December 14, 2025Dec 14 1 hour ago, KhanhDTP said: + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom) + Zink (openGL) >=60fps@1080p How do you use Zink?
December 14, 2025Dec 14 Author 23 hours ago, 晓飞丁 said: How do you use Zink? Set var environments as below: export PAN_MESA_DEBUG=gl3 export MESA_GL_VERSION_OVERRIDE=4.3 export MESA_LOADER_DRIVER_OVERRIDE=zink export GALLIUM_DRIVER=zink export LIBGL_KOPPER_DRI2=true Edited December 15, 2025Dec 15 by KhanhDTP
December 14, 2025Dec 14 8 hours ago, KhanhDTP said: + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-Proton (https://github.com/GloriousEggroll/proton-ge-custom) + Zink (openGL) >=60fps@1080p I am trying to use Zink to play TomRaider , while comes out this error: [BOX64] Using emulated /home/xfding/tmp/wine-proton-10.0-3-amd64-wow64/lib/wine/x86_64-unix/winepulse.so [BOX64] Using native(wrapped) libpulse.so.0 [BOX64] Using emulated /home/xfding/tmp/wine-proton-10.0-3-amd64-wow64/lib/wine/x86_64-unix/winealsa.so [BOX64] Using native(wrapped) libasound.so.2 [BOX64] Using native(wrapped) libGL.so.1 WARNING: Some incorrect rendering might occur because the selected Vulkan device (Mali-G610) doesn't support base Zink requirements: feats.features.fillModeNonSolid feats.features.shaderClipDistance [BOX64] 15479|Ask to run at NULL, will segfault wine: Unhandled page fault on execute access to 0000000000000000 at address 0000000000000000 (thread 0024), starting debugger... [BOX64] winedbg detected, not launching it! 0024:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 32 332" (731) Read the Wine Developers Guide on how to set up winedbg or another debugger Is "GE-proton" is a must to OpenEL games?
December 14, 2025Dec 14 Author 3 hours ago, 晓飞丁 said: Is "GE-proton" is a must to OpenEL games? No, basically any wine/proton (wow64) will work! 3 hours ago, 晓飞丁 said: I am trying to use Zink to play TomRaider Btw, that version of the Tomb Raider!
December 14, 2025Dec 14 9 minutes ago, KhanhDTP said: Btw, that version of the Tomb Raider! It is Tomb Raider 1~3 remastered Gog version
December 15, 2025Dec 15 Author 11 hours ago, 晓飞丁 said: It is Tomb Raider 1~3 remastered Gog version Have you tried other wine/proton versions?
December 15, 2025Dec 15 1 hour ago, KhanhDTP said: Have you tried other wine/proton versions? I just used wine-proton 10.0.3. While replace the wine to 11.0-rc1 to my previous proton environment, which is working fine on some games, such as VampireSuvivors, after installing Wine-mono, none game can be played. Comes out a dialog says that "Failed to initialize graphics, Make sure you have DirectX installed"
December 15, 2025Dec 15 Author 1 hour ago, 晓飞丁 said: Comes out a dialog says that "Failed to initialize graphics, Make sure you have DirectX installed" (https://www.pcgamingwiki.com/wiki/Vampire_Survivors) Vampire_Survivors is a 64-bit / Direct3D 11.1 game. You may not be setting DXVK (stripped) properly. Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following: Quote info: Game: VampireSurvivors.exe info: DXVK: v1.6.1 info: Built-in extension providers: info: Win32 WSI info: OpenVR warn: OpenVR: Failed to locate module info: Enabled instance extensions: info: VK_KHR_surface info: VK_KHR_win32_surface warn: D3D9: VK_FORMAT_D16_UNORM_S8_UINT -> VK_FORMAT_D24_UNORM_S8_UINT info: Mali-G610: info: Driver: 26.0.0 info: Vulkan: 1.4.335 info: Memory Heap[0]: info: Size: 5945 MiB info: Flags: 0x1 info: Memory Type[0]: Property Flags = 0x7 info: Process set as DPI aware info: Device properties: info: Device name: : Mali-G610 info: Driver version : 26.0.0 info: Enabled device extensions:
December 15, 2025Dec 15 2 hours ago, KhanhDTP said: (https://www.pcgamingwiki.com/wiki/Vampire_Survivors) Vampire_Survivors is a 64-bit / Direct3D 11.1 game. You may not be setting DXVK (stripped) properly. Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following: Thank you so much! I will try it tonight!
December 15, 2025Dec 15 4 hours ago, KhanhDTP said: Set var environments as below: export WINEDLLOVERRIDES="d3d12,d3d12core,d3d11,dxgi,d3d10,d3d10_1,d3d10core,d3d9,d3d8,dinput8=n,b" Download the DXVK (stripped) here: https://github.com/khanh-it/dxvk/releases/tag/releases (You may want to try to know which version works best for this game) Extract and then copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file. If you're setting up the DXVK properly, you will see the output with something like the following: Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again?
December 15, 2025Dec 15 Author 1 minute ago, 晓飞丁 said: Everytime you change you wine version, should the $WINEPREFIX dir such as ~/.wine/driver_c should be deleted and install DVXK dll again? You extract and copy the x64/d3d11.dll, x64/dxgi.dll files to the game's executable file folder. So no need to change anything in $WINEPREFIX dir.
