Skip to content
View in the app
Armbian Community Forums
udev rules not create SYMLINK
Featured Replies
I create a file 98-use-serial.rules under folder /etc/udev/rules.d . But symlink not created . My purpose is to fix USB port names, As COM1 COM2 COM3
This is the content of 98-usb-serial.rules:
SUBSYSTEM=="tty",ATTRS{busnum}=="1",ATTRS{devnum}=="2",SYMLINK+="COM1"
SUBSYSTEM=="tty",ATTRS{busnum}=="4",ATTRS{devnum}=="2",SYMLINK+="COM2"
SUBSYSTEM=="tty",ATTRS{busnum}=="5",ATTRS{devnum}=="2",SYMLINK+="COM3"
I used to fix the USB port on Asus Tinker S, Khada_VIM3 , all worked fine. I have no idea why Orange Pi 4 LTD not working.
Might be related: on latest armbian, I'm
encountering two issues:
  1. Contents of /dev/serial/by-id and /dev/serial/by-path are not the same: some connected devices are missing from by-id, making it complicated to identify which /dev/ttyACMx is which.
orangepi@mypc:~$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 007: ID 1a86:55d4 QinHeng Electronics USB Single Serial
Bus 003 Device 006: ID 1a86:55d4 QinHeng Electronics USB Single Serial
Bus 003 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 014: ID 1a86:55d4 QinHeng Electronics USB Single Serial
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
orangepi@mypc:~$ usbreset
Usage:
  usbreset PPPP:VVVV - reset by product and vendor id
  usbreset BBB/DDD   - reset by bus and device number
  usbreset "Product" - reset by product name
Devices:
  Number 002/014  ID 1a86:55d4  USB Single Serial
  Number 003/007  ID 1a86:55d4  USB Single Serial
  Number 003/006  ID 1a86:55d4  USB Single Serial
  Number 003/002  ID 1a40:0101  USB 2.0 Hub
orangepi@mypc:~$ tree /dev/serial/
/dev/serial/
├── by-id
│   └── usb-1a86_USB_Single_Serial_535A000001-if00 -> ../../ttyACM3
└── by-path
    ├── platform-fe3a0000.usb-usb-0:1:1.0 -> ../../ttyACM3
    ├── platform-xhci-hcd.4.auto-usb-0:1.3:1.0 -> ../../ttyACM0
    └── platform-xhci-hcd.4.auto-usb-0:1.4:1.0 -> ../../ttyACM1
3 directories, 4 files
Armbian 24.5.1 bookworm
2. Simultaneously, I am encountering problems when usb-serial converter will freeze and won't respond unless I manually perform usbreset command.
udev rules (60-serial.rules) were certainly updated since armbian release ~1 year ago.
However, this might be simply related to some changes in our connected hardware. Since we added USB hub and have newer revision of these usb-serial converters, I cannot say for certain this is an OS problem.
I have the same problem.  These two things together (udev rules and symlinks) are a show-stopper.
The platform is Orange Pi Pro 5.
First, the udev script is extremely useful for pinning USB-serial devices to a specific name
Second, the symlink mechanism is essential for presenting serial devices as "COMxx" in the Wine dosdevices folder.
Here is my 48-ttyUSB.rules file, which links manufacturer-specific devices to "tty...." names:
KERNEL=="ttyUSB0" SYMLINK+="%k" GROUP="ray" MODE="0666"
KERNEL=="ttyUSB[0-9]*", SUBSYSTEM=="tty", SUBSYSTEMS=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", SYMLINK+="tty-F232" GROUP="ray" MODE="0666"
KERNEL=="ttyUSB[0-9]*", SUBSYSTEM=="tty", ATTRS{interface}=="USB-COM485 Plus2", ATTRS{bInterfaceNumber}=="00", SYMLINK+="tty-F485A" GROUP="ray" MODE="0666"
KERNEL=="ttyUSB[0-9]*", SUBSYSTEM=="tty", ATTRS{interface}=="USB-COM485 Plus2", ATTRS{bInterfaceNumber}=="01", SYMLINK+="tty-F485B" GROUP="ray" MODE="0666"
KERNEL=="ttyUSB[0-9]*", SUBSYSTEM=="tty", SUBSYSTEMS=="usb", ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", SYMLINK+="tty-Pro" GROUP="ray" MODE="0666"
KERNEL=="ttyUSB[0-9]*", SUBSYSTEM=="tty", SUBSYSTEMS=="usb", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6015", SYMLINK+="tty-CHIPIX" GROUP="ray" MODE="0666"
This works perfectly on a range of Linux computers: all of them are Mint or Ubuntu, and all are on x86 hardware.
As a further diagnostic in the Orange Pi/Armbian scene, any of the USB-serial adapters will come up as /dev/ttyUSB0.
Any attempt to establish a symlink in ~.wine/dosdevices installs an entity which looks like a symlink, but which doesn't work: even trying to inspect Properties crashes out.
Help please!
Long time since I really did run wine, but I still have it installed on Opensuse Tumbleweed (x86_64). That is a rolling release with latest Linux and in the past years I found out udev are less and less needed.
For network devices, you can for example use a systemd network .link file to rename and have nice static names (based on MAC-address).
For serial ports via USB, you can use existing unique serial device name, e.g. in my ser2net.yaml file:
connector: serialdev,/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AC2YVFHY-if00-port0,115200n81,local
Works great and rather critical as this is my energy measurement thing. It should be possible to create another symlink named COM<x> to those names.
Around 2 years ago there was once a Debian systemd problem and then this build-in method failed, but was fixed rather quick.
What the difference is between other Linux computer and this one, I don't know. The original topic is 2 years old and other board. So no-one really can reproduce you problem, that is why I just write a working methodology and forget about this topic I guess.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
