- Helios64 doesn't boot when powered on
I discovered that the problem is uboot related. It started after updating to the last stable armbian version. When the helios fail to boot I can attacche the usb cable and type boot on the uboot prompt and it start to work. If i power off and power on with cable attacched (to debug the error) it boot without issue! Very strange! Which version of uboot is the recommended one?
- Helios64 - Armbian 23.08 Bookworm issues (solved)
In my case the new kernel runs fine! Now I'm trying your last suggestion, i wrote here the command, so any users can try: echo "ENABLE=true MIN_SPEED=600000 MAX_SPEED=1800000 GOVERNOR=ondemand" > /etc/default/cpufrequtils systemctl disable --now armbian-hardware-optimize.service vi /etc/rc.local and insert before exit 0: for i in $(awk -F":" "/xhci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 20 > /proc/irq/$i/smp_affinity done for i in $(awk -F":" "/ahci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 30 > /proc/irq/$i/smp_affinity done
i'm sorry, but I can't find the reply button on the forum. In any case, @ebin-dev I don't have any monitor connected do the NAS. The only stable kernel i found is the 6.1.63 (whith this image Armbian_23.11.1_Helios64_bookworm_current_6.1.63.img.xz). My third try was ok, because the freeze is random, so sometis it occurs after 5 minutes, so you can configure the system. Edit: I confirm that kenrel 6.1.63 is stable for me. The 6.1 is an LTS version, why isn't update in armbian? https://endoflife.date/linux
magostinelli
