Skip to content
View in the app
Armbian Community Forums
Wrong temperature reading Orange Pi zero 2
Featured Replies
I've tinkering with this board, and trying to boot from spl, but the boot halts after reading the temperature sensors, which does not happen when booting from the sd card.
After booting from the sd card I read the sensor that causes the problem
# cat /sys/devices/virtual/thermal/thermal_zone0/temp
51740
I found in a forum some kernel patches to mitigate this: https://forum.manjaro.org/t/support-for-orangepi-zero2-h616-ddr3-zero3-and-zero-2w-h618-lpddr4/154679
Why does it fail when booting from spl, and not when booting from the sd?
Here is the system info:
Quote
# armbianmonitor -m
Stop monitoring using [ctrl]-[c]
Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
23:48:42  1512 MHz  0.00   3%   1%   1%   0%   0%   0%  51.8 °C  0/5
23:48:48   480 MHz  0.00   0%   0%   0%   0%   0%   0%  51.0 °C  0/5
23:48:53   480 MHz  0.00   0%   0%   0%   0%   0%   0%  51.9 °C  0/5^C
# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepizero2
BOARD_NAME="Orange Pi Zero2"
BOARDFAMILY=sun50iw9
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=89476e86f
LINUXFAMILY=sunxi64
ARCH=arm64
BOOT_SOC=
IMAGE_TYPE=stable
BOARD_TYPE=wip
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
KERNEL_TARGET=current,edge
KERNEL_TEST_TARGET=current
FORCE_BOOTSCRIPT_UPDATE=yes
FORCE_UBOOT_UPDATE=
OVERLAYDIR="/boot/dtb/allwinner/overlay"
VENDOR="Armbian"
VENDORDOCS="https://docs.armbian.com"
VENDORURL="https://www.armbian.com/"
VENDORSUPPORT="https://forum.armbian.com"
EDIT: I am booting the same install in both cases from the sd card, but from the spl I do it manually since I have to take the sd card out to get into the spl
VENDORBUGS="https://www.armbian.com/bugs"
BOOTSCRIPT_FORCE_UPDATE="yes"
BOOTSCRIPT_DST="boot.cmd"
VERSION=24.8.4
REVISION=24.8.4
BRANCH=current
# uname -r
6.6.36-current-sunxi64
Edited by silajim
  • Author
14 minutes ago, robertoj said:
Can you step back in armbian images until you find a linux version that doesn't show this problem?
I could to kernels I suppose, but not full images
13 minutes ago, SteeMan said:
Do you have the same uboot installed to spi as you have on the sd?
No, the sd has  2024.01-armbian-2024.01-S866c-P7079-Ha9af-V2dce-Bda0a-R448a while the spl 2024.07 . I guess I could maybe copy the sd one into the spi? But would it boot the usb? How would I even extract the uboot?
Edited by silajim
I meant to only change the kernel.
I have never modified any of my SPI flash orange pis, because I fear bricking them.
  • Author
1 hour ago, SteeMan said:
I suspect that is your answer as to why one boots and the other doesn't when using the same kernel
Yeah, I found the original uboot under /usr/lib and also compiled it from the source using armbian build, but it seems it's built without env support. Any ideas on how to enable it? I need to extend the usb init timeout so the external ssd has time to initialize.
EDIT: nevermind, setting usb_pgood_delay to 10000 instead of 1000 fixed the issue
EDIT2 : for future reference:
remove sdcard if any, remove 1 jumper lead, rember where it was (it's needed to boot the device into FEL mode)
connect serial adapter to board, with 115200 baud
connect usb-c to computer (if working in a VM pass the allwinner device to the VM)
go to the latest official build, extract it and under it go to: {extracted_path}/usr/lib/linux-u-boot-current-orangepizero2 or simmilar u-boot path
use: "sudo sunxi-fel -v -p spiflash-write 0 u-boot-sunxi-with-spl.bin" to write u-boot into device
reconnect the previusly removed jumper lead (this allow for the device to boot from it's memory chip also known as SPI)
restart the device and monitor the serial (tty) output
if it fails to detect the usb ssd, increase the usb_pgood_delay envoiroment variable using the serial console:
	editenv usb_pgood_delay
		-> input a number, bigger than the exsting (ms)
	saveenv
if it boots succefully, remove serial cables and close
Edited by silajim
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
