darcyg
  1. I only tested the main configuration to ensure that the kernel and file system rootfs are normal, and other configurations have not been tested yet The attachments are patch files and several modified source files. The testing was conducted in my own buildroot project. It has not been tested in armbian yet (there are currently some issues with the armbian compilation environment). My buildroot project was launched based on the DTS of this post. I believe it should be available in armbian. add-rk3576h96-m9s-dts.patch rk3576-linux.dtsirk3576-h96-m9s.dtsrk3576.dtsi
  2. hey, @cmuki! Using the dts from the rk3576-evb1-v10 / rk3576-armsom-sige5 / rk3576-rock-4d in the https://github.com/radxa/kernel/arch/arm64/boot/dts/rockchip/ directory After modification, they can all boot the Armbian version h96-m9s Note: The rk3576-linux.dtsi file forcibly specifies the UUID of the rootfs device partition, which may cause system boot failure. Adjustments might be needed. The basic modification method is simple: disable the PCIe and GMAC1 configurations, modify the reset_pin configuration of GMAC0 to gpio2 and PB3 to enter the system. I used rock-4d as the template for modification. Other modifications have not been thoroughly studied yet.
  3. @xiaobao80, The official use is the closed source Mali library. Panfrost is an open-source GPU library. It should be that the Panfrost module does not yet support rk3576
  4. @Protx Thank you very much. I am currently compiling other systems, and I will test your solution later. Additionally, I have found that the latest official trunk403 build, as well as the previous trunk250, both exhibit this error. I am testing using an SD card.
  5. hi Protx: Hello, I have just started learning the compilation of Armbian. I am also using the OrangePI3b with the RK3566. I need to study the startup of rknpu in version 6.1.43. I downloaded the latest repository from https://github.com/armbian/build, specifically the main branch. I compiled it according to your compilation configuration. There was an error message upon booting. ** Booting bootflow 'mmc@fe2b0000.bootdev.part_1' with script Boot script loaded from mmc 1:1 155 bytes read in 3 ms (49.8 KiB/s) 8598033 bytes read in 724 ms (11.3 MiB/s) 37388800 bytes read in 3133 ms (11.4 MiB/s) 167999 bytes read in 47 ms (3.4 MiB/s) Working FDT set to a100000 Trying kaslrseed command... Info: Unknown command can be safely ignored since kaslrseed does not apply to all boards. Unknown command 'kaslrseed' - try 'help' Moving Image from 0x2080000 to 0x2200000, end=4660000 ## Loading init Ramdisk from Legacy Image at 0a200000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 8597969 Bytes = 8.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 0a100000 Booting using the fdt blob at 0xa100000 Working FDT set to a100000 Loading Ramdisk to ec68e000, end ecec11d1 ... OK ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0) Loading Device Tree to 00000000ec5fc000, end 00000000ec68dfff ... OK Working FDT set to ec5fc000 Starting kernel ... [ 14.607208] Internal error: Oops: 0000000096000044 [#1] SMP [ 14.607281] pwm-backlight backlight: Looking up power-supply from device tree [ 14.607780] Modules linked in: [ 14.607848] pwm-backlight backlight: Looking up power-supply property in node /backlight failed [ 14.608469] sprdbt_tty(+) [ 14.608536] pwm-backlight backlight: supply power not found, using dummy regulator [ 14.608569] fuse dm_mod ip_tables ipv6 panel_simple pwm_bl [ 14.611186] CPU: 1 PID: 312 Comm: systemd-modules Tainted: G W 6.1.43-vendor-rk35xx #1 [ 14.612092] Hardware name: Rockchip RK3566 OPi 3B (DT) [ 14.612601] pstate: 60400009 (nZCv daif +PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 14.613282] pc : tty_unregister_driver+0x44/0x78 [ 14.613752] lr : tty_unregister_driver+0x40/0x78 [ 14.614212] sp : ffff80000d02b7c0 [ 14.614544] x29: ffff80000d02b7c0 x28: ffff80000a10f0c8 x27: 0000000000000000 [ 14.615242] x26: 0000000000000000 x25: ffff80000a23f000 x24: ffff0000092f8400 [ 14.615937] x23: ffff80000122d000 x22: ffff80000122e178 x21: 00000000ffffffef [ 14.616632] x20: ffff80000a2272e0 x19: ffff000008c7fb00 x18: 0000000000000000 [ 14.617328] x17: 7420797274207427 x16: 6e6f64202c545349 x15: 5845452d20687469 [ 14.618028] x14: 7720305442797474 x13: 2e79726f74636572 x12: 696420656d617320 [ 14.618724] x11: 656874206e692065 x10: 6d616e20656d6173 x9 : ffff80000915ee50 [ 14.619420] x8 : 696166206c616e72 x7 : 65746e695f646461 x6 : 0000000000000000 [ 14.620115] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 0000000000000000 [ 14.624209] x2 : ffff000001731c80 x1 : dead000000000100 x0 : dead000000000122 [ 14.628287] Call trace: [ 14.631921] tty_unregister_driver+0x44/0x78 [ 14.635732] mtty_probe+0x1e8/0x2b0 [sprdbt_tty] [ 14.639572] platform_probe+0x70/0xc0 [ 14.643282] really_probe+0x1cc/0x390 [ 14.646981] __driver_probe_device+0x140/0x158 [ 14.650736] driver_probe_device+0x48/0xd0 [ 14.654452] __device_attach_driver+0xd8/0x128 [ 14.658174] bus_for_each_drv+0xa0/0xc8 [ 14.661870] __device_attach+0xf8/0x180 [ 14.665557] device_initial_probe+0x1c/0x28 [ 14.669266] bus_probe_device+0x38/0x9c [ 14.672951] device_add+0x550/0x688 [ 14.676590] platform_device_add+0xec/0x224 [ 14.680286] mtty_pdev_init+0x50/0x1000 [sprdbt_tty] [ 14.684061] do_one_initcall+0x94/0x1e4 [ 14.687709] do_init_module+0x58/0x1e0 [ 14.691329] load_module+0x1818/0x18e0 [ 14.694906] __do_sys_finit_module+0xf8/0x118 [ 14.698524] __arm64_sys_finit_module+0x24/0x30 [ 14.702132] invoke_syscall+0x8c/0x128 [ 14.705606] el0_svc_common.constprop.0+0xd8/0x128 [ 14.709161] do_el0_svc+0xac/0xbc [ 14.712551] el0_svc+0x2c/0x54 [ 14.715888] el0t_64_sync_handler+0xac/0x13c [ 14.719319] el0t_64_sync+0x19c/0x1a0 [ 14.722684] [ 14.722684] PC: 0xffff80000875f79c: [ 14.723515] rk_pcie_establish_link: 132 callbacks suppressed I found that the latest repository does not match your operating instructions. For example, the commit 63073b4af636146d26a7f0f258610eed060c8f34 in the Kwiboog's uboot repository branch rk3568-2023.10 is no longer found. However, the compilation does not report any errors. Could you please share your compilation repository and configuration? Thank you. @Protx kernel.log
