Skip to content
View in the app
Armbian Community Forums
Armbian for MXQ-Pro 5g 4k H313
Featured Replies
Hello Everyone, I've seen a few threads on these boards but wanted to create a centralized source for information.
It's my understanding there are multiple variants of these boards, the one I have and used is IK316Q-EMCP_V4.1
I know there are other versions without UART ports, mine was lucky enough to have them.
To build this image (adjust the compile command to your liking)
git clone https://github.com/sicXnull/armbian-build
cd armbian-build
git checkout MXQ-PRO
./compile.sh build BOARD=mxqpro-h313 BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=cinnamon DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base EXPERT=yes KERNEL_BTF=no KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm
Prebuilt Images
Armbian-unofficial_26.02.0-trunk_Mxqpro_bookworm_current_6.12.65_cinnamon_desktop.img
Armbian-unofficial_26.02.0-trunk_Mxqpro_bookworm_current_6.12.65_minimal.img
Unfortunately this board was already flashed with MiniArch by the time i got it, so i was unable to get the original DTB. Therefore, wifi does not work
Is someone able to get the DTB from this board so we can get wifi working?
  • Author
Update on this box.
Got wifi working fine. Everything works well with SD Boot. Installing to EMMC brings me to this error
U-Boot SPL 2024.01_armbian-2024.01-S866c-Pa67d-H5afb-Vc88c-B2eb2-R448a (Feb 15 2026 - 18:20:18 -0500)
DRAM base address is defined as 0x40000000
DRAM has 14 b/raw, 10 b/col, 4 B/width, 2 #rank and 8 #bank
DRAM top address must be less than 0x40000000
DRAM: 1024 MiB
Trying to boot from MMC2
MMC Device 1 not found
spl: could not find mmc device 1. error: -19
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
Chasing down what could be causing this.
  • Author
On 2/16/2026 at 8:53 PM, Kevin su said:
I ran into the same issue when flashing
"Armbian-unofficial_26.02.0-trunk_Mxqpro_bookworm_current_6.12.65_minimal" (worked only in SD Card).
The issue was gone when I switched to
"Armbian-unofficial_25.05.0-trunk_X96q-lpddr3-v1-3_bookworm_edge_6.12.11_server"
built by @Nick A
Hey @Nick A any idea which patch you're applying that fixes the EMMC boot?
I created this account just to thank you, man. Thank you so much, it worked perfectly here. Finally, my old TV box has another use besides collecting dust.
Edited by Jorge Henrique
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
