October 16, 20241 yr 2 hours ago, firepower said: i like to make a bootable micro SDcard with the Vontar H618 Android 12 firmware and see if it would boot on the Tanix Tx6. Use Disks to make an image and restore to sdcard? You can try it but it may fail to boot android for many reasons. When i finally boot my Z1 h313 box with Armbian i made an eMMC backup from a a second Z1 with android, using dd and i tried to restore it to my bricked Z1 device . however when i restore the image Z1 device failed to boot and when i investigate the reason i realize that for some reason gpt partition information was lost on restored device. Chinese manufacturers use common android images for their products, They just customize the logo and boot boot video and some other information including devices firmwares wifi/bt/vfd however in some cases they verify some keys for their boxes on android / vendor partition, and if you try to use unofficial or different manufacturer image does not boot. You can burn a downloaded android image to sd card as startup using PhoenixCard. BUT... When i tried by burning a downloaded firmware image for Transpeed 8k (H618.apollo-p3.T-H618_100M_12_FD650.2023.09.13.17.20.img) using (PhoenixCard.v4.2.4 / Startup ) it stayed on Transpeed logo for Ever. When i have the time, I will try to do it and with Vontar image i download (H618.apollo-p16.VONTAR_H618_100M_12_FD650.2024.05.20.12.40.img) but i believe the the result will be the same because these images are almost identical vontar/transpeed except (logos ) i decompose it both NOTE: If you use PhoenixCard please take care because if you choose product you may erase your eMMC on destination tv-box. Edited October 16, 20241 yr by rafman
October 17, 20241 yr Quote Can someone with a Transpeed 8k618-t measure the 32KHz clock with a Oscilloscope? The 32Khz fanout is routed to PG10 pin on the SOC and connected to the LPO pin of the WiFi/BT chip. @Nick A Vontar H618 HK6334Q this is from data sheet: "Pin 24 LPO External Low Power Clock input (32.768KHz)" measured with Owon HDS2202S hand held Oscilloscope. its 32.768KHz NOT 32kHz AP6330.pdf Edited October 17, 20241 yr by firepower
October 17, 20241 yr @firepower is this the xtal that has 37.400 writen? can you add a picture of it?
October 17, 20241 yr No that Xtal is 37.4MHz or 26MHz used to generate the 2.4 and 5GHz radio fequency. (If no Xtal is used it be using internal oscillator or 24MHz from H618 cpu Xtal). The Low Power Clock, LPO is used to Clock the wifi chip when off/sleep and turn wifi and bluetooth on and off, 3 clk pulse after the voltage rails are turned on or off. When on it uses high speed clock from Xtal. See Page 17 of datasheet. Its Input Pin 24 of Wifi/BT chip, clk comes from H618/H616 arm CPU. Pin 24 LDO is marked with Pink dot. Edited October 19, 20241 yr by firepower
October 19, 20241 yr On 10/10/2024 at 7:43 AM, rafman said: @MMorales With my Compiled version of @Nick A github trunk with 6.7.12 kernel. I don't have problems except (Bluetooth). WiFi works and connects to my router. CPU Temp Sensor Works. OpenVfd is working. (with downloaded headers for 6.7.12) Sound is working LAN is Working. HDMI is working. Video (MPV with hardware Acceleration) seems to work Remote IR is working (with above .toml file and ir-keytables) Finally Only the BlueTooth is not Working. Hello Rafman, did you get MPV working for the first time with Linux 6.7.12? Or did you see it with an earlier Linux too? Which Debian or Ubuntu did you build? What are the most critical linux modules and debian packages, for hardware video acceleration? Thank you!
