Skip to content
View in the app
Armbian Community Forums
server home assistant and armbian
Featured Replies
Good afternoon! I bought a server home assistant. The web used to open. the interface is at 192.168.1.141:8123, and now it’s reaching armbian and I don’t know what to do next and I don’t understand why this happened either. I’m asking for your help. Has anyone ever had such a situation?
If I created the wrong theme, can you tell me where to create it, or maybe there is already such a theme?
Edited by starbirds
From the screenshot you included I can determine the following:
1) This is a repurposed TV Box type device since it is running the rk3318-box build.  (Note Armbian does not support TV Boxes, these are all community supported)
2) You are running a build from May of 2022 (over three years old)
3) As it says: No end-user support: built from trunk (which means this isn't any sort of official armbian build)
For support you really need to go to the company that you bought this from
  • Author
And it turns out that nothing can be done? For some reason, it works for everyone, but something happened to me and it doesn't work anymore.
  • Author
Good afternoon! Thank you for your answers and advice. I didn't buy it because it was cheap, but because I wanted to buy a server and didn't know how much it actually cost. It was my first time buying a server, and I had a bad experience.
Aliexpress randomly assembled electronics is expected to fail - you need to lower expectations, count on luck, read forum for clues, DIY. Little better are single board computers, then what is declared as supported, best what is platinum supported (for this use case FriendlyElec R3S would be perfect) following by Raspbbery Pi and x86 hardware. If you are looking for top first time experience buying a server, you should stick to https://www.supermicro.com/en/ :) I can assure you that Armbian works perfectly on any of servers they sell. But yes, price does not match.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
