April 11, 20242 yr What you need: - A DQ08 (got mine from aliexpress) - An sdcard (4g if you want to use external usb3 ssd or 32g if not)  If you're lazy and trust my image (you shouln't, as I can bundle malwares inside): - flash this using this - usb2serial included - put in DQ08 and plug it in ethernet - scan for the ip using this - in windows terminal, using password=1234: ssh root@BOXIP To build the sd card, i've used this tutorial: - install wsl on your windows - apply this patch  Spoiler sudo wget --output-document=/usr/share/keyrings/armbian-next.gpg https://apt-test.next.armbian.com/armbian-next.gpg cat << EOD | sudo tee /etc/apt/sources.list.d/armbian-next.list deb [signed-by=/usr/share/keyrings/armbian-next.gpg] http://apt-test.next.armbian.com armbian main deb [signed-by=/usr/share/keyrings/armbian-next.gpg] http://apt-test.next.armbian.com armbian-$(lsb_release -cs) main EOD sudo apt update && sudo apt list --upgradable | grep -i armbian - open wsl shell - install docker on wsl: curl -fsSL get.docker.com | sh - run docker: sudo /etc/init.d/docker start - permit to use docker: sudo usermod -aG docker $USER - open a new shell (important) - follow this Spoiler  git clone https://github.com/ilyakurdyukov/rk3528-tvbox.git cd rk3528-tvbox git clone --depth=1 https://github.com/armbian/build armbian-build cp -R armbian-patch/* armbian-build/ cd armbian-build ./compile.sh build BOARD=rk3528-tvbox BRANCH=legacy BUILD_DESKTOP=no BUILD_MINIMAL=yes EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm cd ../.. cat <<EOF > rk3528-tvbox/build.sh #!/bin/bash cd /build IMAGE=\`ls /build/armbian-build/output/images/*.img\` losetup -D losetup --partscan /dev/loop0 \$IMAGE mount /dev/loop0p1 /mnt cd devicetree cp orig/*.dtsi . patch -p1 -i rk3528-tvbox.patch make NAME=rk3528-vontar-dq08 PRESET=LINUX cp rk3528-vontar-dq08.dtb /mnt/dtb/rockchip sed "s#fdtfile=.*#fdtfile=rockchip/rk3528-vontar-dq08.dtb#" -i /mnt/armbianEnv.txt losetup -D cat \$IMAGE | gzip > /build/\`basename \$IMAGE\`.gz EOF chmod a+x rk3528-tvbox/build.sh docker run -it -v /dev:/dev --privileged=true -v `pwd`/rk3528-tvbox:/build --rm armbian.local.only/armbian-build:initial /build/build.sh  - flash the img file found in Linux/Ubuntu/home/XXX/armbian-build/output/image using this - put in DQ08 and plug it in ethernet - scan for the ip using this - in windows terminal, using password=1234: ssh root@BOXIP  If, like me, you want to use an USB3 SSD: - flash the usb3 drive with the same image - plug to the box - e2label /dev/sda2 ssd - change /boot/armbianEnv.txt: rootdev=LABEL=ssd - reboot - check free size with: df -h / - optional: remove unused boot partition: fdisk /dev/sda + d + 1 + w + q - optional: remove unused data partition: fdisk /dev/mmcblk0 + d + 2 + w + q  If, like me, you have usb2serial adapters: - follow this but remove all parameters at the end of ./compile.sh build and during kernel configuration, enable this: Device Drivers -> USB Support -> USB Serial Converter Support -> FTDI and PL230x Edited April 11, 20242 yr by fensoft
April 11, 20242 yr Please do not promote forks of Armbian on these forums. If you what to help Armbian, please submit PRs and contribute code that makes Armbian better. It doesn't help to have yet another fork of stuff out there that never gets contributed back.  Your warning about using external builds applies equally well to external git sources. No one should trust this unless they inspect all the changes you have made from genuine Armbian. User be warned.
April 11, 20242 yr Author do you want me to remove all binaries ? Â about tvbox in the genuine armbian, i'm pretty sure that i've read somewhere armbian would not support them Edited April 11, 20242 yr by fensoft
April 11, 20242 yr They aren't officially supported, but there are many TV boxes that are Community Maintained and available on the Armbian download page. Â No need to remove the binaries, your warnings are good enough.
April 12, 20242 yr @fensoft congratulations for your work, please stop acting like you dont live in society. Just do it in a PR. Or Compile 30x backdoor images to US. Edited April 12, 20242 yr by Hqnicolas
April 13, 20242 yr Is it possible to install Armbian into internal memory without jumping though hoops?
April 13, 20242 yr Author On 4/12/2024 at 7:02 AM, Hqnicolas said: please stop acting like you dont live in society. Just do it in a PR. Or Compile 30x backdoor images to US. Toxicity level over 9000, you better keep it for yourself next time. Â About PR, I can't and dont want. It's not my patch. Feel free to do it yourself if it's so important.
April 13, 20242 yr Author 22 minutes ago, Shinjin said: Is it possible to install Armbian into internal memory If I understand well, boot loader is at the begining of the emmc. Doing armbian-install will probably ends with system not booting anymore.
April 13, 20242 yr Yes, but AFAIK on other TV boxes an internal install shouldn't touch vital portions of the emmc. And Rockchip devices should still boot from SDCARD?   Â
April 13, 20242 yr Author I have the original software from vendor if needed. But, as I dont trust internal emmc, I never tried.
