10 bit AV1 decoder missing in kernel?
I have edge kernel installed and working. I compiled the v4l2 ffmpeg but some of my av1 videos are not working. After some digging I noticed that v4l2-ctl --device=/dev/video4 --list-formats-ext ioctl: VIDIOC_ENUM_FMT Type: Video Capture Multiplanar [0]: 'VT12' (Y/UV 4:2:0 (4x4 Linear)) [1]: 'NV12' (Y/UV 4:2:0) Shouldn't this include the 10 bit formats as well? (NV15?) Does anyone know why the 10 bit format is missing in the kernel? Is this specific to the orange pi? I found this GitHub - dongioia/rock5bplus-rkvdec2: Rock 5B+ (RK3588) on mainline Linux 7.1: V4L2 stateless RKVDEC2/Hantro hardware video decode (VP9 / H.264 / HEVC / AV1) up to 4K, plus a guide for stock Chromium 150 with clean in-browser HW decode (VP9 Mali green artifact fixed upstream in the Chromium 150 ANGLE roll). HDMI 2.0 4K@60Hz, on Beryllium OS. · GitHub Going to test their patches, I am unsure if they are related to the issue but they list a 10 bit VP9.
- Armbian 26.5.1 - Ubuntu 26.04 - Current doesn't boot
I never used the UART serial console - is there a guide to set that one up? Also I tried multiple cards - and no difference. Usually any good image would at least make one flash of green light but no luck with any of these (ones published on site and freshly built). Is there a way I can check the u-boot version on my working card?
Lost USB devices after 25.8.2 update
I have my kernel locked to 6.1.75 but still after 25.8.2 update, I lost all USB devices on both of my Orange PI 5. Only the USB3 port is working. The only way I've been able to get access to the USB is by switching to the latest `current` kernel... Any clues on what is going on? Firmware or kernel upgrades are not doing anything... where can the issue be???? I tried downgrading to many different versions but beside the current branch, USB is gone. Thanks
- Analog Audio out not working (25.2.1 / 6.1 kernel / KDE Neon)
- Armbian_25.8.2_Orangepi5_noble_current_6.12.49.img.xz fails to boot
- Overlays do not apply even when selected in armbian-config and then rebooting
- pwm overlay broken on kernel 6.12
Overlays seem to be broken in latest 25.5.1 vendor build
See for more details but without using the overlay-user folder - I was not able to get the pwm to work on a fresh download.
OMG - I can confirm this issue is also happening on orange pi 5 with latest armbian v25.5.1 + Linux 6.1.*-vendor-rk35xx This is my armbianEnv.txt The pwm only loads when I copy it into overlay-user. The really strange thing is that I have two of these boxes and the one that went through upgrades is working just fine but I'm trying a fresh install on another and no way to get the overlay to work except this hack
OttawaHacker
