Skip to content
View in the app
Armbian Community Forums
Featured Replies
  • Author
On 3/13/2025 at 11:31 AM, Void Spirit said:
I tried to connect via ssh. the box provided the ip and mac address. I connected it like this: 1) lan option: PC -(lan)-  router  -(lan)- TV box. no connect. 2) Wi-Fi option: PC -(wifi)- router -(LAN)- TV box. no connect. Through the mobile application, Fing saw that the multitool did not have an open port. Although there are different IP and Mac addresses in multitool mode and Android mode. The multitool was downloaded from a link on this website
Hello; multitool has the port 22 open and listening for ssh connections. If it does not show the open port, then it is either freezed or did not start at all.
Regarding your A6 Mini board, which seems the only one with rk322x, it is not a board that we have encountered here on the forums, which is quite curious since the board marks a production date of 2018. Consider it to be a fake board.
I have not exactly understood what is what, since you declare you have a 2/16 S905W board with fake specs and a 1/8 RK322x board with (supposedly) real specs, but they could easily be both fake. Looking on google for A6_Mini boards, I only see S905L devices. You also say LibreELEC boots, but you did not say on which of those two boards boots.
Hello. I will respond to everyone with one message.
@RaptorSDS   Yes, the last link from this site. IP android tv 192.160.1.80 MAC ......79.81
From the SD card multitool IP 192.168.1.43 MAC ........fe:9b    but when scanning ports, there are no free ones. Connection through Putty failed.
@Alexander Sokolov   Thank you for the links. I tried. But unfortunately, they didn't work either.  Did you install it via a multitool or directly onto an SD card using balenaEtcher or Rufus?
@jock    Communicating through a translator. Incorrect translations of my text are possible. This is a board that indicates 2/16 S905W but in fact it is 1/8 RK322x. On the previous page, I sent screenshots. Screenshot number 8 aida64 with the original factory firmware. This is one tv box. Maybe I should have reverted to the factory firmware after LibreELEC but I don't have a dump.
Edited by Void Spirit
@Void Spirit
First of all, I recommend removing the radiator from the processor. To make sure that it's rk3228a. I use rpi image writer and balenaEtcher. And to check the operation of the multitool, it is best to connect the set-top box to the router. The console should be assigned an IP address and you can work with it via SSH, and you can use the screen command for the GUI interface of the utility.
@Александр Соколов Please look at the previous page. There is also a photo without a radiator. I connected it to the router. I accepted the IP address. I tried to connect via the windows command prompt, then through the Putty application. As a result, I scanned the network and found no open ports. I can capture the process on video.  Главное шьётся на другие андроиды и на LibreELEC а мультитул никак не реагирует.
vor 3 Stunden schrieb Gustavo Rgs:
Have any build rk322x armbian server version, without desktop?
yes every build that was compile has a minimal version that is the server one , please search for that at this post or github
hi, i wonder if theres any support for the a/v output on my tv box with the rk3229, i installed armbian but only seems to output on the hdmi, i really want to connect it to my tv :3
@Александр Соколов I installed different versions of Android. Successfully installed LibreELEC. But couldn't handle Armbian. I struggled with it for 3 weeks. I'm tired already. The only thing I didn't try was installing from USB. I installed everything from SD, from different SD cards. Can you please tell me, did you always have an image through HDMI when installing Armbian?
@Void Spirit
the easiest thing to do in such cases is connect a ttl > usb converter to those well exposed pads to see what is going on putty or any serial terminal you desire, and help understand  why the box doesn't boot
As you can see from photos @Alexander has it's debug wires attached semi-permanently with hot glue and this i suggest to you.
Saying " I am already tired" really doesn't help a lot , instead giving as much infos as possible will lead to successfully run the box
If libreeelc boots, armbian will boot. I have the same box, among many others, and I can say it boots fine and works fine too with armbian
Edited by fabiobassa
Ok, so I'm a newbie to Linux, I got the minimal image from the community but they are all minimal version, I want a version with a desktop, is it possible to convert the minimal? or can you link me a version with desktop?
I tried that one now, but my problem seems to be the same with all desktop versions, desktop wont boot, the keyboard and mouse connect don't turn on either.
my memory i eMMC.
I'll try to install the boot in the sd after installing to flash, maybe that will do the trick.
EDIT- No luck, any attempt to use a desktop img doesn't boot, hdmi and usb don't work, just the power led.
Edited by Chatuba
vor 42 Minuten schrieb Chatuba:
do you boot the minimal version , did they run good ? please provide version of minimal .  ( do you use lagecy version )
wich config did you use for  rk322x-config --> same has to be config to run dekstop
currently on the newst minimal version, it works fine, all ports work, I'm currently trying to manually install a xfce4, but lightdm.service isn't working.
EDIT - got a desktop to work via console, but i need to install anydesk, sadly it seems im missing multiple libraries bc sudo apt install anydesk tries to use a version for raspberry pi.
let me elaborate what I'm trying to do. I want to use my rk3229 as a wake on wan server, i cannot port forward, because my ISP doesnt allow it, I ask you to not suggest ways to port forward ive tried all of them, my isp locks down their router with no option for bridge mode.
my hope was to use anydesk, bc it has a native wake on wan feature as long as 2 machines are in the network.
