July 28Jul 28 I tried to run the image build process using Docker. At one point it tries to download the Linux tree and due to my slow Internet connection (max 3MB/s) there seems to be a connection reset from Github due to a too long download time (after 9 minutes, simillar times in 2 attempts). ✗ [ ...........](2.57 MB/s) Downloading linux-complete.git.tar 1.68/3.55 GB 47.34% 9m27s └─ sha256:dd18f1227c9bcf8d3a1c1ecd55721323639550c2845750f59168e17a0d0483bd Error: failed to copy content to /armbian/cache/git-bundles/kernel/linux-complete.git.tar.oras.pull.tmp/linux-complete.git.tar: copy failed: stream error: stream ID 1; PROTOCOL_ERROR; received from peer Is there any workaround besides switching to a faster Internet connection?
July 29Jul 29 KERNEL_GIT=shallow (or was it GIT_KERNEL? Having hard times to keep that in mind correctly) but anyway, this will load a shallow tree with the corresponding kernel version only.
July 29Jul 29 Author It is KERNEL_GIT=shallow, and this really helped (at least in the evening, when the 3MB/s were possible). What I am now stumbling across are errors in tar and cp due to file ownership issues: I cloned the Armbian repo as plain user and am now running in Docker as root: I probably should have cloned the repo as root already ...
July 29Jul 29 Author To follow up myself: somehow the Docker build does not work: If I clone the repo as root, I cannot call "./compile.sh docker-shell", as the script cannot create directories in "build" then. I also cannot run the compile.sh as root, as the script is complaining then that I run docker as root / sudo. So I have to clone the repo as plain user. Later I am running compile.sh in Docker, where I will be root. Many downloaded files will be owned by root then. As soon as tar is run (by root) this tries to keep the old user and fails (workaround: add the option --no-same-owner, e.g. in kernel-git-oras.sh:217), I also have to remove the "-p" option from cp (e.g. kernel-config.sh:69). But I am hit by a similar issue in the build process and are flooded with many error messages like these: GEN kernel/kheaders_data.tar.xz tar: include/clocksource/samsung_pwm.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/arm_arch_timer.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/timer-davinci.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/pxa.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/timer-ti-dm.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/hyperv_timer.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/timer-xilinx.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/timer-riscv.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/clocksource/timer-goldfish.h: Cannot change ownership to uid 0, gid 0: Invalid argument tar: include/trace/stages/stage6_event_callback.h: Cannot change ownership to uid 0, gid 0: Invalid argument Docker seems to be recent (Docker version 29.6.2, build 1.fc44) - and I ran it according to the "Building with Docker" page: me@localhost:~/BananaPro/repo/build$ ./compile.sh docker-shell BOARD=bananapipro BRANCH=current BUILD_DESKTOP=no BUILD_MINIMAL=no EXPERT=yes KERNEL_CONFIGURE=no RELEASE=trixie KERNEL_BTF=no KERNEL_GIT=shallow root@dbd99257d5cb:/armbian# ./compile.sh The build directory is on a NFS share. And something seems to be very much screwed up ...
July 30Jul 30 Have you tried adding yourself to the docker group and run docker as your user? https://docs.docker.com/engine/install/linux-postinstall/
July 30Jul 30 Author Yes I have and I call compile.sh (and from it docker) as plain user. But inside docker I am root. There are options to run Docker rootless or to change uid/gid. But as I did not read anything about this in the Armbian docs I have not tried such changes yet.
July 30Jul 30 Author I moved the whole build directory from my nfs drive to an internal drive, changed all file ownerships as root to me:mygroup and voila: the build process ran through. I do not know what caused the above problems: but it seems to be somehow related to having the tree on an nfs drive.
July 31Jul 31 12 hours ago, loeriver said: the tree on an nfs drive see what is /etc/exports on the nfs-server something like *(rw,no_root_squash,no_subtree_check) should give more or less unrestricted access. And not to forget id-mappening for non-root, unless you manually made sure same uid gid for users Edited July 31Jul 31 by eselarm
July 31Jul 31 Author Thank you for the hint. -/etc/exports on the nfs server is: /volume1/documents *(rw,async,no_wdelay,no_root_squash,insecure_locks,sec=sys,anonuid=1025,anongid=100) -the server's /etc/idmapd.conf has: [Mapping] Nobody-User = nfsnobody Nobody-Group = nfsnobody The uid/gid on nfs server and client do not match (server: 1026 / 100, client: 1000 / 1000). I think I have to educate myself about the nfs setup (or work on the non-nfs disk) as this becomes not quite OT in this forum.
