Armbian on CM3588, fan does not work
I got mine booting again. The /boot/Image link hadn't been updated. Nor the links in / but I'm not sure they are necessary anyway. I have a desktop and network but ssh won't let me in for some reason. I'll have to get a keyboard and mouse attached. On the upside the fan is working 🙂 While I was rummaging around I noticed I have a dtb overlay for the fan. I thought I had disabled it. It was based on the one here but IIRC I cut it down somewhat. I can look into it more if you still have issues.
- Armbian on CM3588, fan does not work
windows network drive
You aren't telling us much, like what software you are using. I would expect you to need to give it something like smb://10.10.2.101/NAME_OF_SHARE/ or sftp://10.10.2.101:/path/to/folder You will also need to give it a username and password somehow. But first; have you checked you can reach it on the network?
- Cloning image from ssd to cd card
Edit ArmbianEnv.txt when machine is unable to boot?
If there is nothing in /boot at all then its content is probably in another partition which gets mounted while booting. You will need to find that partition and mount it in your PC to modify it.
If the file is not in /boot could you have accidentally deleted it? Maybe try recreating it. In general, if you have boot problems you should attach a serial to USB cable and see what uboot is saying.
- Complete beginner.
Update issue
Did you do Update All after removing knotes? If you were running wayland you will probably need to use Ctrl-Alt-F3 as wayland uses F1 and there is an (unusable) X server on F2 for xwayland. Then, after logging in sudo apt update sudo apt full-upgrade If that's not enough try sudo apt install task-kde-desktop
- Update issue
- Update issue
- Version `25.8.2` of kernel, dtb and/or header package on Armbian Ubuntu Noble break `zfs-dkms`
CM3588-NAS HDMI Audio enablement
The armbian edge image for the FriendlyElec CM3588-NAS is currently on kernel 6.17 but has no HDMI audio despite it having been added in 6.15 (I think). This is simply because it has not been enabled in the device tree for this board. You can enable it with this user overlay: /dts-v1/; /plugin/; / { fragment@0 { target-path = "/hdmi0-sound"; __overlay__ { status = "okay"; }; }; fragment@1 { target-path = "/hdmi1-sound"; __overlay__ { status = "okay"; }; }; };
- Where to Start
CryBaby
