May 3, 20242 yr My system has `linux-image-current-bcm2712` package installed with version 24.2.5 which I believe is the current Arbian release. I installed `linux-headers-current-bcm2712`, but this package has version 24.2.1. So I end up with system running `6.6.23-current-bcm2712` with headers for `6.6.18-current-bcm2712` and I can't build extra drivers in result. Any hints? I love technical forums that don't understand markdown, it makes life so much easier...
May 3, 20242 yr 1 hour ago, Michal Fita said: Any hints? Did you reboot before (re)installing headers? If yes and still not ok ... beta repository certainly has matched kernel / headers combo. IMO its pretty safe to upgrade to daily builds, but then freeze kernel (can be done in armbian-config).
May 3, 20242 yr Author Quote Did you reboot before (re)installing headers? How this helps `apt` recognize what to install from the repository? But yes, I gave it a try... reinstalling `linux-headers-current-bcm2712` reinstalls 24.2.1 with 6.6.18 in it. I used `armbian-config` as suggested... and ended up with: hi linux-headers-current-bcm2712 24.2.1 arm64 Armbian Linux current headers 6.6.18-current-bcm2712 hi linux-image-current-bcm2712 24.5.0-trunk.530 arm64 Armbian Linux current kernel image 6.6.30-current-bcm2712 What's actually even worse. More hints?
May 3, 20242 yr 2 minutes ago, Michal Fita said: More hints? Remove headers, reboot, install then once again.
May 3, 20242 yr Author OK 🤦♂️ I had to unfreeze, do `apt update` manually, then I got update for `linux-headers-` to 24.5.0. So, `apt upgrade` did: ii linux-headers-current-bcm2712 24.5.0-trunk.530 arm64 Armbian Linux current headers 6.6.30-current-bcm2712 ii linux-image-current-bcm2712 24.5.0-trunk.530 arm64 Armbian Linux current kernel image 6.6.30-current-bcm2712 Possible bug in `armbian-config` not upgrading headers package?
May 3, 20242 yr Author Quote IMO its pretty safe to upgrade to daily builds, but then freeze kernel (can be done in armbian-config). And 6.6.30 bricks the unit... doesn't boot 🤦♂️ and I don't have serial cable to my RPi5. Fan remains spinning at full speed. Going back to reflash the SD Card with original image. Who can fix header package for the stable branch? Edited May 3, 20242 yr by Michal Fita
May 3, 20242 yr 56 minutes ago, Michal Fita said: Who can fix header package for the stable branch? This is just one issue out of thousands and we operate all this with budget that is very close to zero. This should be picked by maintainer, if exists. We support them from our business deals, but still, they come and go and in between, we have nobody. For a month and half, there is nobody and I can't cover, its too expensive. Since none of board maintainer is full time, but they should be, this can easily take weeks, or more ... But luckily: automated builds makes it half way. Its there, even smoke tested, where problems are not detected. one can build combo on their own. its open source. You can fix bugs too. we need to push new release by the end of the month. And yes, I heard there are some problems with Rpi kernels. Which will just make us more damages and headaches. Rpi foundation has almost 2 mio EUR yearly budget to fight problems ... Its not Armbian that is making bugs, but you expect us to pay to fix them. I tried to help you with hints. Here I have to stop. Out on vacations.
May 3, 20242 yr Author 47 minutes ago, Igor said: its open source. You can fix bugs too. Gladly, just need to know where to start to trigger CI to build header's package for 24.2.5? Quote Its there, even smoke tested, where problems are not detected. Raspberry Pi 5 is not on the list. 47 minutes ago, Igor said: but you expect us to pay to fix them. No, I expect to tell me what's wrong and give hint how this can be fixed. 47 minutes ago, Igor said: We support them from our business deals How much we'd have to pay to get this fixed? Edited May 3, 20242 yr by Michal Fita
May 3, 20242 yr 2 minutes ago, Michal Fita said: I expect to tell me what's wrong Usually research (or active sponsoring of our team) is needed to determine what is wrong. This can take half an hour or several weeks. As active sponsoring is still way below 1% of our costs, I have absolutely no interest to cover expenses of any research and then provide findings in exchange for nothing. This is deadly for the project and our mental health. Usually additional questions / research are requested, which only makes developers more frustrated. This is quite common delusion here - that open source developers are stupid and just happy to work for free. Yes, limited to things they like to work on. There are thousands of problems and they are not ours. They are yours, even "sold" under Armbian assembly. If you can tell who will pay research for you or for everyone, I will find someone that will do it. Or not. I have no budget to spent. Since this is open source, anyone can finance to tell what is wrong. This is the essence of this forums. 11 minutes ago, Michal Fita said: How much we'd have to pay to get this fixed? ... and perhaps another week that solution is developed, implemented and tested? Perhaps a lot more. Ain't simple to answer to this question. All this require serious investment from our side to support worse customer there is Don't take this as an offence as this is a part of the game. This only have ends at different point. You can donate, or not. If you want that this is fixed, this has different procedure. It require establishing business relation, which procedure is by default expensive and for resolving one problem ... its a lot better to skip it anyway. However, starting point is trying to make a support contract, make large enough donation that we don't need to pay for everything as we will not move. This is not something granted as I need to be sure that I can keep my promise and meet your expectations. 32 minutes ago, Michal Fita said: Gladly, just need to know where to start to trigger CI to build header's package for 24.2.5? Armbian CI can only be executed by Armbian staff member with sufficient privileges. I am talking about CI that is auto remaking all our code (kernel, headers, ...) on code change. This is dropped to APT repo http://beta.armbian.com, which is updated daily and at every code change.
