December 21, 20223 yr Hi, I am struggling to get the second NIC (1Gbit) to work. The wireless and first NIC (100Mbit) works All NIC's connected I am using Armbian 22.11.0-trunk Bullseye root@rockpi-e:~# ifconfig -a eth0: flags=4098<BROADCAST,MULTICAST> mtu 1500 ether 9a:9c:84:a1:77:63 txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 41 eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 10.150.1.153 netmask 255.255.255.0 broadcast 10.150.1.255 ether 9a:9c:84:a1:77:83 txqueuelen 1000 (Ethernet) RX packets 511 bytes 40303 (39.3 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 154 bytes 14296 (13.9 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 42 lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536 inet 127.0.0.1 netmask 255.0.0.0 inet6 ::1 prefixlen 128 scopeid 0x10<host> loop txqueuelen 1000 (Local Loopback) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 wlx60fb004c1ad0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.86.37 netmask 255.255.255.0 broadcast 192.168.86.255 inet6 fe80::87c1:1dc5:ab7:6e70 prefixlen 64 scopeid 0x20<link> ether 60:fb:00:4c:1a:d0 txqueuelen 1000 (Ethernet) RX packets 4101 bytes 919466 (897.9 KiB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 747 bytes 336966 (329.0 KiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 root@rockpi-e:~# root@rockpi-e:~# nmcli connection show NAME UUID TYPE DEVICE Wired connection 2 2824d9e9-002b-3206-a9e3-56101ea54125 ethernet eth1 mesh 0f22274b-554b-47b6-899e-2ae5e1ec9e1a wifi wlx60fb004c1ad0 Armbian ethernet f8b4ca43-7e6f-464a-ab38-9c8744b0dc16 ethernet -- Wired connection 1 c7d498a6-cbdd-3daa-b1fe-c71c23dc7e70 ethernet -- root@rockpi-e:~# root@rockpi-e:~# root@rockpi-e:~# nmcli connection up c7d498a6-cbdd-3daa-b1fe-c71c23dc7e70 Error: Connection activation failed: The device could not be readied for configuration Hint: use 'journalctl -xe NM_CONNECTION=c7d498a6-cbdd-3daa-b1fe-c71c23dc7e70 + NM_DEVICE=eth0' to get more details. root@rockpi-e:~# root@rockpi-e:~# journalctl -xe NM_CONNECTION=c7d498a6-cbdd-3daa-b1fe-c71c23dc7e70 + NM_DEVICE=eth0 Journal file /var/log/journal/f5dd17308a32431b9d72c3f4257db559/system@488569ec21fd40be8b54f2a0c0f5271d-0000000000000001-0005ec5fc6f64b22.journal is truncated, ignoring file. Dec 21 17:36:07 rockpi-e NetworkManager[622]: <info> [1671640567.3994] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed') Dec 21 17:36:07 rockpi-e NetworkManager[622]: <info> [1671640567.4061] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed') Dec 21 17:36:07 rockpi-e NetworkManager[622]: <info> [1671640567.4106] device (eth0): state change: config -> failed (reason 'config-failed', sys-iface-state: 'managed') Dec 21 17:36:07 rockpi-e NetworkManager[622]: <warn> [1671640567.4252] device (eth0): Activation: failed for connection 'Wired connection 1' dmesg show: [ 1519.182778] rk_gmac-dwmac ff540000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) [ 1540.887807] rk_gmac-dwmac ff540000.ethernet eth0: no phy at addr -1 [ 1540.887850] rk_gmac-dwmac ff540000.ethernet eth0: stmmac_open: Cannot attach to PHY (error: -19) Anyone know how to solve it?
June 23, 20233 yr Have same problem Root cause - Board Version 1.21 with new NIC chip rtl8211f Solution from RADXA forum does not work.. :+( https://forum.radxa.com/t/rock-pi-e-board-version-1-21-ethhernet-not-working-in-armbian/15061/3 Dear maintainer. Pllease make special build for 1.21 board revision..
August 23, 20233 yr Having the same issue with board revision 1.21 - the 1Gbit NIC doesn't work. Unfortunately I am not versed enough to patch this myself and compile my own version. In addition to that, it may break with future updates, doesn't it? Maybe someone can implement this in the main repository so it will work for all devices? Edited August 23, 20233 yr by FabulousGee Added more information
July 15, 20242 yr I also have the problem that the 1000BaseT interface end0 cannot be activated on the Rock Pi E. 😞 I was hoping to solve the problem with the overlay mentioned in the previous post. However, the application of the command does not work for me. Unfortunately, I have no experience with this "overlay" technology, so I can only type in the commands and hope for success. 😉 me@myhost:~$ sudo armbian-add-overlay rk3328-r8211f.dts [sudo] password for me: Compiling the overlay Error: rk3328-r8211f.dts:7.1-2 syntax error FATAL ERROR: Unable to parse input tree Error compiling the overlay Any suggestions?
November 24, 20241 yr That overlay did import fine for me, but still no luck, so currently im using older build whit older kernel (Armbian_24.5.3_Rockpi-e_bookworm_current_6.6.36_minimal) that works whit frozen updates. Edited November 24, 20241 yr by maigonis
