Amlogic s905l board p271 install guide
@akabulous did you check your board architecture using AIDA and already make sure your board is p271 with Amlogic S905l ? let me know what are your's tv box model ?
SOLVED !! I have try using dtb for p281 and it's work right now, i search on google that p271 architecture is same with p281 Download armbian s9xx on here I have use dtb file name is meson-gxl-s905w-p281.dtb on /dtb/amlogic By following this step : Now it's work now Thanks to armbian team and community !!
i have buy cheap tv box tripsky mini q3, i have look on recovery is based a95x_r2 and have this specs : and i search on google for dtb is in here : https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/amlogic/meson-gxlx-s905l-p271.dts i don't know how to port this, because i don't have any experience for porting this support, any support on this ?
CSC Armbian for RK322x TV box boards
While using a multitool on the RK3229Q 221P V1.3 board to perform a backup, the screen suddenly went blank midway through the process. What could be causing this issue? my device is MXQ PRO 4K 5G
