- Gaming experience with Orange Pi 5 (RK3588) on Armbian
Awesome. Let me try that. Had to reinstall my SBC cause I done a stupid thing, removed my boot partition. Wanted to format another sd-card of the same size and didn't look well enough. Installing wine and all the others now, will try with all you've mentioned. Big thank you, I'm in the hospital with little to do, and I miss Farming Simulator to make the time pass quickly. Thank you for the great work.
@KhanhDTPHi. First off, great job with all these games. Would it be possible to test FarmingSimulator 17 please? I got the game working, but the image is offset a lot. Mouse also. I needed to set wine to win7 and use the x86 FarmingSimulator2017.exe in the x86 folder. I've got no clue how to fix this issue, maybe you have more tips and tricks. In windowed mode I can see everything, but mouse goes out of the window and stops working. Otherwise it looks playable if it was outputting correctly. Cheers, NicoD
Video : Pi-Apps on Armbian on the Radxa Dragon Q6A
I tried FEX-emu, but on our devices it's slower. It is optimised for snapdragon while box64 is more optimised for the lower-end SBC ARM-SOC. Here a video I once made about it. Things have changed a lot, fex-emu has matured at lot in this time. I didn't know it was build for steam back then so didn't test that. Also have no steam games that would run.- Hard Brick After Failed Armbian Upgrade (Jammy to Noble)
Here the link to the video. Thanks to Mike from Mekotronics. https://mekotronics.wetransfer.com/downloads/9a21fbbbd8123b75cb5119d632bb565020251208034519/a7c7d3?t_lsid=dd63b65e-c41d-4c4e-81ea-66eea92954d0&t_network=link&t_rid=YXV0aDB8NjE4ZTI0ZjkyMDYzZGYwMDY5Y2FhMmFh&t_s=download_link&t_ts=1765165519- Hard Brick After Failed Armbian Upgrade (Jammy to Noble)
Hi. Forgive me for my memory is very bad. There is a video somewhere on how to unbrick mekotronics Rockchip devices. I've been searching for it the last half hour but can't find it. I know I've got it on my pc somewhere. Email mekotronics and they'll give you a link to it. If I find it I'll share it.- Armbian images don't boot on my 2 M5
That's probably the boot partition in fat32. You can't read linux partitions in Windows without tools. So it's normal you can't read an armbian image in windows since it doesn't use fat partitions. Why it doesn't boot is another case. I would try to build my own image with either legacy or mainline kernel. I don't have the board so no idea what works on it.- Desktop for odroid xu4?
It is nog normal desktop images are not available. You can always install a desktop to server images. I use taskset for desktops that need a lot of dependancies. sudo apt install taskset sudo taskset For the xu4 there should be not much difference with the armbian desktop images except for the background image.- Video : Armbian-gamingX86 / A tool to install Steam, PPSSPP, Retropie and Xonotic on Armbian Jammy/Noble X86
Hi all. In this video I show how to use armbian-gamingX86. A script to install Steam, PPSSPP, Retropie and Xonotic on Armbian Jammy/Noble X86. Here link to armbian-gamingX86 : https://github.com/NicoD-SBC/armbian-gamingX86 Here my video about it. Cheers, NicoD
