cent
  1. DDR Version 2.06 20170316 In 1A1A1C1C 3 DDR3 282C1C1C 3 35351C1C 3 Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB mach:2 OUT Boot1 Release Time: 2017-06-12, version: 2.40 ChipType = 0xa, 1384 SdmmcInit=2 0 BootCapSize=2000 UserCapSize=3728MB FwPartO�*V�k%���=0 20 StorageInit ok = 113376 SEC = 1 SecureInit 4 114844 Code check OK! theLoader 0x60000000, 168321 hdr 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, hdr 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, hdr 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, hdr 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, � U-Boot 2014.10-RK3128-06-g829baaa (Apr 19 2024 - 09:54:01) CPU: rk3128 cpu version = 0 CPU's clock information: arm pll = 600000000HZ periph pll = 594000000HZ ddr pll = 600000000HZ codec pll = 400000000HZ Board: Rockchip platform Board Uboot as second level loader DRAM: Found dram banks: 1 Adding bank:0000000060000000(0000000040000000) 128 MiB GIC CPU mask = 0x00000001 rk dma pl330 version: 1.4 remotectl v0.1 pwm freq=0xb�*V�k%��� = 0 20 SdmmcInit = 2 0 storage init OK! Using default environment GetParam Load FDT from boot image. power key: bank-0 pin-5 can't find dts node for fixed No pmic detect. power hold: bank-16777215 pin-255, active level-0 Secure Boot Mode: 0x1 SecureBootEn = 1, SecureBootLock = 1 #Boot ver: 2024-04-19#2.40 empty serial no. normal boot. checkKey vbus = 1 board_fbt_key_pressed: ir_keycode = 0x0, frt = 0 no fuel gauge found no fuel gauge found can't find power_ctr node for lcdc0 can't find dts node for deviceinfo rk_hdmi_register:fail to read deviceinfo Hdmi Devices Not Exist. SCREEN_TVOUT rk3036_tve_init:use default config g_tve_pos = 1 read logo on state from dts [1] no fuel gauge found ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp! Secure Boot state: 1 kernel @ 0x62000000 (0x0068db20) ramdisk @ 0x65bf0000 (0x00167f20) bootrk: do_bootm_linux... Loading Device Tree to 65600000, end 65617398 ... OK Add bank:0000000060000000, 0000000040000000 Starting kernel ... <hit enter to activate fiq debugger> [ 0.000000] Booting Linux on physical CPU 0xf00 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.104 (txcz@txcz-host2) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Apr 19 09:45:47 CST 2024 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3128, model: rockchip,rk3128 [ 0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x9dc00000, offset:0x00000000 [ 0.000000] hdmi init vic is 1704292188 [ 0.000000] cvbs init tve.format is 1 [ 0.000000] cvbs init tve.format is 1 [ 0.000000] cvbs init tve.format is 1 [ 0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x9dc00000 for uboot logo [ 0.000000] rockchip_ion_reserve [ 0.000000] ion heap(cma): base(0) size(800000) align(0) [ 0.000000] ion heap(vmalloc): base(0) size(0) align(0) [ 0.000000] cma: CMA: reserved 8 MiB at 9d400000 [ 0.000000] ion_reserve: cma reserved base 9d400000 size 8388608 [ 0.000000] cma: CMA: reserved 16 MiB at 7f000000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1672000 s13440 r8192 d15232 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 261120 [ 0.000000] Kernel command line: vmalloc=496M rockchip_jtag console=ttyFIQ0 androidboot.baseband=N/A androidboot.selinux=disabled androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x00006000@0x00010000(kernel),0x00006000@0x00016000(boot),0x00010000@0x0001C000(recovery),0x00020000@0x0002C000(backup),0x00040000@0x0004C000(cache),0x00008000@0x0008C000(metadata),0x00002000@0x00094000(kpanic),0x00200000@0x00096000(system),0x00020000@0x00296000(radical_update),-@0x002B6000(userdata) storagemedia=emmc uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2024-04-19_09:54:01 hdmi.vic=1704292188 tve.format=1 SecureBootCheckOk=1 [ 0.000000] rockchip jtag enabled [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 964088k/964088k available, 84488k reserved, 483328K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0bc6f5c (12028 kB) [ 0.000000] .init : 0xc0bc7000 - 0xc0c26480 ( 382 kB) [ 0.000000] .data : 0xc0c28000 - 0xc0d0c3a0 ( 913 kB) [ 0.000000] .bss : 0xc0d0c3a0 - 0xc0e2c95c (1154 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
