Skip to content
View in the app
Armbian Community Forums
Need help in understanding a i2c configuration effect
Featured Replies
I configured 2 armbian on sd card and the configuration of the i2c is the same in armbianEnv.txt. Plattform Olimex-Lime2 A20
verbosity=1
logo=disabled
console=both
disp_mode=1280x1024p50
overlay_prefix=sun7i-a20
rootdev=UUID=194e9f9a-826b-4644-9f2f-4ef388277816
rootfstype=ext4
overlays=i2c1 i2c2 uart3
as you see, I confiugred the overlays.
But on one image I get:
#image with desktop
sudo i2cdetect -l
i2c-3   i2c             mv64xxx_i2c adapter                     I2C adapter
i2c-1   i2c             mv64xxx_i2c adapter                     I2C adapter
i2c-2   i2c             mv64xxx_i2c adapter                     I2C adapter
and booting the other image I get
# headless image
sudo i2cdetect -l
i2c-0   i2c             sun4i_hdmi_i2c adapter                  I2C adapter
so I get an aditional device for i2c-0.
I don't understand what's happening. What could cause this effect? Or better: What must happen, that the i2c-0 does not appear in the list.
One more info: The first image has a runing desktop and the second one in headless. Maybe this has something to do with the issue?
Can someone give me a pointer to understand this. Btw. both versions work perfekt:
i2cdetect -y 2
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 21 -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
i2cdetect -y 3
The 0x68 is a RTC which is configured. So everything is OK, but I drives me crazy not to understand what I've done "wrong". Can someone give me a pointer?
Thanks for all help.
Edited by Peter Heß
typo
its "de" in DT. you can comment/remove
&de {
	status = "okay";
in dt
so the i2c hdmi adapter will not be initialized
or you can use aliases to define i2c buses like
aliases {
    i2c0 = &i2c0;
    i2c1 = &i2c1;
	i2c2 = &i2c2;
	i2c3 = &i2c3;
so the i2c hdmi adapter will be named i2c-4
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
