November 3, 20232 yr sudo add-apt-repository ppa:liujianfeng1994/rockchip-multimedia [sudo] contraseña para eduardo: Repository: 'deb https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu/ bookworm main' Description: This ppa provides a package rockchip-multimedia-config to config your system ready for multimedia acceleration. sudo apt install rockchip-multimedia-config Then you're good to go. More info: https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia Adding repository. Press [ENTER] to continue or Ctrl-c to cancel. Adding deb entry to /etc/apt/sources.list.d/liujianfeng1994-ubuntu-rockchip-multimedia-bookworm.list Adding disabled deb-src entry to /etc/apt/sources.list.d/liujianfeng1994-ubuntu-rockchip-multimedia-bookworm.list Adding key to /etc/apt/trusted.gpg.d/liujianfeng1994-ubuntu-rockchip-multimedia.gpg with fingerprint 0B2F0747E3BD546820A639B68065BE1FC67AABDE Obj:1 http://deb.debian.org/debian bookworm InRelease Des:3 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB] Des:5 http://security.debian.org bookworm-security InRelease [48.0 kB] Des:6 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB] Obj:2 https://cli.github.com/packages stable InRelease Ign:8 https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm InRelease Obj:7 http://armbian.chi.auroradev.org/apt bookworm InRelease Des:4 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium InRelease [3 843 B] Des:9 http://deb.debian.org/debian bookworm-backports/main arm64 Packages.diff/Index [63.3 kB] Ign:10 https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu bookworm InRelease Des:11 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb).diff/Index [48.8 kB] Des:12 http://deb.debian.org/debian bookworm-backports/main all Contents (deb).diff/Index [63.6 kB] Err:13 https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release 404 Not Found [IP: 185.125.190.52 443] Des:14 http://security.debian.org bookworm-security/main arm64 Packages [92.9 kB] Des:15 http://deb.debian.org/debian bookworm-backports/main arm64 Packages T-2023-11-02-0803.41-F-2023-11-02-0203.47.pdiff [16.4 kB] Des:15 http://deb.debian.org/debian bookworm-backports/main arm64 Packages T-2023-11-02-0803.41-F-2023-11-02-0203.47.pdiff [16.4 kB] Err:16 https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu bookworm Release 404 Not Found [IP: 185.125.190.52 443] Des:17 https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs vscodium/main arm64 Packages [1 039 B] Des:18 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) T-2023-11-02-0803.41-F-2023-11-02-0803.41.pdiff [85.2 kB] Des:18 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) T-2023-11-02-0803.41-F-2023-11-02-0803.41.pdiff [85.2 kB] Des:19 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) T-2023-11-02-0203.47-F-2023-11-02-0203.47.pdiff [27.2 kB] Des:19 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) T-2023-11-02-0203.47-F-2023-11-02-0203.47.pdiff [27.2 kB] Leyendo lista de paquetes... Hecho E: El repositorio «https://ppa.launchpadcontent.net/liujianfeng1994/panfork-mesa/ubuntu bookworm Release» no tiene un fichero de Publicación. N: No se puede actualizar de un repositorio como este de forma segura y por tanto está deshabilitado por omisión. N: Vea la página de manual apt-secure(8) para los detalles sobre la creación de repositorios y la configuración de usuarios. E: El repositorio «https://ppa.launchpadcontent.net/liujianfeng1994/rockchip-multimedia/ubuntu bookworm Release» no tiene un fichero de Publicación. N: No se puede actualizar de un repositorio como este de forma segura y por tanto está deshabilitado por omisión. N: Vea la página de manual apt-secure(8) para los detalles sobre la creación de repositorios y la configuración de usuarios. eduardo@orangepi5-plus:~$
November 3, 20232 yr Author neofetch eduardo@orangepi5-plus ---------------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.8.2) aarch64 ███████████████████████ Host: Orange Pi 5 Plus ▄▄██ ██▄▄ Kernel: 5.10.160-legacy-rk35xx ▄▄██ ███████████ ██▄▄ Uptime: 4 hours, 17 mins ▄▄██ ██ ██ ██▄▄ Packages: 1521 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Resolution: 1920x1080 ▄▄██ █████████████ ██▄▄ DE: Cinnamon 5.6.8 ▄▄██ ██ ██ ██▄▄ WM: Mutter (Muffin) ▄▄██ ██ ██ ██▄▄ WM Theme: cinnamon (Numix) ▄▄██ ██ ██ ██▄▄ Theme: Numix [GTK2/3] ▄▄██ ██▄▄ Icons: Numix [GTK2/3] ███████████████████████ Terminal: gnome-terminal █ █ █ █ █ █ █ █ █ █ █ CPU: (8) @ 1.800GHz Memory: 4884MiB / 15718MiB I dont see the gpu in the neofetch output
November 7, 20232 yr Author I tried a lot of things, but could not activate the gpu. Installed Joshua Reik Ubuntu and now everything seems to work fine. I would prefer to use armbian, but have to stay at ubuntu for now.
November 7, 20232 yr Solution He needed to use Jammy and not bookworm. The desktop choice has nothing to do with it. The AmazingFate repo only works on Jammy. That is what JashuaRiek is using too.