October 19, 20241 yr I using build 240909 with Kernel 6.9.12 and edge ubuntu noble and i do not have hardware accelerated video and no Blue Tooth. Xtal usually alway measured in MHz, except for "clock" Xtal used in clocks and watches. 32.678 kHz size 3x8mm Edited October 19, 20241 yr by firepower
October 19, 20241 yr 8 hours ago, robertoj said: Hello Rafman, did you get MPV working for the first time with Linux 6.7.12? Or did you see it with an earlier Linux too? Which Debian or Ubuntu did you build? What are the most critical linux modules and debian packages, for hardware video acceleration? Thank you! Hello, i didn't do something special with MPV on Bookworm 6.7.12 kernel because i see that h264 video playback ((h264 / mp4)) was smooth and CPU utilization very low. For this reason i write above --> Video (MPV with hardware Acceleration) seems to work. I have Bookworm 6.7.12 on my Transpeed8k-t tv box and MPV works fine with kernel 6.7.12. I also have tested video playback with MPV in various H313 tv-boxes with Armbian (e.g Z1 and Q1) with Kernel 6.6.44 but video playback sucks and i used this experimental tutorial in order to watch acceptable (h264 / mp4) video playback (On bookworm 6.6.44 it makes significant difference in CPU utilization on h264 video playback). GPU of H618 and H313 is the same (ARM Mali-G31 MP2) You can read the experimental tutorial bellow (and what modules are used) : I don't know if above kernel patches are applied to 6.7.12 but video decoding seems to work much better (probably due to ffmpeg version ?) Also on my transpeed 8k tv-box (H618, kernel 6.7.12) I have compiled Freetux Tv that uses libVLC (https://github.com/freetuxtv/freetuxtv) and i am able to watch ip tv channels around the world smoothly. In the above image freetux tv uses 5.08 % CPU Utilization however in other channels may increase depending the video codec used. Edited October 19, 20241 yr by rafman
October 23, 20241 yr On 10/10/2024 at 3:17 AM, MMorales said: I configured a mini remote for switching led display info and control the brightness Hi, can you share with me how you could do that? Thanks!
October 23, 20241 yr @dale its shared on this topic. but you have previously the openvfd working. read this two posts:
October 23, 20241 yr @dale yes, but is so personal for my needs. maybe its a little confusing to adapt to your needs. anyway i post it i use /tmp/vfd.txt like a bridge bewting app for use the display. so i can send text from any other script i load. in this scrpit im waiting for a keypress (remote) to increase or decrease the brightness, its so dirty i know but i was made as i needed so ugly. import re import os import time import subprocess import psutil import threading import keyboard from animaciones import * texto = "" last_short_txt = "@@" max_caracteres = 4 velocidad = 0.2 tiempo_ultimo_texto = int(time.time()) f = "/tmp/vfd.txt" vueltas = 1 brillo = "0" brillo_standby = "0" brillo_actual = "8" def escribe(t): with open("/tmp/vfd.txt", 'w') as file: file.write(t) def on_function_key(event): if event.name.startswith('f') or event.name == "[" or event.name == "]" : e = event.name escribe("**"+e) def listen_key(): keyboard.on_press(on_function_key) # Mantiene el script en ejecución keyboard.wait('esc') # Puedes salir presionando Esc hilo = threading.Thread(target=listen_key) hilo.start() print("Experando contenido en",f,"para mostrar en el display") def read_file(filename = f): if not os.path.isfile(filename): return "" with open(filename, 'r') as f: texto = re.sub(r'(\r\n|\n|\r)', '', f.read()).strip() if texto == "" : texto = " " os.remove(filename) print(texto) return texto def cerrar_proceso(nombre): """Cierra el proceso dado su nombre.""" for proc in psutil.process_iter(['name']): if proc.info['name'] == nombre: proc.terminate() # Termina el proceso proc.wait() # Espera a que el proceso termine def pinta(texto_a_enviar): global brillo_actual cerrar_proceso("OpenVFDService") if brillo != brillo_actual: brillo_actual = brillo proceso = subprocess.Popen(['OpenVFDService', '-s', texto_a_enviar,'-b',brillo]) else: proceso = subprocess.Popen(['OpenVFDService', '-s', texto_a_enviar]) while True: time.sleep(1) newtext = read_file() if newtext != "" : if(newtext[:2] == "**"): if(newtext == "**]"): if int(brillo_standby) < 7: brillo = brillo_standby = str(int(brillo_standby) + 1) if(newtext == "**["): if int(brillo_standby) > 0: brillo = brillo_standby = str(int(brillo_standby) - 1) texto = "c "+ brillo_standby +"}" tiempo_ultimo_texto -= 10 vueltas = 1 elif(newtext[:2] == "##"): ramdom_combo(int(newtext[2:4])) else: texto = newtext tiempo_ultimo_texto = int(time.time()) + 60 brillo = "7" else: if tiempo_ultimo_texto + 5 < int(time.time()): tiempo_ultimo_texto = int(time.time()) texto =f' {round(psutil.cpu_percent()):02}' brillo = brillo_standby if vueltas % 10 == 0:ramdom_combo() vueltas += 1 if texto != "": if len(texto) > max_caracteres: texto_completo = " "*max_caracteres + texto + " "*max_caracteres longitud_texto = len(texto_completo) for i in range(longitud_texto - max_caracteres + 1): texto_a_enviar = texto_completo[i:i + max_caracteres] pinta(texto_a_enviar) time.sleep(velocidad) else: if last_short_txt == texto: continue last_short_txt = texto pinta(texto) Edited October 23, 20241 yr by MMorales
October 23, 20241 yr @MMoralesthank you! I'm thinking of a way to integrate it into openvfd driver module. But it is a bit complicated.
