Skip to content
View in the app
Armbian Community Forums
BCM43430 WiFi (AP6212) - HT Avail timeout clkctl 0x50 on BCM43430/2 stepping - Armbian 5.9 kernel
Featured Replies
Hello everyone,
I have two identical-looking "arm-64" Amlogic TV boxes (S805X-based, meson-gxl-s805x-p241.dtb), both running the same Armbian image (kernel 5.9.0-arm-64 from balbes150 build).
Both boxes have BCM43430 WiFi+BT combo (AP6212 module) on SDIO (mmc1).
Problem:
- STB 1: WiFi works perfectly (BCM43430/1 stepping)
- STB 2: WiFi fails to initialize (BCM43430/2 stepping) — always ends with "HT Avail timeout (1000000): clkctl 0x50"
Key dmesg from STB 1 (working):
[   7.719726] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[   7.736079] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/1
[   7.976301] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Mar 30 2021 01:12:21 version 7.45.98.118 (7d96287 CY) FWID 01-32059766
→ wlan0 appears and connects normally
Key dmesg from STB 2 (not working):
[  7.564287] brcmfmac: F1 signature read @0x18000000=0x1542a9a6
[  7.568240] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430-sdio for chip BCM43430/2
[  8.644057] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[  9.652082] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
→ No wlan0 interface created
What I already tried on STB 2:
1. Copied entire /lib/firmware/brcm folder from STB 1 → same timeout
2. Symlinked brcmfmac43430a0-sdio.bin / .txt → same timeout
3. Symlinked Raspberry Pi 3 variant (brcmfmac43430-sdio.raspberrypi,3-model-b.txt) → same
4. Created symlink for board-specific file: ln -sf brcmfmac43430-sdio.txt brcmfmac43430-sdio.amlogic,p241.txt → still fails
5. Added various NVRAM tweaks (boardflags3=0x48200100, LPO=1, sd_drivestrength=6, etc.) → no change
6. Tried sdio_overclock=0 (and 25000000) → module says "unknown parameter 'sdio_overclock' ignored" (not supported in this kernel 5.9 build)
Current /lib/firmware/brcm contents (relevant files):
- brcmfmac43430-sdio.bin
- brcmfmac43430-sdio.txt
- brcmfmac43430a0-sdio.bin
- brcmfmac43430a0-sdio.txt
- brcmfmac43430-sdio.raspberrypi,3-model-b.txt
- brcmfmac43430-sdio.amlogic,p241.txt (now exists)
modinfo brcmfmac shows no sdio_overclock or drive_strength parameter available.
Questions:
- Has anyone seen BCM43430/2 stepping specifically fail like this while /1 works on the same image?
- Is there a known good NVRAM .txt for BCM43430/2 on Amlogic boxes?
- Any other module parameters or DTB tweaks that could slow down SDIO clock or force LPO mode?
- Or is this most likely a hardware difference (LPO crystal issue on the module/board)?
Any help or pointers greatly appreciated — really want to avoid buying USB dongles if possible.
Thanks!
ls /lib/firmware/brcm
  • bcm4329.hcd
  • BCM4330B1.hcd
  • bcm4330.hcd
  • BCM43342.hcd
  • BCM4334B0.hcd
  • BCM43430A1.hcd
  • BCM43430B0.hcd
  • bcm43438-sdio.hcd
  • BCM4343A0.hcd
  • BCM4345C0_003.001.025.0162.0000_Generic_UART_37_4MHz_wlbga_ref_iLNA_iTR_eLG.hcd
  • BCM4345C0.amlogic,sm1.hcd
  • BCM4345C0.firefly,rk3566-roc-pc.hcd
  • BCM4345C0.radxa,zero2.hcd
  • BCM4345C0.raspberrypi,4-compute-module.hcd
  • BCM4345C5.hcd
  • BCM4356A2.hcd
  • BCM4359C0.hcd
  • BCM4362A2.hcd
  • BCM4362A2-khadas-vim4.hcd
  • brcmfmac4329-sdio.bin
  • brcmfmac4329-sdio.txt
  • brcmfmac4330-sdio.amlogic,q200-n1.txt
  • brcmfmac4330-sdio.bin
  • brcmfmac4330-sdio.rockchip,rk3318-box.txt
  • brcmfmac4330-sdio.txt
  • brcmfmac43342-sdio.bin
  • brcmfmac43342-sdio.txt
