Skip to content
View in the app
Armbian Community Forums
Armbian Linux 6.6 (Ubuntu 24.04 Noble) Cubox server image doesn't boot
Featured Replies
Greetings;
I have downloaded this https://dl.armbian.com/cubox-i/Noble_current_server and verified that I got what I was supposed to (ASC, SHA).
I have used a brand new usbimager to install it on various freshly formatted (brand new SD Formatter) and verified working Samsung Evo 32GB, SanDisk Extreme Plus 16GB, Extreme Plus 32GB.
All the formatting, imaging and installation done on an Ubuntu 25.04 laptop.
After usbimager is done, if I use the Ubuntu Disks application to look at the drive, the first partion shows as free space, which seems suspicious.
When I insert the newly-set up SD cards in the Cubox-i4, I see the bootloader start and then do its handoff to the operating system... and then nothing.  No more signal on the HDMI cable, nothing out on ssh, nothing.  The Cubox-i4 tries to reboot every few minutes with no more successful outcome.
This same Cubox-i4 runs fine with the last SD card system disk I built for it using the previous Debian server image.
Does anyone have any ideas?
Thanks in advance!
  • Author
Thanks for your replies!
@Igor is that screen shot you've pastebinned from a connection to the usb TTY?
I've ordered a new card reader / writer which should be here tomorrow.  The only one I currently have is in my elderly System76 laptop and I'm not fully confident in its driver support (for example it doesn't eject or unmount, so my only recourse is to run sync a bunch of times and then shut the machine down).
I don't think there's much point in building new cards with the Bookworm minimal version as that's what I currently have on my Cuboxes.
I will report back.  Thanks again!
Connected via SSH. DHCP client is automatically getting IP, so you should be able to find the device on network after few minutes ... in case HDMI output is really broken. I can't test that as device is stashed to some rack.
  • Author
@Igor thanks for the reply.
In my case, I can't even ping the Cubox much less connect to it.  I'm pretty sure something is failing as the device reboots itself every ~ 2 minutes; each time I see the initial boot with logo on the HDMI, then the screen goes blank, then my monitor claims that HDMI signal is lost, then nothing (including no successful pings) for a couple of minutes, then around again.
I've ordered some new SD cards and a USB SD card reader writer which should arrive Wednesday.  Maybe things will improve after that.  If not I will try a serial connection via USB.
I will report back.
  • Author
@Igor well I'm not getting very far, unless I'm prepared to count failures... I have more of those.
The SD Card reader / writer works well; I can use it to carry out various operations on my brand-new SanDisk Extreme Pro A2, including formatting from the Ubuntu Disks application, running SDCardFormatter, using usbimager to create the Armbian 25.5.1 Noble Minimal system disk, mounting, unmounting and ejecting... When I've finally got the SD card set up, here's what the Ubuntu Disk application shows.  Note the first partition is 4.2MB of free space.
When I put this SD card in the Cubox and boot from it, the same thing appears to happen as previously - on the HDMI-connected monitor, the Cubox bootloader runs and hands off to the boot program, after which the monitor reports no HDMI signal and the monitor goes into sleep mode.  After approximately two minutes, the Cubox bootloader appears again on the monitor, hands off to the boot program, and... the same thing.
Nothing seems to be active at the IP address - I can neither ping nor ssh to it.
This time I have my laptop connected vi USB to the Cubox console port.  Various positive messages show up in
dmesg
finally ending in:
usb 1-6: Detected FT-X
usb 1-6: FTDI USB Serial Device converter now attached to ttyUSB0
But running either screen or minicom, they return immediately, showing no sign of having established any kind of connection, no waiting for a connection, no error message, nothing.
Just a reminder that this Cubox boots and runs fine on the current system SD card which is up-to-date bookworm minimal.
This looks normal. Most of those boards have bootloaders at locations prior to boot partition.
Boot loop. This can be many things - i would guess kernel crash and watchdog issue restart. Why that happens? Hard to tell.
This way?
sudo screen /dev/ttyUSB0 115200
It should prompt out something.
  • Author
Good evening all and thanks @Igor for the suggestions.
