Friday at 06:11 AM2 days I have a recently commissioned Radxa Rock-5B that I use as my PXE host. It has a number of iso images that are loopback mounted on directories like /var/www/html/mirrors/Fedora-44. I recently attempted an install of Fedora 44 on a VM and it crashed, complaining that it was unable to download a package from /var/www/html/mirrors/Fedora-44/Packages/p/parted-3.6-14.fc44.x86_64.rpm. I checked the directory on the Rock-5B and it was indeed missing but it was also giving me a lot of output that looked like -r--r--r-- 1 root root 264876 Feb 2 2026 policycoreutils-3.10-1.fc44.x86_64.rpm ?????????? ? ? ? ? ? policycoreutils-newrole-3.10-1.fc44.x86_64.rpm all files from here are the same ??? I checked the sha256sum of the Fedora 44 iso against the one published on the website and it matches. I renamed the file and downloaded a fresh copy, just in case, same size, same sha256sum, same errors. I rebooted the Rock-5B to see if it was a transient problem but it was still broken on reboot. I copied the iso file to a different system running an older kernel and mounted it there and the content was correct and there were no errors and more importantly the parted-3.6 rpm file it complained about was present. I removed linux-image-bleedingedge-rockchip64 and rebooted into Linux rock-5b 6.18.53-current-rockchip64 and the problem was gone. It seems something about loopback mounting iso images is broken in 7.3.0-rc4. I have not tried a more recent bleedingedge version yet.
Friday at 06:32 AM2 days bleedingedge is not meant to be used as end-user but for developers only. Use "current" if you prefer stability over breakage.
