Skip to content
View in the app
Armbian Community Forums
How to use h3consumption on Orange Pi Zero?
Featured Replies
I want to disable 2 cores, downlock the CPU and limit the ethernet
i installed Armbian_5.33.171003_Orangepizero_Ubuntu_xenial_next_4.13.4.img via Fetcher
but h3consumption can't be found nor apt-get install'd
isn't it part of Armbian by now or is it simply not part of the Pi Zero armbian?
Because I read a blog of someone who increased the stability of their pi zero with h3consumption
It is part of the still only recommended Armbian images for any H2+ and H3 devices and works there flawlessly. You're using mainline kernel which is marked as experimental and not supported.
And unless someone else is porting h3consumption functionality to mainline kernel I doubt it will ever work there (fex files with legacy kernel vs. device tree with mainline). Though what you're trying to do is easy since only added/adjusted stuff in two simple text files (simply study what h3consumption is doing).
I already dealt with blog posts mentioning even weirder stuff :)
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