I managed to connect to my Cubox-i4 from my laptop via USB with
sudo picocom -b 115200 -r -l /dev/ttyUSB0
and now I have lots of messages, but no success with booting the Ubuntu 24.04 Noble minimal image.  In particular, there is a complaint about a CRC error.  I've attached the text generated by letting the boot process run for awhile.
I decided to try the Bookworm minimal image, and I'm up and running right away with that.  So I guess I will stick with Bookworm for now.
If anyone generates a new Ubuntu 24.04 image they would like me to try, happy to give it a go.  Or of course any other suggestions!
booting_ubuntu_cubox-i.txt
"*** Warning - bad CRC, using default environment"
This is safe to ignore.
It is strange why Ubuntu doesn't work, while Bookworm does. This could be some build infrastructure issue.
https://docs.armbian.com/Developer-Guide_Build-Preparation/
  • Author
@igor I think what you're suggesting is that I build my own Ubuntu 24.04 image using the info on the page; am I correct?
I could be talked into this but first I would have to build a 24.04 system - my three desktops and one laptop are all running 25.04, soon to move to 25.10.  I could sacrifice the "old beater"...
Reading these instructions, I believe that running 24.04 on an X86/64 machine I could build an ARM system; does that make sense?
This comment worries me though:
Quote
This command will generate Ubuntu 24.04 Noble based Gnome desktop environment image for Intel based hardware (uefi-x86). Besides bare desktop, it will contain packages from browsers and desktop_tool sections and it will use unchanged kernel from current kernel branch.
I'm trying to create a minimal IOT image; is that a separate pathway?
Thanks in advance, and as always thanks for Armbian!
You don't have to run on bare-metal. A proper VM will do  too and is probably the better solution.
Yes. Cross-compiling is used for everything that's not native.
You're aware that the command in the docs is just an example, right?
  • Author
@werner, thanks for the information and the clarification on my concern in the documentation.
This sounds like an interesting project, I do believe I'll give it a try.
Again, thank you for the encouragement and the pointers.
  • Author
If you don't mind, just a few points of confirmation.
Reading the documentation and the info on the GitHub page for boards, I gather I can probably expect to use
./compile.sh cubox-i
However looking in the cubox-i.csc file, which at this moment looks like:
# Freescale / NXP iMx6 dual-quad core 1GB/2GB RAM SoC Wifi/BT GBE
BOARD_NAME="Cubox i2eX/i4"
BOARDFAMILY="imx6"
BOARD_MAINTAINER=""
BOOTCONFIG="mx6cuboxi_defconfig"
KERNEL_TARGET="current,edge"
KERNEL_TEST_TARGET="current"
FULL_DESKTOP="yes"
BOOT_LOGO="desktop"
PACKAGE_LIST_BOARD="rfkill bluetooth bluez bluez-tools"
I suspect I want to add/change (at least) the following build switches
BUILD_MINIMAL="yes"
FULL_DESKTOP="no"
since I (think I) want the minimal Ubuntu 24.04.
The build switches page doesn't talk about the KERNEL_TARGET nor the KERNEL_TEST_TARGET switches.  I'm puzzled why there are two kernel targets but only one test target.  Also, is there somewhere I can read up on the differences between targets, especially "current" and "edge"?
Same sort of question about BOOT_LOGO - are those listed / explained somewhere?
Given that I'm looking for a minimal / non-desktop configuration, I still guess I can build from either a server or a desktop Ubuntu running in a VM (or bare metal) as per @Werner's comment.  Does that sound correct?
Finally I'm guessing this should generate a u-boot based image, given that the Cubox uses u-boot; is that correct?
Thanks very much in advance for any clarification.
12 hours ago, monetschemist said:
BUILD_MINIMAL="yes"
FULL_DESKTOP="no"
Use them as command line switches, like ./compile.sh BUILD_MINIMAL=yes FULL_DESKTOP=no ...
KERNEL_TEST_TARGET
Used by CI only which kernel to do automatic build tests.
By any chance, could someone post a link to a working image for Cubox I?
I'm trying to find any working Armbian build and there is nothing that works.
Thanks!
Hi, did you resolve this? I'm having trouble with the same thing and this seems to be the only forum where this is mentioned. It seems to be a watchdog issue?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
