Skip to content
View in the app
Armbian Community Forums
[ODROID C2] USB ports are (again?) not working properly
Featured Replies
no WiFi Adapter after fresh installation. usbcore.autosuspend=-1 fixes it:
  ___      _           _     _    ____ ____
 / _ \  __| |_ __ ___ (_) __| |  / ___|___ \
| | | |/ _` | '__/ _ \| |/ _` | | |     __) |
| |_| | (_| | | | (_) | | (_| | | |___ / __/
 \___/ \__,_|_|  \___/|_|\__,_|  \____|_____|
Welcome to Armbian 24.2.1 Bookworm with Linux 6.6.16-current-meson64
System load:   46%           	Up time:       0 min
Memory usage:  7% of 1.82G  	IP:	       192.168.25.252
CPU temp:      28°C           	Usage of /:    66% of 3.0G
[ Menu-driven system configuration (beta): sudo apt update && sudo apt install armbian-config ]
root@odroid:~# cat /boot/armbianEnv.txt
verbosity=1
console=both
overlay_prefix=meson
rootdev=UUID=1cf10f1a-aa21-4ff0-875d-c59f57c87173
rootfstype=ext4
extraboardargs=fastboot noswap isolcpus=3 usbcore.autosuspend=-1
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
root@odroid:~# lsusb
Bus 001 Device 007: ID 0bda:2838 Realtek Semiconductor Corp. RTL2838 DVB-T
Bus 001 Device 006: ID 7392:7822 Edimax Technology Co., Ltd EW-7612UAn V2 802.11n Wireless Adapter [Realtek RTL8192CU]
Bus 001 Device 005: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Since todays update to kernel 6.6 on my odroid c2, usb was broken.
lsusb shows that no devices are found anymore using the new kernel:
lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
dmesg shows the following error during boot:
[    5.777103] onboard-usb-hub 1-1: can't set config #1, error -71
Adding the "extraboardargs" option to /boot/armbianEnv.txt as described above, solved the problem for me.
Edit: This recent kernel change might be connected: https://lore.kernel.org/lkml/1jleciyahv.fsf@starbuckisacylon.baylibre.com/T/
Edited by Scritch
I have a rather janky fix for this issue. Basically, we reset all USB devices on the bus after boot. I created a systemd service file with the following contents:
$ cat /etc/systemd/system/usb-reset.service
[Unit]
Description=Reset USB devices before SDDM
Before=sddm.service
[Service]
Type=oneshot
ExecStart=/root/usbreset.sh
[Install]
WantedBy=multi-user.target
And the script is this:
$ cat ~/usbreset.sh
#!/usr/bin/env bash
# Resets USB devices in a specified path.
# Use with caution, as this may reset devices currently in use.
base_path="/sys/bus/usb/devices/"
# Function to reset a single USB device
reset_usb_device() {
    dev_path="$1"
    echo "Resetting device at '$dev_path' ..."
    echo 0 | sudo tee "$dev_path/authorized" > /dev/null  # Deactivate
    sleep 1  # Short delay
    echo 1 | sudo tee "$dev_path/authorized" > /dev/null  # Reactivate
# Find USB devices
echo "Looking for USB devices in '$base_path'..."
for dev_path in "$base_path"/*
do
    reset_usb_device "$dev_path"
done
echo "Done."
Enable and start this service and your USB devices will be re-initialized after boot.
I've also verified that adding the "extraboardargs" as in the first post works for me as well.
Edited by all2
On my Gentoo setup, I never had any USB issues before 6.6, even without the usbcore.autosuspend=-1 option. With 6.6, though, USB doesn’t work for me even with that option enabled. The fix from all2 worked for me, so thanks to that I put together what I think is a slightly more robust solution:
Quote
[Unit]
Description=reinitialize USB (dwc2 c9100000.usb) on ODROID-C2
DefaultDependencies=no
After=systemd-udev-settle.service
Before=sysinit.target
[Service]
Type=oneshot
ExecStart=/bin/sh -c 'echo c9100000.usb > /sys/bus/platform/drivers/dwc2/unbind; sleep 1; echo c9100000.usb > /sys/bus/platform/drivers/dwc2/bind'
[Install]
WantedBy=sysinit.target
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
