Nanopc T6 emmc format 2 partions
Hello I would like to know if it is possible to have 2 partions on the emmc. Indeed My emmc have 256go for only the os armbian with OMV (2.5go only used). I would like to have for example a boot partition with size of 50go and an other partition for my data (200go). However when I use armbian-config the full emmc is formated. If a solution exist could you please share with me the solution. Thanks in advance for your support.
Nanopc T6 pass openmediavault 6 to 7 procedure ?
Hello everyone I would like to provide you with my experience to maintain an OMV server with docker. the information below are strategi and not a tutorial step by step. After several installation I found for me the best install easy to maintain. My server is a nanopc T6 with EMMC memory and NVME disk. could work also with all other similar pc cards The solution works aloso with SDcard. the installation of armbian and OMV will installed on the SDcard or EMMC memory. Please note that in case you want to use EMMC memory please transfer os to EMMC before install OMV After that I recommend to spleet the NVME in two partitions one for docker data and other one for general data. The partition dedicated for docker I recommend 60 go (depend your size of your container) The data partition take the rest After that connect you in OMV, install service compose and declare all hard drive you have. In the partition for docker, create folder as following: - for docker named docker - one compose named compose - one data named data after that go to service compose parameter in OMV and declare all dossier above in the appropriate location example data for data etc. For the folder docker copy the exact folder link from share folder area in OMV. after that you can install portainer with compose file added in compose --> file. when you have installed portainer you can continue all docker installation through portainer. Now the most interesting, if you want to change your armbian os with a clean installation or pass to the new version of OMV. you can format the SDcard or EMC memory without a risk to loose your docker installation. indeed you reinstall the os and OMV on EMMC or SDcard after that you follow the instruction above to declare the different existing folder in OMV for docker configuration in compose, you save and all docker installation reappear as it its installed previously. hoping this information help you.
Nanopc t6 down after tried to upgrade kernel 5.10.160-legacy-rk35xx to new 6.1 available in armbian-config
I have reinstall the device and the docker. However, I need to install the firmware 5.10.160. Indeed the nanopc-t6 don ot star with any image with firmware 6.1.43 or 6.8.9. I do not understand why ?. Apprently I understand that you are able to install the version 6.1.43 without issue. Could you please explain me the procedure you have used ? Thanks in advance for your support.
- Nanopc t6 down after tried to upgrade kernel 5.10.160-legacy-rk35xx to new 6.1 available in armbian-config
Hello all I have broken my installation when I tried to install the kernel 6.1 my current kernel 5.10.160-legacy-rk35xx. My nanopc t6 do not start. My installation is on EMMC and start on it. Could you please help me to recover it ? I have a backup file from OMV but I don't know how to push the backup to the EMMC? other possibility I guess copy the boot folder backup to EMMC boot folder but I do not know if it is enough. I really appreciate an help furthermore a clear turial could help evryone to recover an installation on EMMC memory. Thanks in advance for your support.
- Nanopc T6 pass openmediavault 6 to 7 procedure ?
Dear all I have a nanopc T6 with kernel 5.10.160 bullseye and omv 6 EMC 256gb avec NVME I would like to pass on omv 7 with bookworm. I found this command which change all automatically and keep the configuration. "omv-release-upgrade" Could you please confirm that this command could be used with armbian or an other metod exist ? Thanks in advance for your support.
Nico21311
