Skip to content
View in the app
Armbian Community Forums
RK3288/RK3328 Legacy Multimedia Framework
Featured Replies
Is it possible to install Multimedia Framework for Armbian CLI images?
I have to run Chromium with Web GL 2.0 support and don't need Desktop things....
In my case under latest Armbian Debian CLI image I have packages not found.
root@tinkerboard:~# sudo apt install media-buster-legacy-tinkerboard --install-recommends
Reading package lists... Done
Building dependency tree... Done
E: Unable to locate package media-buster-legacy-tinkerboard
root@tinkerboard:~# sudo apt install media-buster-legacy-rk3328 --install-recommends
E: Unable to locate package media-buster-legacy-rk3328
Thanks JMCC, I have overlooked the sources listed above.
But still I have not found a repository for the package media-buster-legacy-tinkerboard itself.
I'm struggling to find the proper PPA with "chromium-browser" that would work with WebGL2 on Tinkerboard S (RK3288). Snap version does not support Web GL2.
Does anybody know the good PPA with Chromium for RK3288?
Just found this forum. Thank you @JMCC for your hard work. Anybody knows exactly which Buster legacy desktop image would work on a renegade? I have tried every one of them at https://armbian.tnahosting.net/archive/renegade/archive/ (link provided by libre.compter and that's why I tried). It appears that those images include all those at https://armbian.systemonachip.net/archive (suggested by OP). None works. If lucky, some would boot into GUI but I couldn't run sudo apt update (or upgrade), lots of error messages. I couldn't even start chromium either. Some images wouldn't even boot into GUI. Thank you.
Pretty new to Linux and single board computer. If I didn't do it right, I apologize.
  • Author
Do you have emmc or only SD card? Renegade legacy images don't get along well with SD cards (it was a problem with regulator voltages, and didn't affect all units). For example, mine worked only with certain older legacy images on SD card, but it broke somewhere around early 2019.
So do you have emmc? If so, the easiest is boot the board from a current image, and then flash legacy from it into emmc. I can teach you how to do that
If you don't have emmc, please try this image: https://armbian.tnahosting.net/archive/renegade/archive/Armbian_5.75_Renegade_Ubuntu_bionic_default_4.4.174.7z , and use the old multimedia script instead (DO NOT upgrade the kernel, use "apt-mark hold"):
Thank you, @JMCC. I do use an SD card. I guess that's why. Are you sure your link is correct? That's bionic default, no desktop version. It did try its desktop version, of course not working, lol.
I did see two buster default at the same directory. One is 4.4.184 and the other 4.4.192. Which one should I try? Older one? I assume here default means legacy? Thank you.
BTW, how to quote in this forum? I saw you guys quoted but I couldn't find how to. Sorry if this is a dump question.
Ok, I have tested the oldest buster (4.4.182) . It logs into GUI but nothing can be done. Pretty much same with 4.4.192. Is there any older version that can be used? The bionic 4.4.174 works quite well, except that the script (the old one) doesn't do anything. Still 100% CPU at 720p. In fact, chromium doesn't even provide anything better than 720p for youtube. It looks like it need to be 4.4.174 or older. Thank you.
Edited by Handy Doctor
Hello everyone, Do not use this procedure on RK322X boards, I did it and the system broke, I lost everything, I did it out of curiosity... in short, by messing up you learn.
  • Igor unpinned this topic
I Know this thread is old but i installer buster on my rk3318 box and the media-buster-legacy-rk3328 package does not exist anymore
does anyone have a archive of it
Thanks!, it works nicely, i was using a minimal image and had to install xfce then edit the media-buster-legacy-rk3328 deb to not ask for armbian-buster-desktop, i also needed mpv-legacy and got it from a github link
so far everything is working good, 4K hevc in kodi is fine but for some reason chromium in chrome://gpu says that video decoding isnt accelerated, only webgl stuff
Edited by EAZY BLACK
I have the tinkerboard rk3288, where do I find the mpv-legacy :(
perhaps someone who's more knowledgeable could update the script to work on newer versions than buster, like  bookworm or trixie?
many thanks, JMCC but I couldn't, for the life of me get it to install. After trying to install whatever armhf .deb files I could, I got stuck with 3 missing deps. After more fiddling and basically copying every possible deb file to the apt cache, somehow I made it worse. I give up for today, it's been a couple of hours after my dayjob already. Wanted to use the tinkerboard a video streamer/lite computer for the bedroom but without acceleration for youtube, netflix and even my own movies, might as well get one of those crappy android sticks. I'm affraid that without some automagic script to run it all I'm lost
this is what I succeded in getting:
The following packages have unmet dependencies:
 media-buster-legacy-tinkerboard : Depends: qtmultimedia5-examples but it is not going to be installed
                                   Depends: qtgstreamer-plugins-qt5 but it is not going to be installed
                                   Depends: kodi-rk but it is not installable
                                   Depends: mpv-legacy but it is not installable
                                   Depends: librga2 but it is not installable
After like a week of trying to make my tinkerboard rk3288 play videos I finally found the holy grail:
https://users.armbian.com/jmcc/output/
Find the latest version and install that with all his dependencies, all the dependencies are in the debian archive:
deb http://archive.debian.org/debian buster main contrib non-free
deb http://archive.debian.org/debian buster-updates main contrib non-free
deb http://archive.debian.org/debian buster-backports main contrib non-free
deb http://archive.debian.org/debian-security buster/updates main contrib non-free
deb [signed-by=/usr/share/keyrings/armbian.gpg] https://github.armbian.com/configng stable main
deb http://apt.armbian.com buster main buster-utils buster-desktop
I managed to play 4k hevc dolby atmos 5.1 movie streaming from my jellyfin server at my parents house using kodi-gbm and it worked flawlessly! I couldn't do the same with mpv yet. I hope this helps ppl with this ancient (2017) sbc.
thank you so much for the link, after trying some of the older tinkerboard .deb archives from there I was able to install one that didn't have the two missing deps eventually and, lo and behold, I could even feel the accelerated desktop from the login window, even before confirming it with the much snappier webgl aquarium test,  that jumped from about one fps to almost 60
there are still some kinks, like h264ify being installed but not doing squat (youtube is still av1 and hangs the whole system), but I'll take what I got for now
as for the SOC being 2017....I'm fully aware that like everything Asus makes, it becomes e-waste after 2 years, I could probably try to flip this board online for $1 and no one would buy it, but I still believe it should be enough for me to stream video from my NAS on my secondary TV using 5-15W, kind of like those crappy Android sticks that plug into HDMI and an extra USB port
I have yet to decide if my next SBC should be a rk3588 board or just bite the bullet and get some N100 SBC that's probably cheaper (I live in Europe, Orange Pi 5 probably goes for more than a used PS5 with all the taxes), can run anything and won't be forever stuck on whatever this  year's trending distro is
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
