Skip to content
View in the app
Armbian Community Forums
Xorg HDMI kiosk with audio
Featured Replies
Hi.
Any suggestions on how I can setup a kiosk, using as little resources as possible?
I want a couple of icons, that can launch some apps, that's it.
Regards,
Morten
in the right hand corner is the search-box: kiosk
Do you have any special board in mind? If not, I recommend something Rockchip-based or Odroid XU4. With those, you can have GPU acceleration, which can be very useful for a kiosk if your apps use OpenGL, WebGL, etc..
Once you have chosen the board, setting up the kiosk is straightforward: installing an Armbian Desktop image, and then applying the corresponding media-script if you want 3D acceleration.
  • Author
I have an Orange Pi One, with working OpenGL acceleration.
Hm. Applying media-script, what does that mean?
Regards,
Morten
Edited by morphex@gmail.com
Missing text
No, that was for Rockchips and XU4. You need to run a script after installation to enable 3D acceleration in those boards. But the H3-based boards (like your OPi) have it enabled by default.
Well, then, if that's the case, flash an Armbian Desktop image and you are good to go. It depends on how you want to set up your kiosk, but maybe the easiest way is configuring the XFCE menu to auto-hide, and put the icons of the apps you want on the desktop.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
