steakhutzeee
  1. @hmof which OS are you using? I'm using OMV and had to set these settings the OMV way, but at the end the source of truth is always etc/default/cpufrequtils If you are using OMV you have to use env variables to set the values and then deploy. In the end OMV use ENABLE=true, even if it is deprecated for armbian. Hope this helps.
  2. Some questions here: Isn't cpurequtils deprecated? So any other edit to other file is just ignored on reboot? Could you suggest the appropriate values to apply for min/max? Just as a test I set it to false again, so not using cpurequtils and armbian-config says I'm between 2000 and 2000 Mhz. So, I suppose I'm using the values I applied before.
  3. Thank you! Was looking there just now. I already did: echo 1400000 | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq echo 200000 | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_min_freq that resulted in steakhutzeee@dk:/sys/devices/system/cpu$ grep . /sys/devices/system/cpu/cpu0/cpufreq/* /sys/devices/system/cpu/cpu0/cpufreq/affected_cpus:0 1 2 3 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq:200000 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency:155000 /sys/devices/system/cpu/cpu0/cpufreq/related_cpus:0 1 2 3 /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies:200000 300000 400000 500000 600000 700000 800000 900000 1000000 1100000 1200000 1300000 1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors:userspace powersave conservative ondemand performance schedutil /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:cpufreq-dt /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:ondemand /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:200000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed:<unsupported> grep: /sys/devices/system/cpu/cpu0/cpufreq/stats: Is a directory But I see a different value in: steakhutzeee@dk:/sys/devices/system/cpu$ cat /etc/default/cpufrequtils ENABLE=true GOVERNOR=ondemand MAX_SPEED=2000000 MIN_SPEED=2000000 So which values should I set here? And how can I manage the edits I made before? Maybe this is true only when using DBT instead of using CPU under armbian-config? Thank you!
  4. Hi, I'm running OMV on Odroid HC2. I updated to OMV 7.7.1. Armbian to 24.5.1 with Linux kernel 6.6.31-current-odroid-xu4. After reboot the server started to act very slow. I tried to reapply the DBT for HC1/2 via armbian-config but this did not help. armbian-config says I'm on ondemand governor between 200-200 MHz. What could be the issue? Actually my system says I should run dpkg --configure -a but this command hang here and the system reboots after few seconds... steakhutzeee@dk:~$ sudo dpkg --configure -a [sudo] password for steakhutzeee: Setting up containerd.io (1.6.33-1) ... EDIT: From armbian-config -> CPU (deprecated) I applied the max I could find. Now armbian-config states I'm running 1800-1800 MHz. I was able to successfully run the dpkg command and update my system. steakhutzeee@dk:~$ grep . /sys/devices/system/cpu/cpu0/cpufreq/* /sys/devices/system/cpu/cpu0/cpufreq/affected_cpus:0 1 2 3 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq:200000 /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_transition_latency:155000 /sys/devices/system/cpu/cpu0/cpufreq/related_cpus:0 1 2 3 /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies:200000 300000 400000 500000 600000 700000 800000 900000 1000000 1100000 1200000 1300000 1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors:userspace powersave conservative ondemand performance schedutil /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver:cpufreq-dt /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor:ondemand /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq:1400000 /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed:<unsupported> grep: /sys/devices/system/cpu/cpu0/cpufreq/stats: Is a directory I did: echo 1400000 | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq echo 200000 | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_min_freq If this issue with frequencies has to be fixed with an update, how can I set a correct frequency manually now? I'm afraid this high freq could cause damage actually. Thank you!
  5. So I noted that the file armbian-image-release is sourced by 10-armbian-header. So I tried renaming it and the issue disappeared. Can I delete this file? Why it is so different from the one below? I see they are both sourced. steakhutzeee@dk:~$ cat /etc/armbian-image-release.bak # PLEASE DO NOT EDIT THIS FILE BOARD=odroidxu4 BOARD_NAME="Odroid XU4" BOARDFAMILY=odroidxu4 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=3f998600-dirty DISTRIBUTION_CODENAME=buster DISTRIBUTION_STATUS=supported VERSION=20.05.7 LINUXFAMILY=odroidxu4 BRANCH=legacy ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=Image IMAGE_UUID=fb5ecd1b-019b-4ffe-8887-1f486b947dda steakhutzeee@dk:~$ While I'm clearly on a newer version: steakhutzeee@dk:/etc$ cat armbian-release # PLEASE DO NOT EDIT THIS FILE BOARD=odroidxu4 BOARD_NAME="Odroid HC1" BOARDFAMILY=odroidxu4 BUILD_REPOSITORY_URL=https://github.com/armbian/build BUILD_REPOSITORY_COMMIT=2630001fb LINUXFAMILY=odroidxu4 ARCH=arm IMAGE_TYPE=stable BOARD_TYPE=conf INITRD_ARCH=arm KERNEL_IMAGE_TYPE=zImage FORCE_BOOTSCRIPT_UPDATE= FORCE_UBOOT_UPDATE= VENDOR="Armbian" VENDORDOCS="https://docs.armbian.com" VENDORURL="https://www.armbian.com" VENDORSUPPORT="https://forum.armbian.com" VENDORBUGS="https://www.armbian.com/bugs" BOOTSCRIPT_FORCE_UPDATE="no" BOOTSCRIPT_DST="boot.ini" VERSION=24.2.1 REVISION=24.2.1 BRANCH=current steakhutzeee@dk:/etc$
  6. For some reason the output of this file is wrong: steakhutzeee@dk:/etc/update-motd.d$ ./10-armbian-header ___ _ _ _ _ _ ____ _ / _ \ __| |_ __ ___ (_) __| | | | | |/ ___/ | | | | |/ _` | '__/ _ \| |/ _` | | |_| | | | | | |_| | (_| | | | (_) | | (_| | | _ | |___| | \___/ \__,_|_| \___/|_|\__,_| |_| |_|\____|_| Welcome to Armbian 24.2.1 Buster with Linux 6.1.79-current-odroidxu4 No end-user support: unsupported (buster) userspace! steakhutzeee@dk:/etc/update-motd.d$ I'm trying to figure out why and where from it picks up the value Buster instead of Bookworm. Any help?
  7. Hi, i updated my Odroid HC2 to OMV7 following posts 29 and 30 from this thread https://forum.openmediavault.org/index.php?thread/51654-seemingly-cannot-update-and-upgrade-anymore-due-to-repository-having-no-release/&postID=383747#post383747 Actually looks like the update completed successfully, but i noted that connecting in ssh my motd looks wrong. Attaching it. I do not understand why it picks the VERSION_CODENAME "Buster" while i'm instead on "bookworm". Following scripts in /etc/update-motd.d : steakhutzeee@dk:/etc/update-motd.d$ grep VERSION_CODENAME /etc/os-release | cut -d"=" -f2 bookworm steakhutzeee@dk:/etc/update-motd.d$ /usr/bin/lsb_release -c | cut -d":" -f2 | tr -d "\t" bookworm steakhutzeee@dk:/etc/update-motd.d$ grep CODENAME /etc/lsb-release | cut -d"=" -f2 grep: /etc/lsb-release: No such file or directory How could i solve this? Thanks!
