Skip to content
View in the app
Armbian Community Forums
Helios64 rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp Kernel 6.18.10 Crash/Freeze
Featured Replies
Hi everybody,
I running Helios64 with kernel 6.12.58 since a long time and the prahal dtb file rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and my helios64 work well.
Today, Armbian upgrade to 6.18.10 kernel.
Is this update use the same change or patch like in rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp ?
Is rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp work with 6..18.10 kernel ?
Is I must to downgrade to 6.12.58 kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze at this kernel version ?
Thanks for answer.
Edited by BipBip1981
  • Author
For information:
First reboot and crash same that before use rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp. 😞
Back to 6.12.58, rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and freeze to this setting
Me and my brother have helios64 with 6.18.10 Kernel :
RAID 10 / LVM / LUKS and crash always when "cryptsetup open..." start
Crash when many I/O
Crash when use Full CPUs
With rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and Kernel 6.12.58 or 6.12.(XX below):
Me, never crash but I reboot often and power off often for personal choice.
My brother have uptime upper than 100 or 200 days with problem, freeze or crash
Bye
  • BipBip1981 changed the title to Helios64 rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp Kernel 6.18.10 Crash/Freeze
FWIW, I am running -edge kernel from armbian with respective dtb (linux-dtb-edge-rockchip64 package), and it's quite stable.
vmlinuz-6.18.0-rc6-edge-rockchip64
dtb-6.18.0-rc6-edge-rockchip64
  • Author
Hello, I hope you don't have any problem.
Maybe me and my brother have defective or more unstable helios64 than you.
Only thing I can say that Prahal share here the specifics files rk3399-kobol-helios64.dtb-6.XX.xx-L2-hs400-opp in this forum since two years ago my helios64 and my brother's helios64 work stable only with it.
I back to 6.12.58 Kernel with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp file and freeze firmware/kernel with armbian-config.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
