binkerd
  1. Error trying to run apt upgrade. Here is the error I receive: The following packages have unmet dependencies: armbian-bsp-cli-rpi4b-current : Depends: base-files (>= 25.8.2) but 25.8.1-12.4+deb12u11-bookworm is to be installed E: Unable to correct problems, you have held broken packages. I am not sure how to resolve this. Help will be greatly appreciated.
  2. I think I spoke too soon. The sudo apt update process is working but when I try to do sudo apt upgrade I get an error: mark@station-m2:~$ sudo apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-config 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/114 kB of archives. After this operation, 611 kB disk space will be freed. Do you want to continue? [Y/n] y dpkg-deb: error: archive '/var/cache/apt/archives/armbian-config_25.2.0-trunk.25.1114.223708_all.deb' uses unknown compression for member 'control.tar.zst', giving up dpkg: error processing archive /var/cache/apt/archives/armbian-config_25.2.0-trunk.25.1114.223708_all.deb (--unpack): dpkg-deb --control subprocess returned error exit status 2 Errors were encountered while processing: /var/cache/apt/archives/armbian-config_25.2.0-trunk.25.1114.223708_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Seems that whatever update this is it is compressed with the zst format. I don't know if this is a repository error or something that needs fixing on my system. Any help would be appreciated.
  3. That worked! Thank you for the quick response and the simple fix to this issue. Mark Binkerd
  4. When I run apt update on my Armbian machine (station-p2) I have started getting the following error message: mark@station-m2:~$ sudo apt update Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://deb.debian.org/debian bullseye-backports InRelease Hit:5 http://security.debian.org bullseye-security InRelease Hit:1 http://armbian.chi.auroradev.org/apt bullseye InRelease Hit:7 http://giteduberger.fr rpimonitor/ InRelease Get:6 https://github.armbian.com/configng stable InRelease [3,264 B] Err:6 https://github.armbian.com/configng stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 Reading package lists... Done W: GPG error: https://github.armbian.com/configng stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 E: The repository 'https://armbian.github.io/configng stable InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. mark@station-m2:~$ This has been happening for the past few days, and I don't know how to resolve the issue. I can get to the https://github.armbian.com/configng webpage from my network but I keep getting errors when trying to update. Any ideas on how to resolve this?
  5. Recently when I run apt update I receive a message that an update is available. When I run an apt list --upgradable it shows the following: mark@station-m2:~$ sudo apt list -a --upgradable Listing... Done armbian-bsp-cli-station-m2-current/bullseye 24.5.1 arm64 [upgradable from: 23.8.1] armbian-bsp-cli-station-m2-current/bullseye 24.2.1 arm64 armbian-bsp-cli-station-m2-current/now 23.8.1 arm64 [installed,upgradable to: 24.5.1] When I run apt upgrade I get the following output: mark@station-m2:~$ sudo apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. mark@station-m2:~$ I am not sure why it does not do the upgrade of arm64. What am I doing wrong?