April 13, 20242 yr 57 minutes ago, fensoft said: I dont trust internal emmc I have done the internal EMMC armbian and I dont trust this EMMC too... Edited April 13, 20242 yr by Hqnicolas
May 11, 20251 yr Author I have uploaded an updated version here.  Also, for thoses who want to use internal emmc (boot without sdcard), you can run this script: Spoiler #!/bin/bash set -e set -x TARGET=/dev/mmcblk2 IMAGE=Armbian-unofficial_25.05.0-trunk_Rk3528-tvbox_bookworm_legacy_5.10.160_minimal.img sed -e 's/\s*\([\+0-9a-zA-Z]*\).*/\1/' << EOF | fdisk $TARGET d # delete 3 d # delete 4 d # delete 5 d # delete 6 d # delete 7 d # delete 8 d # delete 9 d # delete 10 d # delete 11 d # delete 12 d # delete 13 d # delete 14 d # delete 2 n # new partition 2 16384 +16384 n # new partition 3 +524288 n # new partition 4 61071295 n # new partition 5 61071296 61071325 x # expert mode n # set name 2 uboot n # set name 3 boot n # set name 4 rootfs p # print r # return w # save q # quit EOF sed -e 's/\s*\([\+0-9a-zA-Z]*\).*/\1/' << EOF | gdisk $TARGET x # expert mode a # set attribute 3 2 w Y EOF LO=`losetup -f` losetup --partscan $LO $IMAGE dd bs=512 if=$LO of=${TARGET}p2 count=16384 skip=16384 dd if=/dev/loop0p1 of=${TARGET}p3 bs=1M status=progress dd if=/dev/loop0p2 of=${TARGET}p4 bs=1M status=progress   You can reinstall android using this, connecting DQ08's usb2 port (using a male-male usb cable) to the computer while pushing the button in the AV connector. Then, in the app (extracted to c:\), choose firmware / firmware.bin / restore / run. Edited May 11, 20251 yr by fensoft
May 13, 20251 yr Hello I was able to build image (both debian and ubuntu) according to this instructions: https://gist.github.com/fensoft/1ff3ef81ab2bd9ed9364a564aa2cbcd5?permalink_comment_id=5576642#file-build-sh  image is flashed to microsd card.  However tvbox does not boot from sdcard - I see that it boots up regulary to android. Also I have found that in AV jacker on board there is button, so if hold it during boot - you are into Android recovery with options (reboot system/ reboot to bootloader/ fastboot /udpates ADB /updates from SD card/ factory reset /wipe / power off)  The question is how to make TV box boot from sdcard? I was setting up armbian to orange pi - and it by default boots from sdcard. But with tv box according to posts and videos also should....  I'm trying to flash: Transpeed ATV Android 13 TV BOX RK3528 With Voice Assistant TV Apps Dual Wifi Quad Core Cortex A53 Support 8K 4K Video BT5.0 with 4G ram: https://www.aliexpress.com/item/1005007785484949.html    Â
May 13, 20251 yr Author you don't have to. it's already trying to boot by default to sd. you can either try to install the same android as me, change the sdcard or plug an usb2serial cable @ 1.5Mbauds to check uboot logs.
May 13, 20251 yr I thought there should be any console output to hdmi, ok will try with uart. By the way @fensoft are you using armbian on it? is it stable?
May 15, 20251 yr Author i never connected anything on the hdmi port, sorry. i'm using 10 of them for different projects, some are used 24/7/365 for home assistant or video encoding
May 16, 20251 yr 16 hours ago, fensoft said: . i'm using 10 of them for different projects did the 100mbps LAN make you work worse?
May 16, 20251 yr Author 100mbps is enough for all my projects. if not, there are some usb3 gigabit adapters Edited May 16, 20251 yr by fensoft
September 1, 20251 yr Hi everyone, i manage to extract the .dtb file from the recovery partition of the rk3528-X88pro13-android. This is the board number : X88PRO 13-D4-V1.1 (2023-04-12). Maybe it will be useful to someone 😉 rk3528-x88pro13-android.dtb
September 30, 20251 yr @fensoft please make this https://github.com/ilyakurdyukov/rk3528-tvbox as a pull request, you have the dq08 tvbox board, you're embedded in the community, you've tested everything, you seem like the perfect guy
September 30, 20251 yr Author I already said i cant and dont want to. Â Anyway, in the meantime, I tried to port to latest version of armbian and didn't managed to finish because of some issues with devicetree. I gave up because no time for the moment (and found nomore fun in debugging for something i dont need) Â Final goal was to port haos to it anyway. Armbian was only a step for me. Edited September 30, 20251 yr by fensoft
September 30, 20251 yr 4 minutes ago, fensoft said: I gave up because no time for the moment leave a link for other users like @John Taylor to continue your work, also @fedes_gl could give a hand
October 4, 20251 yr Author On 9/30/2025 at 5:56 PM, Hqnicolas said: leave a link for other user everything is in the main post
October 4, 20251 yr Author for thoses who want to install sd to emmc, use this script (remove the line about haos near the end) Edited October 4, 20251 yr by fensoft
October 5, 20251 yr Author i've updated the image to include info on screen like IP / cpu usage / ram usage (in %) Â any software can write to /tmp/screen to change content you can download here
October 9, 20251 yr On 10/5/2025 at 5:31 PM, fensoft said: any software can write to /tmp/screen to change content  For this 16xx displays we need to ask @Jean-Francois Lessard he was in contact with this drivers for a while. these 16xx displays will be included in the mainline 6.18 drivers as tm16xx_i2c make sure to adjust your device according to this repository to benefit from the update https://github.com/jefflessard/tm16xx-display
November 24, 2025Nov 24 Author 2 hours ago, alex001gg1 said: You really will put malware if i install this? you clearly didn't get the point
November 24, 2025Nov 24 Just answer it... Will i have malware if i installed it on my tv box H96 max RK3528 4gb ram 64gb rom
November 25, 2025Nov 25 Author "no". but don't trust anybody, that was the point. you don't know me.  moreover, you probably already have on your stock firmware, like a lot of chinese android tvbox
