- Armbian Image for Kernel 4.4
- Unstable weston with Lima and linux kernel 6.1-rk3328
Hey, I am working with Weston-7 alongside Lima driver with MESA v19 to render using MALI450 on the display but it isn't rendering it properly. I thought the issue is with MESA so I upgraded it to v20 and applied required patches for Weston-7, but still the result is same and there is no improvement. I have attached the video link below of Weston terminal on the display for reference. Weston render Any idea what I might be missing here?
Facing issues to bring up RTL8723AS wifi module with rk3328 soc
I have been working on rk3328 (kernel 6.1) based board recently and have been trying to bringup wifi RTL8723AS module using rockpi-e image. As there is no direct support available for this module I have tried to cloning it from github and building it but it gives compilation errors. Hence I referred to drivers available in the kernel and found one for the module similar to that of my module (RTL8723BS), cross verified through user manual and datasheets and build it using armbian. The driver gets built properly and even initializes upon powerup but it isn't getting into probe. The wifi is interfaced through SDIO to the board. Any idea what might be wrong?
