TRS-80
Moderators
  1. You will probably be better off installing Nginx (Proxy?) Manager as an add-on, assuming it is available. It will be much easier for you that way.
  2. TRS-80 replied to balbes150's topic in RISC-V
    They may have been tests. Or they could have worked at one time. But Linux kernel (and other hardware) is always moving forward and everything needs constant maintenance.
  3. I am going to go back to basics, so apologies if this is too obvious. Are you guys opening ports between the container and the host? I am still learning Docker myself, but isn't the default to limit containers to their own little Docker network, where they can only reach each other? For example, when I started running Home Assistant as a Docker container, I had to allow `--net=host` option (well, the equivalent in my `docker-compose` file, but you get the idea).
  4. I don't even own one of these, but I am fascinated by how you guys finally got it stable it sounds like? After all these years. And the fact that Kobol (our once partner) went out of business years ago (I just looked and we are about a month shy of 3 years now). Such triumph of the human will (and this project!), it could almost warm an old cynics heart. EDIT: I updated (removed) the "instability" comments about Helios64 in my NAS article: So, you want to run a file server (aka NAS)?
  5. Alas, I am but a low to (at best!) mid-level wizard. Nonetheless, I try and help people as best i can. Yes, some of that I knew, some I learned just now (thank you). Maybe the devs know this, too (and just don't have time to deal with it), or maybe they don't. In any case, do you think you might be able to get a patch together to help fix this problem, for the benefit of everyone?
  6. It should be. OK I got mine working by installing the Armbian image using the nand-sata-install tool, but that was from an older version of Armbian. I am not sure what that does, if it just copies it like dd does then this will work. But if not then you might have a bad time. In particular, I would not recommend over-writing something that "works" (even though for me I hate Manjaro and KDE and therefore it never did "work" for me, lol) but I hope you take my meaning. I am not sure if this is supported in Armbian or not. Part of the problem is that the PBP has kind of weird boot order where it prefers eMMC over SD card. Putting all the above together was why I decided to leave Tow-Boot on my SPI, at least for the time being. It gives a lot of options which can be helpful, especially in case of recovery. Maybe Armbian get around to addressing the boot loader situation at some point, until then I would be careful about what you do, or you might end up with a paperweight!
  7. Armbian_23.02.0-trunk_Pinebook-pro_sid_edge_6.1.11_xfce_desktop (as mentioned above) pine64-pinebookPro-2021.10-005 (TowBoot) I did have to check my notes to find the latter. Sorry for not mentioning it previously, I thought people were asking about which Armbian version. I have not changed anything on that PBP since then, but from the sounds of it I need to test some newer versions. No idea when I might get around to that though, kind of busy with other things right now. If anyone finds a newer working combination, please post details. @Miles Raymond, I just read your linked GitHub issue, it appears you are using the same Tow-Boot version I am, which is interesting. I had got that from my notes, so I decided to double check on the actual device. So I went into Tow-Boot console and can confirm the following (transcribed by hand but double checked): => version Tow-Boot 2021.10 (Oct 04 2021 - 15:09:26 +0000)005 [variant: spi] aarch64-unknown-linux-gnu-gcc (GCC) 9.3.0 GNU ld (GNU Binutils) 2.35.1
  8. I have been reading into this for some hours now, and it seems like I will need to write (or perhaps modify from some existing) DTB overlay or something like that? I tried following the instructions here, and using a .dtbo file (hifiberry-amp100.dtbo) I copied from OSMC I have here on an RPi 3, but I don't think that's right as it mentions 'brcm,bcm2835' which I suppose means it can only be used with RPi. The above mentioned .dtbo file seemed to be in some binary format, although I could still make out some text in it. I can't even seem to find the uncompressed (plain text) versions, I searched OSMC and HiFiBerry repos (amongst others), I don't think I am looking in right place (maybe I need to look in RPi Foundation or Linux kernel sources?). Any help or pointers will be appreciated. This seems to be a non-trivial task (at least for a low to medium level wizard such as myself).
  9. I slowly convinced myself that I wanted a PineBook Pro, some time after the first production run. But then COVID, parts shortages, etc. happened and they were not available again until about mid-2022. But when they were, I decided to snap one up. And since then I have not been able to get it to boot Armbian. It came from the factory with Manjaro, which for me being a Debian guy, might as well be useless. So the PBP sat around collecting dust. Since then I have tried a few times to get it to work. I read many forum posts, tried some things. I won't document all that in detail. In this post, I will continue from where I left off here. However to summarize, that was about comparing DTB/DTS files to Kali, which supposedly works. That may become useful later, but I don't think that's the main problem. I think that the main problem is that this new batch came from the factory with no bootloader flashed to the included SPI flash chip. This is a problem on PineBook Pro because the RK3399 has a kind of weird boot order: SPI, eMMC, SD card. Therefore, if you just put in some SD card you flashed, it still boots from the factory Manjaro from the eMMC. Whatever bootloader they are using also apparently will not recognize an otherwise working Armbian image on an SD card. Now, because of the weird boot situation, there is supposed to be a switch to turn off eMMC. However this did not work for me. Which means one of 2 things: The switch does not work. I read at least one other person saying this. Also on the new revision, it's in a slightly different place than the old revision (may be a clue, maybe not). I simply had a bad Armbian image (which I had burned to sd card) that would not boot for whatever reason.[0] But let's put that aside for a moment. As I still think the main problem is the (empty) SPI. And that will be the easiest/best path forward. I confirmed the 'blank SPI' theory 2 different ways. First, as mentioned in a follow-up to the linked post (4 paragraphs above): As Martijn Braam states here: Of course, I like to beat a horse until it's really dead be thorough in my investigations, so today I wasted a lot of time[1] verifying that this indeed was the case. I did so by dd'ing the /dev/mtd0 block device into a file[2]. When I examined the file, it contained all FF, and also it is about 16 MiB in size. To me this confirms that indeed, the SPI on the new batch comes from the factory empty. So what is next? I keep reading that the only people who had success first had to install something like tow-boot to the SPI. That will be my next step. But before I flashed anything to SPI, I wanted to see what really came from the factory (which I did above). I will continue to document my progress whenever time allows for me to work on this. [0] Once I got the bootloader situation sorted, I later used this same image (on the SD card) to boot and install Armbian, so I do not think this was the case. [1] In the end the solution was simple. But first I wasted a lot of time trying to get rkdeveloptool working in Manjaro on the PBP. Only to realize it's intended to be used from a second machine to read the SPI flash via USB in maskrom mode. Anyway, lesson learned. [2] I tried to attach it but maybe it's too big.
  10. EDIT: Solution in next post (this started as a question; yeah maybe I should have split it, but whatever). Apologies if this is dumb question. I finally got my hands on some appropriate (64-bit) hardware, and ready to install software now. I have read so many threads (in Kobol Club and elsewhere), Issues (at GitHub as well as Atlassian) and I think this is solved by now (on Armbian) but cannot confirm? Official install instructions (on OpenZFS website) don't really seem applicable to Armbian (kernel headers will be different, etc.). I guess what I am asking is, do I just do something like the following: $ sudo apt install zfs-dkms zfsutils-linux And it should "just work"? Or is there more to it than that? Looks like I should make sure backports are set up beforehand, as ZFS version is significantly newer there (2.0.3 vs 0.7.12). Target device is ROCKPro64, on latest Armbian 21.02.3 Buster Current, which is kernel 5.10.21.
