Skip to content
View in the app
Armbian Community Forums
Temporarily suspending ramlogging, will this work?
Featured Replies
For troubleshooting purposes I want to temporarily have logs written immediately to disk rather than to ram. Will this work?
# ramlog OFF
sudo systemctl stop armbian-ramlog
sudo sed -i 's/^ENABLED=.*/ENABLED=false/' /etc/default/armbian-ramlog
sudo systemctl restart rsyslog
sudo journalctl --flush
# ramlog ON
sudo sed -i 's/^ENABLED=.*/ENABLED=true/' /etc/default/armbian-ramlog
sudo systemctl start armbian-ramlog
Edited by mc510
# ramlog OFF
# ramlog ON
Temporarily suspending RAM logging should generally be tested carefully, especially if the goal is reducing unnecessary writes or memory usage. Checking the actual logging configuration first can clarify what is consuming resources. For audio-related hardware projects, an Authentic ST TDA7293 amplifier IC may also require proper thermal and power-supply considerations.
Yes, that should work for a temporary troubleshooting test. I’d verify #systemctl status armbian-ramlog# and check #/var/log# afterward to confirm logs are being written directly to disk. Re-enabling ramlog should restore the normal setup.
Edit: For the code, I use # because it was breaking the paragraph when I was using the code option. Sorry :)
Edited by DavidFajardo
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
