Skip to content
View in the app
Armbian Community Forums
Featured Replies
  • Author
2 hours ago, Obmor said:
It worked! thank you very much! There are already 2 WLANs: WLAN0 and WLAN1 hmm..
That's because usually these drivers are suited for Android and they expose by default a "regular" interface and a "P2P" interface for direct connection.
Just use wlan0, or there should be a module option to disable the p2p interface.
11 hours ago, MaxT said:
he above linked GitHub repo contains exactly what was asked - brief overview of the build system with links to documentation. Have you read those?
Yes, I read it, but I can't find the information I needed in the repo.
 Looking at the logs of a custom image I made, I found the hash of the u-boot version used, and now the patches worked without problems
I also found some information about how I should configure the kernel
@jock
19 часов назад, jock сказал:
here it is a module for kernel 6.6.67 and rtl8189es.
Hi!
Do I understand correctly that when changing/updating the kernel version, the driver will not load and you will need to rebuild the module?
  • Author
Yes, it is correct. But I will enable the rtl8189es module in the armbian mainline so forthcoming kernels will have the module compiled in. Just not update the kernel in the meantime.
@jock
24.12.2024 в 03:04, jock сказал:
Try to put this file: rk322x-led-conf9.dtbo
in /boot/dtb/overlay directory, then append led-conf9 to overlays line in /boot/armbianEnv.txt and see from dmesg if your wifi device gets detected.
Send the dmesg log anyway, it is the first step to understand what is wrong.
By the way, you don't have to apply this patch. You just need to install the driver.
@jock
Do you mean the led-conf9 device tree overlay? Does the wifi works even without this overlay applied?
So sure. Works without overlay
There is still such a problem. When the device reboots, the USB Ethernet adapter does not initialize. You have to pull it out and put it in again. When the device is turned off, there is no such thing.
Hello!
Few days I try to config small printserver with rk3239 box.
It use "v24.11.1 for rk322x-box running Armbian Linux 6.6.63-current-rockchip" image (tested with older images too).
Looks everething works fine. But one problem with printing app.
I try to use hplip-printer-app as snap pkg. https://github.com/OpenPrinting/hplip-printer-app
App start, but if try to connect to http://IP:8000 it crash with "Segmentation fault"
I thought maybe some app bug, but I had make some tests with amlogic S905X, S905X3 boxes and raspi 4b. There apps works fine.
I not understand why rk box crashes?
On 12/22/2024 at 12:13 AM, MattWestB said:
@Asriel Nguyen The board looks very not RK3228 like but your lsusb is saying it one in maskrom mode so shall being one but no initial booltloader in the eMMC = shall booting Multitool / Armbian OK from SD-Card (but not direct from USB sticks).
Only PM is if the card reader is on the standard address or being on other then its not working.
Do you have some high res picture of top and bottom of the PCB then cant see the small components and printing ?
Edited December 22 by MattWestB
Hey, sorry for late response
Here are the images
https://alist.genshin.gay/rk3229
Also,
I did solder an sd slot but it seems to be boot looping (the flash drive flickering). That's just my guess
Hello @jock, hope you're ok!
Seven months ago, I successfully installed Armbian (Armbian_community_24.5.0-trunk.563_Rk322x-box_bookworm_current_6.6.30_minimal) and RetroPie on my RK3229 TV box (MXQ-4K-5G) using an 8 GB USB drive. Following the instructions from this forum, the entire compilation process took me approximately 15 hours. I saved everything as an IMG file using Win32DiskManager.
NOTE : I’m aware that the internal Wi-Fi module (SV6256P, which is my internal wifi module) doesn’t work with this setup, but I know that the Armbian Legacy version with kernel 4.4.194 offers an option in rk322x-config to enable this module.
Since then, I’ve created multiple 8 GB images with this configuration.
This time, I decided to make a different procedure: Install from scratch an updated Armbian bookworm, then sudo apt install LXDE in order to GUI-access and copy my files from Retropie (via sh script) without needing to remove the SD card and insert it into a separate Linux OS. I used the latest available community image, Armbian_community_25.2.0-trunk.86_Rk322x-box_bookworm_current_6.6.63_minimal.img.xz, and successfully installed LXDE without any issues.
However, after installing RetroPie, the menu runs very slow. Somehow, I sense GPU Video driver is not responding or somehow LXDE messed up video drivers.
