February 16, 20242 yr Hi, I've been running Armbian legacy server on my 5+ for a month now. I had trouble initially with my EMMC not booting, but I discovered, I had to wipe the SPI Nor then using Armbian config to flash it, then write to EMMC. When a new version of Armbian comes out for the 5+ and it may be a 6.8 kernel build, will I need to re-flash the SPI before I can install the newer version of Armbian (or another image from that's not Armbian?) before updating the EMMC. I found the steps on the Radxa site insightful for a general overview of SPI Nor and flashing (I understand it not an OPi5 x board), but it's not clear to me if a different OS will need the SPI updated due to different bootloader etc ..... https://docs.radxa.com/en/rock5/lowlevel-development/bootloader_spi_flash
