Skip to content
View in the app
Armbian Community Forums
mainline u-boot (March 2024) rk3399 nvme boot
Featured Replies
Now the mainline u-boot has decent pcie and pcie phy driver for rk3399. The only deficiency is the clock of pcie phy not included. The first attached patch add this clock so that u-boot proper can load linux kernel residing in an ext4 partition of nvme ssd.pcie_phy_clk.patch
The second patch enables loading the environment from a file in an ext4 partition of nvme ssd.env_nvme.patch
More conveniently  the u-boot proper(u-boot.itb) could be an ordinary file residing in an ext4 partition of nvme ssd. The idbloader(tpl/spl in spi/emmc/sdcard) could load it if pcie nvme support is enabled in spl. That's the third attachment.spl_nvme.patch
The usb and usb phy is working so the usbkbd can be used to choose a boot option without a serial port debug console. The last attachment set the default env to enable usbkbd and vidconsole.env_vidconsole_usbkbd.patch
And for your convenience my u-boot config for nanopc-t4 also attached here.u-boot.config
the config not work, I don't why
 MKIMAGE u-boot.img
 CC      tpl/arch/arm/mach-rockchip/rk3399/rk3399.o
In file included from include/part.h:9,
                from include/mmc.h:17,
                from include/spl.h:17,
                from arch/arm/mach-rockchip/rk3399/rk3399.c:9:
include/blk.h: In function 'blk_dread':
include/blk.h:552:30: error: 'struct blk_desc' has no member named 'block_read'
 552 |         blks_read = block_dev->block_read(block_dev, start, blkcnt, buffer);
include/blk.h: In function 'blk_dwrite':
include/blk.h:564:25: error: 'struct blk_desc' has no member named 'block_write'
 564 |         return block_dev->block_write(block_dev, start, blkcnt, buffer);
include/blk.h: In function 'blk_derase':
include/blk.h:571:25: error: 'struct blk_desc' has no member named 'block_erase'
 571 |         return block_dev->block_erase(block_dev, start, blkcnt);
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
