- Hardware video acceleration with recent armbian/mainline kernel (Kodi)
I have a T9 2017 rk3328 box running Ubuntu xcfe many hours for downloading. There are not problems but xcfe displays lunchs himself many times and i have to close 20 or more instances of this application when checking the progress. Box is not crashed by this funny clonning. is it possible to avoid this? p.d. la test trunk
yes. Things that can be tried: - DTS phy-mode = "rgmii-id"; or phy-mode = "rgmii-rxid"; - UBOOT CONFIG_PHY_REALTEK=y CONFIG_DWC_ETH_QOS=y CONFIG_DWC_ETH_QOS_ROCKCHIP=y CONFIG_DM_PMIC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y
Can you boot in a working ethernet and then reboot to this trial?
I know that told you the ID of your chip but also told you to switch to phy1 but you didn't. I think It is possible to use the generic driver but don't know if It will work. Changes in dtb must be accurate.
I see this on your dts: ethernet-phy@1 { compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22"; But I think should be: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <0x01>; And try to use the generic driver for ethernet.
Installing armbian on Yundoo Y8 TV box (RK3399)
It is shown on internet how to get maskrom, serIal, and more. Also there is a clue that this box should start with firefly dtb but not stated exactly. Things are different from 1997 now and getting this working without experience is very difficult. With kernel 4.4 you could try with android dtb.
You can not use android dtb. You must try without It or try the rk3399 files included in the sdcard. i cant see the second rockchip (pmic)
- How can I install LXQt on Armbian?
Request for Firmware – Device Live Broadcast V4 (Board: LIVE3588V4.2)
Have you connected the HDMI?
Question about RK3318 armbian method usb
All you need is in this thread CSC Armbian for RK3318/RK3328 TV box boards And the special uboot is there. You have a chance to brick you device so if you don't understand something don't go ahead.
Armbian CSC rk3318 from @jock says: • OTG USB 2.0 port (also as boot device!)
I think your driver is already in armbian, but your chip is not identified. To get it working you can identify it in the ethernet node this way: mdio { compatible = "snps,dwmac-mdio"; #address-cells = < 0x01 >; #size-cells = < 0x00 >; ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; ====> compatible = "ethernet-phy-id7b74.4411", "ethernet-phy-ieee802.3-c22";
The driver is well so the problem seems you are in the wrong ethernet phy. Change from phy0 to phy1 in the ethernet node.
I have a T9 rk3328 tv box with rtl8723bs wifi. This chip got burned out a hot day and the box powers off when is on. There is a way to kill the sdio?
maka