What do you think might be causing this? Perhaps there is a process running in background, and therefore making things going slow
I know a screenshot could explain better, but i'm not at home at this moment.
Hope you can help me on this.
Regards
D
Edited by Daniel Campillay Morales
Hello guys, I am new to the issue of boxes, I have made several without problems but there are 2 boards with the detail that the HDMI turns off in 1 minute, I have tried the recommended images so that this problem does not happen but I have not been able to solve it, I would appreciate your help on the subject, greetings
Hi @jock
Multitool boots properly but after a minute the box turns off(Libreelec has same behavior).
This minute is enough to erase emms but not enough to flash img on board and bricks the device.
Rkdeveloptool works great in maskrom mode and I managed to burn loader and image.
I tried Armbian_21.02.1_Rk322x-box_buster_legacy_4.4.194.img , Armbian_23.08.0-trunk_Rk322x-box_buster_edge_6.5.5_minimal, Armbian_23.11.1_Rk322x-box_jammy_current_6.1.63_minimal and self compiled Armbian-unofficial_24.2.0-trunk_Rk322x-box_bookworm_edge_6.7.5_minimal on emmc and sd card with no success.
Good afternoon. Thanks for the work you are doing.
I'm using a R329Q TV box with SSV6051P wifi chip. With the latest Armbian build the wifi connection doesn't work. According to the website https://travis90x.altervista.org/mxq-pro-4k-tvbox-rockchip-rk322x-armbian/, in order for the driver to work you need a kernel older than version 4.5.0. The page recommends using the Armbian_22.02.0-trunk_Rk322x-box_bullseye_legacy_4.4.194_minimal build, but I don't know where to look for it. There are no versions older than 23 on GitHub. Thanks, JC
  • Author
@Francisco Hasuky it is a known problem: some boards are sent to "suspension" after one minute by the proprietary Trust OS; you need to build u-boot with an opensource Trust to overcome the problem. At the moment I'm unable to build an image or provide the binary, but will do in the forthcoming hours/days
@Jota Ce if you got ssv6051p chip, then you should be ok using any recent armbian image with kernel 6.12 (you could upgrade to edge kernel via armbian-config, or use the beta.armbian.com APT repository). Also kernel 6.6 should work with ssv6051p because the (horrible) driver has been ported from 4.4 kernel.
@toro2077
If I remember well, and you can confirm by yourself scrolling in older posts, thiw wifi will never ever work since there aren't any driver avaible for this ( infamous) chip s9012p
Hello everyone, how are you? I hope you are well.
I have a RK322x TV Box with eMMC and I installed armbian, but my Wlan is a ssv6200, I noticed that this driver is not available in the version "Armbian_community_25.2.0-trunk.293_Rk322x-box_noble_current_6.12.8_xfce_desktop.img", is this missing driver available to download and include in this img?
Hello @Daniel Campillay Morales
do you actually use usb drive and successfully installed?
Can you teach me how to booting multitool with USB Drive, because my tv box did not automatically boot into multitool
i have been found some way but it seems difficult for me
sorry for my bad english:D
@Joshua allen
asking for private chat to solve personal issues  is the most unappropriate way to act in a public forum.
For several reasons:
1) your problem could be the same problem for other people sharing your issues, so solving for you could be solving for many
2) this is an hobby for us and not job.     Job is paid, hobby is for free.          if you need help for your personal issue you can give an advice asking for paid help
3)this really is the worst approach to an open community of people that friendly and mutual try to help each others
that said....
would you share what is your problem, since you already asked for help ( private help..) in another post ?
describe what is working, what not, attach procedures and photos of board , explain your moves and results
We will try to give you a helpful  hand.
Edited by fabiobassa
Hello,
I am new to Armbian, but have access to a lot of RK3228A  boards and up to now I have installed  it on some.
I noticed that a big part of these boards have the Wi-Fi module sv6x5x, like sv6158, sv6212p, 6051 and sv6030p (the last one is not 6x5x, but ok)
I also noticed that this type of module kind of  had support in the past, since older RK322x images came up with the corresponding Wi-Fi driver (ssv6x5x), but the newer images don't seen to come with it.
The problem lies on the fact that older images (legacy kernel) are not supported anymore.
So my question is:
Is there a way to select some configs on the Armbian framework to build images that come with this driver? If not, is there any tips on where I can get the source code and how I can compile it myself ?
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