May 3, 20242 yr Author 2 hours ago, Igor said: They are yours, even "sold" under Armbian assembly. Agree. 2 hours ago, Igor said: You can donate, or not. If you want that this is fixed, this has different procedure. It require establishing business relation, which procedure is by default expensive and for resolving one problem ... its a lot better to skip it anyway. However, starting point is trying to make a support contract, make large enough donation that we don't need to pay for everything as we will not move. This is not something granted as I need to be sure that I can keep my promise and meet your expectations. My company can only cover costs for agreed Statement of Work and the price has to be agreed upfront. We can push limited number of hours invoiced for something important, but unfortunately we can't do donations - startups looks every penny both sides twice. 2 hours ago, Igor said: Armbian CI can only be executed by Armbian staff member with sufficient privileges. I am talking about CI that is auto remaking all our code (kernel, headers, ...) on code change. This is dropped to APT repo http://beta.armbian.com, which is updated daily and at every code change. Looks like images released aren't compatible with state of APT repositories: ~# apt show -a linux-image-current-bcm2712 Package: linux-image-current-bcm2712 Version: 24.2.5 Status: install ok installed Priority: optional Section: kernel Source: linux-6.6.23 Maintainer: Armbian Linux <info@armbian.com> Installed-Size: 155 MB Provides: linux-image, linux-image-armbian, armbian-current Armbian-Kernel-Version: 6.6.23 Armbian-Kernel-Version-Family: 6.6.23-current-bcm2712 Armbian-Original-Hash: 6.6.23-S8c3e-Dfed2-P0000-Ccc02H66b1-HK01ba-Vc222-Bd104-R448a Download-Size: unknown APT-Manual-Installed: yes APT-Sources: /var/lib/dpkg/status Description: Armbian Linux current kernel image 6.6.23-current-bcm2712 This package contains the Linux kernel, modules and corresponding other files. version "6.6.23" git revision "8c3e7a55220cb7cb13131bb8dccd37694537eb97" codename "Hurr durr Ima ninja sloth" drivers hash "fed24384_9f81b93f" patches hash "0000000000000000" .config hash "cc027d3a59f16119" .config hook hash "66b17b0d7f47b551" variables hash "c22207b66dc5dd57157df2cd7b9c20559b2ed8ac44b9c3c3b9704002c06b8921" framework bash hash "d1042705e60277e8" Package: linux-image-current-bcm2712 Version: 24.2.1 Priority: optional Section: kernel Source: linux-6.6.18 Maintainer: Armbian Linux <info@armbian.com> Installed-Size: 158 MB Provides: linux-image, linux-image-armbian, armbian-current Armbian-Kernel-Version: 6.6.18 Armbian-Kernel-Version-Family: 6.6.18-current-bcm2712 Armbian-Original-Hash: 6.6.18-S9e78-D6b4a-P0000-Cb2aaH4168-HK01ba-Vc222-B067e-R448a Download-Size: 27.4 MB APT-Sources: http://apt.armbian.com jammy/main arm64 Packages Description: Armbian Linux current kernel image 6.6.18-current-bcm2712 This package contains the Linux kernel, modules and corresponding other files. version "6.6.18" git revision "9e78addad23f9fc66b0c6399d9234e44a89d699a" codename "Hurr durr Ima ninja sloth" drivers hash "6b4abbc6_0b3d8cbf" patches hash "0000000000000000" .config hash "b2aa59cc79694025" .config hook hash "4168b2934f796ee8" variables hash "c22207b66dc5dd57157df2cd7b9c20559b2ed8ac44b9c3c3b9704002c06b8921" framework bash hash "067e1a10c790605d" `APT-Sources` field indicates only the latter is available on apt.armbian.com... I found https://armbian.site-meganet.com/apt/pool/main/l/linux-6.6.18/ only, no directory for 6.6.23 in there.
May 9, 20242 yr sudo apt install linux-image-current-bcm2712=24.2.1 Did this solve the kernel/header mismatch? I ran into the same issue (and posted separately - not sure that's public yet.) My search-foo was not sufficient to find this post. best,
