Is an upgrade of armbian-config/section software possible (without full re-install) ?
Thanks for your quick answer @Igor So this is the standard way to update any package, So easy, I should have test that before posting here .... I just successfully do : apt update apt list --upgradable armbian-config/inconnu 25.5.0-trunk.53.0213.103604 all [pouvant รชtre mis ร jour depuis : 25.5.0-trunk.18.0207.210415] --> YES there is an update available apt install armbian-config --> juste to update only this package, to no impact other part of my system And ....TADA ! I now have all the latest "software" available in armbian-config available ๐ thx again
Dear all, sorry if it's a stupid question ๐ ... I successfully install armbian on my SBC (in fact a TV box) for amlogic https://www.armbian.com/amlogic-s9xx-tv-box/ I install this one: Armbian_community_25.5.0-trunk.4_Aml-s9xx-box_bookworm_current_6.12.12.img.xz I use armbian-config / section "software" to add some 3rd party software, and it works very well The choice in the "software" section is limited on my setup, and when I look at the source code (main branch) here https://github.com/armbian/configng/tree/main/tools/modules/software I see more software available.... Is it possible to upgrade only "armbian-config" to have an easy access to all the latest software available ? Or perhaps, just copy/paste the module_xxxxxx.sh that I see on the source code somewhere ? Thanks in advance Folks ! Regards Nico.
TV Box S912 (X9T 4K): problem to install on emmc
Dear All, First I would like to thanks all the contributors to armbian, What a great OS for our small SBC ! Context: I run succesfully latest Armbian on a X9T 4K TV Box (amlogic s912) from SD Card 2GB (following instructions here The Problem: I would like to run armbian from emmc (16GB on this box) for better reliability and performance. So, I run the install-aml.sh script, I had some error (no boot.ini ...), but the process seems to finish successfully Next Reboot: It's seems my boot partition is Not OK ... something missing ... For reference See bellow for reference the succesfull boot from the sdcard If I boot from SDCard, I can inspect the /boot and root partition on emmc, everything seems ok On the emmc partition, the /boot/extlinux/extlinux.conf is correctly modified: extlinux.conf LABEL Armbian LINUX /Image INITRD /uInitrd #FDT /dtb/amlogic/meson-gxbb-p200.dtb #FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb #FDT /dtb/amlogic/meson-gxl-s905w-tx3-mini.dtb FDT /dtb/amlogic/meson-gxm-q200.dtb #FDT /dtb/amlogic/meson-g12a-x96-max.dtb #FDT /dtb/amlogic/meson-g12b-odroid-n2.dtb append root=LABEL=ROOT_EMMC rootflags=data=writeback console=ttyAML0,115200n8 console=tty0 rw no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles And the disk partion on the emmc fdisk -l /dev/mmcblk1 Disk /dev/mmcblk1: 14.64 GiB, 15724445696 bytes, 30711808 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x09170000 Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 1953792 2953215 999424 488M c W95 FAT32 (LBA) /dev/mmcblk1p2 2955264 30711807 27756544 13.2G 83 Linux If you can help me .... Thx in advance Nico
Nico059
