Support for Realtek RTD1395
Uhm can I have uart RTD1395PU baud rate?
- S805 Armbian new backup
Way to boot from USB when my emmc is dead
Like some command about it
Skip reason why i have uboot, but can i have tutorial about how to boot armbian from usb by uboot?
ok but this is about bootloader
my build is 5.15 by ophub
so now my uboot is in my sd card according to some instructions and I still can't boot into uboot directly
i found some uboot commands here but i don't understand: setenv bootcmd 'run mytvboot; if test ${bootfromnand} = 1; then setenv bootfromnand 0; saveenv; else run bootfromsd; run bootfromusb; run bootfromemmc; fi; run storeboot' setenv mytvboot "run boot_usb; run boot_mmc; run boot_emmc;" setenv boot_usb 'usb start; for usbdev in 3 2 1 0; do if fatload usb ${usbdev} 1000000 u-boot.ext; then go 1000000; fi; if fatload usb ${usbdev} 1000000 s905_autoscript; then autoscr 1000000; fi; done' setenv boot_mmc 'for mmcdev in 0 1 2; do if fatload mmc ${mmcdev} 1000000 u-boot.ext; then go 1000000; fi; if fatload mmc ${mmcdev} 1000000 s905_autoscript; then autoscr 1000000; fi; done' setenv boot_emmc 'for mmcdev in 0 1 2; do if fatload mmc ${mmcdev} 1000000 u-boot.emmc; then go 1000000; fi; if fatload mmc ${mmcdev} 1000000 s905_autoscript; then autoscr 1000000; fi; done' setenv upgrade_step "0" saveenv
can change default boot to sd card. because i already run armbian using sd card
Install Armbian on s905x2 with android recovery boot
sorry my bad english
im no longer in recovery mode now. but i can't boot to armbian when i use adb reboot update
my box is cm201-1-s905 and im stop at recovery mode like your
i have same problem too
thantien