  • brcmfmac4334-sdio.bin
  • brcmfmac4334-sdio.rockchip,rk3318-box.txt
  • brcmfmac43362-sdio.bin
  • brcmfmac43362-sdio.txt
  • brcmfmac4339-sdio.1CK.txt
  • brcmfmac4339-sdio.bin
  • brcmfmac4339-sdio.txt
  • brcmfmac4339-sdio.ZP.txt
  • brcmfmac43430a0-sdio.bin
  • brcmfmac43430a0-sdio.txt
  • brcmfmac43430b0-sdio.bin
  • brcmfmac43430b0-sdio.rockchip,fine3399.bin
  • brcmfmac43430b0-sdio.txt
  • brcmfmac43430-sdio.bin
  • brcmfmac43430-sdio.clm_blob
  • brcmfmac43430-sdio.raspberrypi,3-model-b.bin
  • brcmfmac43430-sdio.raspberrypi,3-model-b.txt
  • brcmfmac43430-sdio.raspberrypi,model-zero-2-w.bin
  • brcmfmac43430-sdio.raspberrypi,model-zero-2-w.txt
  • brcmfmac43430-sdio.txt
  • brcmfmac43436s-sdio.bin
  • brcmfmac43436s-sdio.raspberrypi,model-zero-2-w.bin
  • brcmfmac43436s-sdio.raspberrypi,model-zero-2-w.txt
  • brcmfmac43455-sdio.amlogic,sm1.bin
  • brcmfmac43455-sdio.amlogic,sm1.txt
  • brcmfmac43455-sdio.bin
  • brcmfmac43455-sdio.clm_blob
  • brcmfmac43455-sdio.firefly,rk3566-roc-pc.bin
  • brcmfmac43455-sdio.firefly,rk3566-roc-pc.txt
  • brcmfmac43455-sdio.radxa,zero2.bin
  • brcmfmac43455-sdio.radxa,zero2.txt
  • brcmfmac43455-sdio.raspberrypi,3-model-b-plus.bin
  • brcmfmac43455-sdio.raspberrypi,4-compute-module.bin
  • brcmfmac43455-sdio.raspberrypi,4-compute-module.txt
  • brcmfmac43455-sdio.raspberrypi,4-model-b.bin
  • brcmfmac43455-sdio.raspberrypi,4-model-b.txt
  • brcmfmac43455-sdio.raspberrypi,5-model-b.bin
  • brcmfmac43455-sdio.raspberrypi,5-model-b.clm_blob
  • brcmfmac43455-sdio.raspberrypi,5-model-b.txt
  • brcmfmac43455-sdio.txt
  • brcmfmac43456-sdio.bin
  • brcmfmac43456-sdio.clm_blob
  • brcmfmac43456-sdio.radxa,rockpi4b.bin
  • brcmfmac43456-sdio.radxa,rockpi4b.txt
  • brcmfmac43456-sdio.radxa,zero2.bin
  • brcmfmac43456-sdio.radxa,zero2.txt
  • brcmfmac43456-sdio.radxa,zero.bin
  • brcmfmac43456-sdio.radxa,zero.txt
  • brcmfmac43456-sdio.raspberrypi,400.bin
  • brcmfmac43456-sdio.raspberrypi,400.txt
  • brcmfmac43456-sdio.txt
  • brcmfmac4356-sdio.bin
  • brcmfmac4356-sdio.clm_blob
  • brcmfmac4356-sdio-nanopi-m4v2.bin
  • brcmfmac4356-sdio-nanopi-m4v2.txt
  • brcmfmac4356-sdio.txt
  • brcmfmac4359-sdio.bin
  • brcmfmac4359-sdio.txt
  • brcmfmac43752-pcie.bin
  • brcmfmac43752-pcie.clm_blob
  • brcmfmac43752-pcie.txt
  • brcmfmac43752-sdio.9tripod,x3568-v4.bin
  • brcmfmac43752-sdio.9tripod,x3568-v4.txt
  • brcmfmac43752-sdio.bin
  • brcmfmac43752-sdio.clm_blob
  • brcmfmac43752-sdio.firefly,rk3568-roc-pc.bin
  • brcmfmac43752-sdio.firefly,rk3568-roc-pc.txt
  • brcmfmac43752-sdio.txt
  • brcmfmac-ap6330-sdio.bin
  • brcmfmac-ap6330-sdio.txt
  • clm_bcm43752a2_ag.blob
  • config_bcm43456c5_ag.txt
  • config_bcm43752a2_ag.txt
  • config.txt
  • fw_bcm43456c5_ag_apsta.bin
  • fw_bcm43456c5_ag.bin
  • fw_bcm43752a2_ag_apsta.bin
  • fw_bcm43752a2_ag.bin
  • fw_bcm43752a2_ag_p2p.bin
  • nvram_ap6256.txt
  • nvram_ap6275s.txt
  • SYN43711A0.hcd
23 minutes ago, Bug Hunter said:
Hello everyone,
In the world of TV boxes "identical looking" means nothing, as manufacturers build each batch with the lowest cost components available at the time.  There are many cases where identical looking boxes even contain different cpus ( ie amlogic vs rockchip).
My recommendation would be first to verify the markings on the boards (there is usually some sort of board identifying text on the board)to really see if they are the same under the  hood.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
