September 24, 20251 yr About a year ago, I installed the OpenMediaVault image for CM3588-NAS from here: https://www.armbian.com/nanopc-cm3588-nas/ The image is debian-bookworm, which has since become oldstable, while trixie is the new stable. Is it possible to upgrade the distribution and move to trixie packages, even though there are no trixie images for CM3588-NAS? In theory this seems completely feasible as my apt configurations seem completely standard with something like deb http://deb.debian.org/debian bookworm main contrib non-free non-free-firmware and deb [signed-by=/usr/share/keyrings/armbian.gpg] http://apt.armbian.com bookworm main bookworm-utils bookworm-desktop If I attempt the upgrade, will I run into problems with some packages (like armbian-bsp-cli-cm3588-nas-vendor or linux-image-vendor-rk35xx) not actually existing for the target release and platform and just end up bricking my system?
September 24, 20251 yr Solution 1 hour ago, Warma said: will I run into problems with some packages Kernel packages comes from the same (main) repository. This won't cause you problems, if you upgrade from bookworm to trixie, but we can't guarantee for packages that comes from Debian. You might try this way: https://docs.armbian.com/User-Guide_Armbian-Config/System/#stable-distro-upgrade Note that you might need to download updated Armbian key: wget -qO - https://apt.armbian.com/armbian.key | gpg --dearmor | \ sudo tee /usr/share/keyrings/armbian.gpg > /dev/null cat << EOF | sudo tee /etc/apt/sources.list.d/armbian-config.sources > /dev/null Types: deb URIs: https://github.armbian.com/configng Suites: stable Components: main Signed-By: /usr/share/keyrings/armbian.gpg EOF
