David Morse
  1. This is the speed that I should be getting from the drive. 500GB – 5,000/3,000MB/s Even benchmark sites are showing the following. Sequential Read - 4,334 MBytes/Sec Sequential Write - 3,478 MBytes/Sec Random Seek Read Write (IOPS 32KQD20) - 2,226 MBytes/Sec IOPS 4KQD163 MBytes/Sec
  2. I have built an Orange Pi 5 Plus systems. I have a 256gb eMMC card which seems to run as speed would expect. Yet when I test the NVMe drive I get slow speeds compared to what is suggested to get. I have seen other people posts that suggest they are getting at least 4gb/s using NVME drives. I have searched for other issues but there is no errors in the logs just can't get the speeds I was expecting. I have the following which suggests at least 5gb/s KINGSTON SNV3S500G I have formatted it using Ext4. root@orangepi5-plus:/boot# hdparm -Tt /dev/nvme0n1 /dev/nvme0n1: Timing cached reads: 2804 MB in 2.00 seconds = 1404.10 MB/sec Timing buffered disk reads: 1394 MB in 3.00 seconds = 464.64 MB/sec
  3. Thanks for this I did do searching but need to probably know more on where to look.
  4. I have done a flat install of "Armbian 24.11.2 Bookworm Minimal" but for some reason it keeps failing to update. I get the following output and I can ping the IP address but when I try to follow the http address it show s a 404 error in the browser. Is there something I am missing as I have tried to fix it but not sure if its just me or everyone is getting this as the file is missing to download. root@orangepi5-plus:~# apt update Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Get:5 https://github.armbian.com/configng stable InRelease [3,264 B] Hit:6 http://armbian.tnahosting.net/apt bookworm InRelease Fetched 3,264 B in 1s (2,240 B/s) Reading package lists... Done Building dependency tree... Done Reading state information... Done 1 package can be upgraded. Run 'apt list --upgradable' to see it. root@orangepi5-plus:~# apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-config 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 116 kB of archives. After this operation, 715 kB disk space will be freed. Do you want to continue? [Y/n] y Err:1 https://github.armbian.com/configng stable/main arm64 armbian-config all 25.2.0-trunk.103.1129.130128 404 Not Found [IP: 185.199.111.153 443] E: Failed to fetch https://github.armbian.com/configng/pool/main/a/armbian-config/armbian-config_25.2.0-trunk.103.1129.130128_all.deb 404 Not Found [IP: 185.199.111.153 443] E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
