Skip to content
View in the app
Armbian Community Forums
GCC distro library not found
Featured Replies
I'm using a fairly newly created Armbian_5.25_Orangepizero_Ubuntu_xenial_default_3.4.113
on my orange Pi Zero, trying to port a set of programs from Raspberry Pi where they work OK.
I use a script to build:
gcc -o myProgram myProgram.cpp -lwiringPi -llibpthread
and my problem is that ld reports that it cannot find libpthread.so.
find / -name libpthread.so -print reports that the library is located in
/usr/lib/arm-Linux-gnueabihf/
and indeed it is.
There is no ld.so.conf file in /etc.
so how do I get my program to complete linkage?
Peter.
PS: I seem to have successfully got the OPi Zero Wifi interface to perform as an access point. I won't be able to confirm this until I can get a program running but a lot of people will be interested if I can confirm and then post my magic incantations!
  • Author
Correction. I do have ld.so.conf which consists on one line thus:
include /etc/ld.so.conf.d/*.conf
and in the referenced folder are two files:
arm-Linux-gnueabihf.conf   and  libc.conf
the first of these files consists of two lines thus:
/lib/arm-linux-gnueabihf
/usr/lib/arm-linux-gnueabihf
and it is in the second of these folders that libpthread.so resides,
along with libpthread.a  and others.
I have tried copying the libraries to the folder in which my program source and the script to compile it resides, tried using the full path of the library, no success.
I am also having another problem with the distro which may relate.
'apt upgrade' and 'apt-get upgrade' find that 'linux-libc-dev' can be upgraded but the upgrade fails with bad URL/404 errors.
PS.  I have confirmed that my setup of the WiFi access point does work completely and properly - excited!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
