callegar
  1. Looks like the current-rockchip64 kernel that one receives with apt on PINE64 rockpro64 is 3.18.10 (6.18.10-current-rockchip64), vulnerable to copy-fail. This seems weird because if you go to https://armbian.com/boards/rockpro64 that page says that the "current" kernel for these systems is 6.18.26 and that is what you get when you download the image file. Is there an issue with updating the apt repos?
  2. Apparently the key needs to go to `/etc/apt/trusted.gpg.d/armbian.gpg` too...
  3. @blood This fixed the issue with the configng repo, but I am still getting the warning for the main repo: ``` Warning: http://apt.armbian.com/dists/trixie/InRelease: Policy will reject signature within a year, see --audit for details Audit: http://apt.armbian.com/dists/trixie/InRelease: Sub-process /usr/bin/sqv returned an error code (1), error message is: Signing key on DF00FAF1C577104B50BF1D0093D6889F9F0E78D5 is not bound: No binding signature at time 2025-11-16T01:37:58Z because: Policy rejected non-revocation signature (PositiveCertification) requiring second pre-image resistance because: SHA1 is not considered secure since 2026-02-01T00:00:00Z Missing key 8CFA83D13EB2181EEF5843E41EB30FAF236099FE, which is needed to verify signature. ```
  4. See There is an issue with the build framework that prevents base-files from being built for the arm64 target. At present time the issue is unresolved, and the root cause might be still unknown.
  5. Thanks for the quick confirmation! From your answer I guess it is an issue that is already under investigation. No need to open a dedicated issue on some tracker, right?
  6. Looks like the package in subject is not in the repos. However, there are other packages depending on it (explicitly indicating that the required version is >=25.8.2) so this prevents package updates. Interestingly, for the armhf target the package is available, so I suspect a build issue. Any clue?
  7. Now it seems that the package is missing for version 25.8.2 and arm64 target. There are packages depending on it (and specifically asking for version >=25.8.2), so this prevents upgrades.
  8. Same issue here. I originally installed a bullseye image and then updated to buster. However /etc/armbian-image-release does not get updated and unfortunately, it is the sole place where motd 10-armbian-header can find information about the distribution codename. In fact: - first /etc/armbian-image-release is read that contains DISTRIBUTION_CODENAME from the original image (which I think is OK because I understand that file should always keep info from the image employed for the initial installation); - then /etc/armbian-release is read, but does not contain anything about the DISTRIBUTION_CODENAME (this does not seem OK to me). - finally no other info is gathered because DISTRIBUTION_CODENAME is already set
  9. A quick msg to kindly ask what should be the current kernels with an RK3318/28 TV Box. My system is currently on -edge and having 6.8.11 installed, but reading here that doing an upgrade on edge, people are receiving 6.10. At the same time `armbian-config` -> System -> Other does not even show me my own kernel among the options, edge being at proposed at 6.7 (associated at armian 24.2.1) and current at 6.6. Is there anything wrong with my config? Is it normal not to see edge kernels associated to the most recent armbian releases (e.g. 24.8.2)?