December 15, 2025Dec 15 Have you ever met the issue "lack of OpenAl32.dll". I try to run "isaac:rebirth" and come out cannot find "openAl32.dll", I got a copy of openAl32.dll from my windows laptop and put it into $WINEPREIX/windows/system32 or the game's executable file folder, cannot get the right result.
December 15, 2025Dec 15 Author 2 minutes ago, 晓飞丁 said: Have you ever met the issue "lack of OpenAl32.dll" No You can try to set env: export BOX64_PREFER_EMULATED=1
December 15, 2025Dec 15 6 minutes ago, KhanhDTP said: export BOX64_PREFER_EMULATED=1 Thank you so much!
December 15, 2025Dec 15 On 12/14/2025 at 12:26 PM, KhanhDTP said: export PAN_MESA_DEBUG=gl3 export MESA_GL_VERSION_OVERRIDE=4.3 export MESA_LOADER_DRIVER_OVERRIDE=zink export GALLIUM_DRIVER=zink export LIBGL_KOPPER_DRI2=true After applying these settings, TomeRaider can be run perfectly now, Thank you !
December 15, 2025Dec 15 Author Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + WineD3D / Zink (OpenGL) ~30fps@720p (this game is capped at 30fps) NARUTO SHIPPUDEN - Ultimate Ninja STORM 3 Full Burst HD Edited December 15, 2025Dec 15 by KhanhDTP
December 16, 2025Dec 16 On 12/8/2025 at 11:46 PM, KhanhDTP said: Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + GE-proton-10.25 (https://github.com/GloriousEggroll/proton-ge-custom) + DXVK-stripped v1.6.1 ~60fps@1080p How do you use GE-proton? I see no wine dir in the released tar.gz but a bunch of python script. When I try to run the "proton", comes out "Proton: No compat data path?"
December 16, 2025Dec 16 Author 5 minutes ago, 晓飞丁 said: How do you use GE-proton? You have to use umu-launcher https://github.com/Open-Wine-Components/umu-launcher
December 16, 2025Dec 16 1 hour ago, KhanhDTP said: You have to use umu-launcher https://github.com/Open-Wine-Components/umu-launcher I am trying to use umu-launcher, using this cmd : umu-run "./VampireSuvivors.exe", the steamrt & wine did start up. However, it stucked in "g_proton.winserver_bin" and nothing happened.
December 16, 2025Dec 16 Author 4 minutes ago, 晓飞丁 said: I am trying to use umu-launcher, using this cmd : umu-run "./VampireSuvivors.exe", the steamrt & wine did start up. However, it stucked in "g_proton.winserver_bin" and nothing happened. You should try other Kron4ek's Wine-Builds wine/proton versions. It's easier to set up!
December 16, 2025Dec 16 4 minutes ago, KhanhDTP said: You should try other Kron4ek's Wine-Builds wine/proton versions. It's easier to set up! Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much!
December 16, 2025Dec 16 Author 25 minutes ago, 晓飞丁 said: Sorry I missed the "dxvk-stripped", Now it works fine! thank you so much! Do you mind sharing some screenshots + your settings ? Edited December 16, 2025Dec 16 by KhanhDTP
December 16, 2025Dec 16 1 hour ago, KhanhDTP said: Do you mind sharing some screenshots + your settings Sure. However, I am in PRC, Google is blocked. I cannot login in on my SBC since I am using Google account to login. I have to use my laptop which has vpn. I will find a way this weekend.
December 16, 2025Dec 16 1 hour ago, KhanhDTP said: Do you mind sharing some screenshots + your settings ? I noticed that some games are using DXVK while some are using wined3d, what is the reason? It that a way that force every game using DXVK?
December 16, 2025Dec 16 3 hours ago, KhanhDTP said: Do you mind sharing some screenshots + your settings ? I've read your DXVK-stripped code on github. Looks like your code is far behind the original one. Is your code can match the release "stripped 2.7.1" libs you provide? Thanks you so much!
December 17, 2025Dec 17 Author Armbian 25.8.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Dxvk 1.10.3 (stripped) 30~60fps@720p (mixed settings) Tomb Raider (2013) Definitive Edition
December 20, 2025Dec 20 Author Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + Dxvk 2.1 (stripped) ~60fps@1080p MiSide Full
December 20, 2025Dec 20 Author Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Dxvk 1.7.1 (stripped) ~60fps@1080p Dave The Diver
December 21, 2025Dec 21 Author Armbian 25.11.2 Noble XFCE (BSD Kernel: 6.1.115) + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + box64 3.9 (https://ryanfortner.github.io/box64-debs/) + wine-10.14-staging-tkg-ntsync-amd64-wow64 (https://github.com/Kron4ek/Wine-Builds/releases/tag/10.14) + Dxvk 2.1 (stripped) ~24fps@720p Sleeping Dogs - Definitive Edition
December 22, 2025Dec 22 On 12/20/2025 at 11:52 PM, KhanhDTP said: + PanVk - mesa 26.0 (https://launchpad.net/~ernstp/+archive/ubuntu/mesaaco) + FEX-Emu 2510 + hangover-10.18 (https://github.com/AndreRH/hangover/releases/tag/hangover-10.18) + Dxvk 1.7.1 (stripped) ~60fps@1080p I failed to run DaveTheDiver using these settings: PanVk-mesa 26.0 + wine-Proton-10.0.3 + Dxvk 2.7.1(stripped) the log shows: Unsupported ioctl 74080 Faking StorageDeviceProperty data Is FEX or DXVK 1.7.1 is a must ?