October 23, 20241 yr @dale i saw in the source of OpenVFDService the is already a pipe from a file like i want (like my vft.txt) but not working for me , thats why i made my own service. Edited October 23, 20241 yr by MMorales
October 25, 20241 yr @MMorales @dale on Jefflessard openvfd version setting brightness its as easy as write number to /sys/class file, no need other service :)
November 3, 20241 yr Hi there, It has been a while. I just tried @Nick A latest release https://github.com/NickAlilovic/build/releases/tag/20241007 on my Transpeed 8K Ultra HD with H618 and everything that I need works. I was able to flash everything from the MicroSD onto the internal EMMC storage and it boots. Wifi is working and Bluetooth is working. I installed Klipper on it and now I can control one of my 3d printers with this little SBC. I have the 4GB Ram version with 128GB EMMC. I think you did it @Nick A Cheers, Heiko
November 3, 20241 yr Really cool @heiko910! Do you have a link to your box? What version of Android did it come with? Did you just move the required firmware files to make wifi and BT work? Or did you boot into Android first?
November 4, 20241 yr @heiko910 My SBC that I already use for Klipper is RK3318 version (H96 max v11) I bought after my Tanix (that use nearly same chip as transpeed speed). Before posting here Im already give up with Tanix as need to open box set up serial display.. so I tought is easier just buy one again that already can use. While waiting new one or after I success with last one (I forgot already), I have spare time and have CP2102 around also (from my previous hobby building quadcopter with STM chip) but I really dont want solder anything (too small for my old eyes, lol) I just slip the stripped wire to the hole TX RX Ground and use tape to hold it in place and try to see whether it send data to computer.. voila I get data from this little machine, and try to asked here.Then @Nick A help and all worked as I needed :) Right now Im still building (mod/designing) CoreXY from used Ender 5 then may be my Tanix got use :)
November 4, 20241 yr @Willx I don't remember what android it was running originally. I used this release from @Nick A https://github.com/NickAlilovic/build/releases/tag/20241007 flashed it onto a microsd card, stuck into the microsd card slot. It boots right into Armbian with Wifi and Bluetooth working. I than used armbian config that you can start from the GUI and flashed the whole thing onto the device's own Emmc storage. Now I don't need the SD-Card anymore. The Model I have is the 8k Transpeed Ultra HD https://www.aliexpress.us/item/3256805753177410.html?spm=a2g0o.productlist.main.49.4e2cvvt0vvt0XU&algo_pvid=498e6e43-548c-42f9-a41e-5907b1b29398&algo_exp_id=498e6e43-548c-42f9-a41e-5907b1b29398-24&pdp_npi=4%40dis!USD!47.83!20.56!!!338.53!145.57!%402101c5b217306953159191252ed08f!12000034941020300!sea!US!1721927299!X&curPageLogUid=aksBgGStl7UU&utparam-url=scene%3Asearch|query_from%3A it has 4gb ram and 128gb rom.
November 4, 20241 yr @heiko910 got it. I have the transpeed 4gb/32gb version and tried the same build but couldn't get wifi or bluetooth working even after moving over the firmware files mentioned in the first page and the recent pages discussing BT. Will try ordering the same unit in case there's a variation there that's more compatible. Thanks for confirming!
