October 22, 2025Oct 22 Looks like the package in subject is not in the repos. However, there are other packages depending on it (explicitly indicating that the required version is >=25.8.2) so this prevents package updates. Interestingly, for the armhf target the package is available, so I suspect a build issue. Any clue?
October 22, 2025Oct 22 3 hours ago, callegar said: I suspect a build issue Correct. It's a problem of: https://github.com/armbian/os/blob/main/.github/workflows/complete-artifact-matrix-all-stable.yml and this configuration: https://github.com/armbian/os/blob/main/userpatches/targets-all-not-eos.yaml It is something to study
October 22, 2025Oct 22 Author Thanks for the quick confirmation! From your answer I guess it is an issue that is already under investigation. No need to open a dedicated issue on some tracker, right?
October 22, 2025Oct 22 3 hours ago, callegar said: that is already under investigation Only that its a known issue. In open source world it is normal to see magnitude more issues then its resolving capacity. I'll look into when possible - its high on 2do list. 3 hours ago, callegar said: No need to open a dedicated issue on some tracker, right? No need.
