Skip to content
View in the app
Armbian Community Forums
Featured Replies
Hello i have an Tanix tx3 mini,with s905w processor.
After a boot fail i can restore armbian, and i must to flash again android, and the box Is work again.
Now i can't flash armbian because the box don't boot from microSD,
any help?
Edited by tasknodes
  • tasknodes changed the title to Tanix TX3 mini unable to boot from Memory card
  • Author
i use
ARMBIAN_20.10_Arm-64_buster_current_5.9.0
and
i use ARMBIAN_20.10_Arm-64_focal_current_5.9.0
Maybe the dtb file Is not good ?
@tasknodes as SteeMan requested, you should provide details and steps of how you installed Armbian. also provide details of what caused a boot failure and details of what error messages or logs that you saw on your tv/monitor.
I hope this helps... For the TX3 Mini, I used the distributions listed on https://www.armbian.com/amlogic-s9xx-tv-box/. Here's what I did:
* Create a bootable image using Rufus (following the instructions).
* Once the image was created, I went to the SD card's storage drive on a PC and made the following changes:
* In the root directory of the SD card, I copied the file u-boot-s905x-s912 and pasted it as u-boot.ext.
* In extlinux\extlinux.conf, on line 4, I changed it to "fdt /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb".
* I ejected the SD card, inserted it into the TX3 Mini, and turned it on.
If it doesn't work, try a different distribution.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