November 5, 20241 yr @Willx Mine not working also 1st, need to open the box and photo the chip.. then seek in forum, Fortunately my wifi chip already known on rockchip forum then ppl here can help to connect it on the build. Bluetooth Im not aware as Im not using it atm
November 5, 20241 yr Hello People who are enjoying h264 acceleration, can you share the result of: $ uname -r $ mpv -V $ ffmpeg -V $ apt show mpv $ apt show ffmpeg (or ffmpeg-v4l2request) command line needed to start playing with mpv
November 6, 20241 yr still trying to get my bluetooth working on Vontare H618. could not power it on. renaming from uppercase filename to lower case allowed me to turn it on. BCM4334B0.hcd to bcm4334b0.hcd still unable to discover and connect. log of dmesg | grep -i bluetooth when uppercase BCM4334B0.hcd it found firmware patch ,but bluetooth power on failed Quote firepower9966@transpeed-8k618-t:~$ dmesg | grep -i bluetooth [ 9.628290] Bluetooth: Core ver 2.22 [ 9.640097] NET: Registered PF_BLUETOOTH protocol family [ 9.640120] Bluetooth: HCI device and connection manager initialized [ 9.640154] Bluetooth: HCI socket layer initialized [ 9.640163] Bluetooth: L2CAP socket layer initialized [ 9.640194] Bluetooth: SCO socket layer initialized [ 9.704117] Bluetooth: HCI UART driver ver 2.3 [ 9.704149] Bluetooth: HCI UART protocol H4 registered [ 9.704155] Bluetooth: HCI UART protocol BCSP registered [ 9.704288] Bluetooth: HCI UART protocol LL registered [ 9.704296] Bluetooth: HCI UART protocol ATH3K registered [ 9.704339] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 9.704520] Bluetooth: HCI UART protocol Intel registered [ 9.704642] Bluetooth: HCI UART protocol Broadcom registered [ 9.704681] Bluetooth: HCI UART protocol QCA registered [ 9.704687] Bluetooth: HCI UART protocol AG6XX registered [ 9.704721] Bluetooth: HCI UART protocol Marvell registered [ 10.072754] Bluetooth: hci0: BCM: chip id 68 [ 10.075160] Bluetooth: hci0: BCM: features 0x0f [ 10.098493] Bluetooth: hci0: BCM4334B0 [ 10.098514] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000 [ 10.102685] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch [ 16.029338] Bluetooth: hci0: BCM: features 0x0f [ 16.052863] Bluetooth: hci0: BCM4334B0 37.4MHz Class1.5 Samsung Note8-1675 [ 16.052894] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1718 [ 19.156467] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 19.156497] Bluetooth: BNEP filters: protocol multicast [ 19.156518] Bluetooth: BNEP socket layer initialized [ 19.164613] Bluetooth: MGMT ver 1.22 [ 21.348030] Bluetooth: hci0: Opcode 0x0c03 failed: -110 [ 37.763098] Bluetooth: RFCOMM TTY layer initialized [ 37.763146] Bluetooth: RFCOMM socket layer initialized [ 37.763175] Bluetooth: RFCOMM ver 1.11 [ 64.071207] Bluetooth: hci0: Opcode 0x0c03 failed: -110 firepower9966@transpeed-8k618-t:~$ sudo bluetoothctl power on [sudo] password for firepower9966: Failed to set power on: org.bluez.Error.Failed when lowercase bcm4334b0.hcd not found firmware patch but bluetooth power on succeeded Quote firepower9966@transpeed-8k618-t:~$ dmesg | grep -i bluetooth [ 9.555970] Bluetooth: Core ver 2.22 [ 9.560198] NET: Registered PF_BLUETOOTH protocol family [ 9.560221] Bluetooth: HCI device and connection manager initialized [ 9.560243] Bluetooth: HCI socket layer initialized [ 9.560251] Bluetooth: L2CAP socket layer initialized [ 9.560284] Bluetooth: SCO socket layer initialized [ 9.997436] Bluetooth: HCI UART driver ver 2.3 [ 9.997466] Bluetooth: HCI UART protocol H4 registered [ 9.997471] Bluetooth: HCI UART protocol BCSP registered [ 9.997573] Bluetooth: HCI UART protocol LL registered [ 9.997579] Bluetooth: HCI UART protocol ATH3K registered [ 9.997610] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 9.997773] Bluetooth: HCI UART protocol Intel registered [ 9.997881] Bluetooth: HCI UART protocol Broadcom registered [ 9.997917] Bluetooth: HCI UART protocol QCA registered [ 9.997922] Bluetooth: HCI UART protocol AG6XX registered [ 9.997952] Bluetooth: HCI UART protocol Marvell registered [ 10.362523] Bluetooth: hci0: BCM: chip id 68 [ 10.365074] Bluetooth: hci0: BCM: features 0x0f [ 10.388518] Bluetooth: hci0: BCM4334B0 [ 10.388539] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000 [ 10.388747] Bluetooth: hci0: BCM: firmware Patch file not found, tried: [ 10.388753] Bluetooth: hci0: BCM: 'brcm/BCM4334B0.transpeed,8k618-t.hcd' [ 10.388758] Bluetooth: hci0: BCM: 'brcm/BCM4334B0.hcd' [ 10.388763] Bluetooth: hci0: BCM: 'brcm/BCM.transpeed,8k618-t.hcd' [ 10.388767] Bluetooth: hci0: BCM: 'brcm/BCM.hcd' [ 19.296742] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 19.296776] Bluetooth: BNEP filters: protocol multicast [ 19.296810] Bluetooth: BNEP socket layer initialized [ 19.308874] Bluetooth: MGMT ver 1.22 [ 37.660228] Bluetooth: RFCOMM TTY layer initialized [ 37.660268] Bluetooth: RFCOMM socket layer initialized [ 37.660295] Bluetooth: RFCOMM ver 1.11 firepower9966@transpeed-8k618-t:~$ sudo bluetoothctl power on [sudo] password for firepower9966: Changing power on succeeded firepower9966@transpeed-8k618-t:~$ think patch / filename needs to be checked or matched. Edited November 6, 20241 yr by firepower
November 6, 20241 yr Hello Everybody!! I'm new here, just got my Transpeed 8k tv box in the 4G/64G config. I managed to boot to desktop with this image: https://github.com/NickAlilovic/build/releases/download/20241007/Armbian-unofficial_24.11.0-trunk_Transpeed-8k618-t_bookworm_edge_6.10.10_xfce_desktop.tar.gz The box boots up fine, asks a few things, then I have the desktop and everything (Ethernet, HDMI, keyboard, mouse) seems to be working. However, when I play a youtube video (1080p), the playback is a bit jerky, when I play it in full screen mode, it brings the system to its knees - even the mouse pointer slows down.... I'm not a Linux guru by any means, but I work with it comfortably in the command line. I haven't compiled an operating system on my own before, but I am willing to learn. I have read through this forum to get a general picture as to what to expect of this piece of hardware, and I'm happy with what I read. I would like to use this box as a media box (watching movies, browsing...) or as a server - I'll see. I'm happy to experiment, happy to test, would love to participate in taming this and maybe other similar boards. I just need a bit of help starting out. I'd like to post a few pics of my board for reference, but the upload keeps failing - maybe because I'm new here.. Anyway, if someone has an idea how to fix this speed issue, that would be awesome.
November 6, 20241 yr @robertoj Although it is NOT working for me, I'm still posting my results - we might find a pattern...: mc@transpeed-8k618-t:~/Desktop$ uname -r 6.10.10-edge-sunxi64 mc@transpeed-8k618-t:~/Desktop$ mpv -V mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects built on UNKNOWN FFmpeg library versions: libavutil 57.28.100 libavcodec 59.37.100 libavformat 59.27.100 libswscale 6.7.100 libavfilter 8.44.100 libswresample 4.7.100 FFmpeg version: 5.1.4-0+deb12u1.v4l2request mc@transpeed-8k618-t:~/Desktop$ ffmpeg -V ffmpeg version 5.1.4-0+deb12u1.v4l2request Copyright (c) 2000-2023 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr --extra-version=0+deb12u1.v4l2request --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libv4l2 --enable-v4l2-request --enable-v4l2-m2m --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared libavutil 57. 