EDIT 2 - I GOT IT! but I went with SSH terminal using tailscale for the connection, since I can't port forward, I'm sorry if anyone needs help, bc I dunno what I did, I spent a day taking photos of my screen and sending it to gemini (first good use of AI)
Edited by Chatuba
Hello people,
I'm not a debian user so i'm not understand all concepts about apt and how the diferentes branch and dependencies are managed.
Can you help me with the following case? (i tried to look for in forums without success, the information that I've found is referenced to another branch noble instead my branch 'focal' but i think it could be similar)
i executed the following:
sudo apt autoremove
what it removed the following package:   armbian-bsp-cli-rk322x-box
thinking that it could be relevant for my SoC device i tried to install it again:
sudo apt install armbian-bsp-cli-rk322x-box >
The following packages have unmet dependencies:
 armbian-bsp-cli-rk322x-box-current : Depends: base-files (>= 25.2.3) but 11ubuntu5.8 is going to be installed
E: Unable to correct problems, you have held broken packages.
have i broken my system? how could i resolve it ?
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 20.04.6 LTS
Release:        20.04
Codename:       focal
if you can help me it would be appreciated. thanks in advance.
Hello people,
sudo apt autoremove
lsb_release -a
Release:        20.04
Codename:       focal
Did I not break anything, then?
everythink is OK?
my PC was rebooted and no problem was raised, but now the login console differs.
I will look into the next steps to stay updated. If the information I am reading is accurate, the branch jump is risky .
Some hint about How to update my system?
(i came from archlinux , and the branch concept is something new for me)
Thanks for the response.
Edited by Menos_16
Hello again, I commented on the topic over a year ago about my R29.
After over a year of not using it, I want to install an internal server to manage some files and even run basic networking and hacking tools.
Is it possible to install Archlinux on it? What has changed since 1 year ago? For example, can I now have HDMI and Wi-Fi?board-tvbox.jpeg.1e9617314cef5bc59493954f3201ad3f.thumb.jpg.5c20f4f8e1d163bb704eb23660b0fa99.jpg
Found a handful of working mxq boards in the trash, the unique ones are labed R329Q_v8.1, MXQ_RK3229_EMPC_V4.1 and B00-RK28A-REV76. What are they actually?
Almost all of them have an ssv6256p. Can someone confirm me it's actually impossible to use the wifi with this chip? I tried and tried and couldn't get it to work.
There's one board with a chip called MSN8800D I would try to get wifi with it but multitool says the emmc storage was not found. Did the chip fry, even though it's a 8Gb/8GB one? If it fried the board shouldn't work at all because the ram would fry too, no? It's Samsung KMQ7X000SA-B315
vor 11 Stunden schrieb Defalt36:
Yes correct the SSV6252p is hard to get it run because no support ,
the MSN8800D i think was a old chip from i-phone or a clone from something , support looks bad ( only some one match with google  ) but its have nothimng to do with emmc support , maybe this board has nand or eMCP memmory and than also emmc not found  ( Nand only in legacy image support , eMCP only with correct led-config sometimes)
when you have exp in hot air soldering maybe swap the wifi this a best solution or use usb stick
Att, my board broken after trying to update, idk why but it crashes and system doenst start
i have installed the last trunk.
vor 5 Stunden schrieb k405:
Please read first page , its very very hard to brick the board normaly insert sd-card and flash another image and you good to go
please provide serial log if possible , else we cannot see where th problem occur
  • Author
The only way, which is really discouraged and discontinued, is to use a build with legacy kernel. On mainline kernel, the only driver supported is for ssv6051p, but it does not work for ssv6256p.
There could be several reasons the eMMC is not detected. One of the reason is obviously it is the broken, even though the DDR part is still working. More often the board has some circuitry or the chip has some configuration that need to be tuned properly in software to work. Tv boxes have plenty and plenty of different configurations that is impossibile to cover all the compatibility issues that  may arise.
If the flash part of the eMCP is really broken, if you plug an sdcard with Armbian on it, the stock Android should not boot (obvious if the internal flash is broken) and Armbian should boot instead.
About the MSN8800D, it seems to be a clone of AIC8800D chip, of which a driver is circulating and should already be integrated in armbian, but not yet enabled for rk322x.
I don't know how to quote messages.
@RaptorSDS I've "broken" the box a few times, but I fix it using rkdeveloptool and the maskrom pin on the board. My problem is that I can't use the eMMC correctly, it crashes every time I try to update the box.
How do I get the serial log? I have time to help with this R29 board if you need it
Now I intend to run Armbian on the SDCARD and use the eMMC as a swapfile and storage for cache and temporary files, is that possible?
Hi, i have a R29_5G_LP3_V1.2 that i brick it, tried reduce the partition from internal emmc, i used rkdeveloptool to fix it, and dont worked! Can i remove the emmc chip and this can work just sdcard boot?
Thanks
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