28.100 / 57. 28.100 libavcodec 59. 37.100 / 59. 37.100 libavformat 59. 27.100 / 59. 27.100 libavdevice 59. 7.100 / 59. 7.100 libavfilter 8. 44.100 / 8. 44.100 libswscale 6. 7.100 / 6. 7.100 libswresample 4. 7.100 / 4. 7.100 libpostproc 56. 6.100 / 56. 6.100 Unrecognized option 'V'. Error splitting the argument list: Option not found mc@transpeed-8k618-t:~/Desktop$ apt show mpv Package: mpv Version: 0.35.1-4 Priority: optional Section: video Maintainer: Debian Multimedia Maintainers <debian-multimedia@lists.debian.org> Installed-Size: 3,346 kB Depends: libarchive13 (>= 3.4.0), libasound2 (>= 1.0.27), libass9 (>= 1:0.15.0), libavcodec59 (>= 7:5.0), libavdevice59 (>= 7:5.0), libavfilter8 (>= 7:5.0), libavformat59 (>= 7:5.0), libavutil57 (>= 7:5.1), libbluray2 (>= 1:0.2.2), libc6 (>= 2.34), libcaca0 (>= 0.99.beta20), libcdio-cdda2 (>= 10.2+2.0.0), libcdio-paranoia2 (>= 10.2+2.0.0), libcdio19 (>= 2.1.0), libdrm2 (>= 2.4.105), libdvdnav4 (>= 4.1.3), libegl1, libgbm1 (>= 17.1.0~rc2), libjack-jackd2-0 (>= 1.9.10+20150825) | libjack-0.125, libjpeg62-turbo (>= 1.3.1), liblcms2-2 (>= 2.6), liblua5.2-0 (>= 5.2.4), libmujs2 (>= 1.0.7), libpipewire-0.3-0 (>= 0.3.50), libplacebo208 (>= 4.208.0), libpulse0 (>= 0.99.4), librubberband2 (>= 3.1.2+dfsg0), libsdl2-2.0-0 (>= 2.0.12), libsixel1 (>= 1.10.3), libswresample4 (>= 7:5.0), libswscale6 (>= 7:5.0), libuchardet0 (>= 0.0.1), libva-drm2 (>= 1.1.0), libva-wayland2 (>= 1.3.0), libva-x11-2 (>= 1.0.3), libva2 (>= 2.2.0), libvdpau1 (>= 0.2), libvulkan1 (>= 1.2.131.2), libwayland-client0 (>= 1.20.0), libwayland-cursor0 (>= 1.15.0), libwayland-egl1 (>= 1.15.0), libx11-6 (>= 2:1.2.99.901), libxext6, libxinerama1 (>= 2:1.1.4), libxkbcommon0 (>= 0.5.0), libxpresent1, libxrandr2 (>= 2:1.4.0), libxss1, libxv1, libzimg2 (>= 0.3.1), zlib1g (>= 1:1.1.4) Recommends: xdg-utils, yt-dlp Suggests: libcuda1 Homepage: https://mpv.io/ Tag: implemented-in::c, interface::graphical, interface::x11, role::program, sound::player, uitoolkit::sdl, uitoolkit::xlib, use::playing, works-with-format::mp3, works-with-format::oggtheora, works-with-format::oggvorbis, works-with-format::wav, works-with::audio, works-with::video, x11::application Download-Size: 1,138 kB APT-Manual-Installed: yes APT-Sources: http://deb.debian.org/debian bookworm/main arm64 Packages Description: video player based on MPlayer/mplayer2 mc@transpeed-8k618-t:~/Desktop$ apt show ffmpeg Package: ffmpeg Version: 7:5.1.6-0+deb12u1 Priority: optional Section: video Maintainer: Debian Multimedia Maintainers <debian-multimedia@lists.debian.org> Installed-Size: 2,593 kB Depends: libavcodec59 (>= 7:5.0), libavdevice59 (>= 7:5.0), libavfilter8 (>= 7:5.1), libavformat59 (>= 7:5.1), libavutil57 (>= 7:5.1), libc6 (>= 2.35), libpostproc56 (>= 7:5.0), libsdl2-2.0-0 (>= 2.0.12), libswresample4 (>= 7:5.1), libswscale6 (>= 7:5.0) Suggests: ffmpeg-doc Homepage: https://ffmpeg.org/ Tag: implemented-in::c, interface::commandline, interface::graphical, interface::x11, network::server, role::program, role::shared-lib, scope::utility, uitoolkit::sdl, use::compressing, use::converting, use::playing, works-with::audio, works-with::video, x11::application Download-Size: 1,803 kB APT-Sources: http://deb.debian.org/debian bookworm/main arm64 Packages Description: Tools for transcoding, streaming and playing of multimedia files
November 6, 20241 yr Vitya... you should only have ffmpeg-v4l2request (ffmpeg with the v4l2-request patches), and NOT the Debian official ffmpeg (without the patches). And your "apt show ffmpeg" shows that you may have BOTH.
