Skip to content
View in the app
Armbian Community Forums
Can't get usb wifi driver installed (cant get linux headers)
Featured Replies
  • Author
@going
out put off the command:
johan@rk322x-box:~$ sudo apt-get install build-essential git dkms
Reading package lists... Done
Building dependency tree... Done
build-essential is already the newest version (12.10ubuntu1).
git is already the newest version (1:2.43.0-1ubuntu7.1).
dkms is already the newest version (3.0.11-1ubuntu13).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
johan@rk322x-box:~$
  • Author
@going
Im still getting no such file directory when i run the first command in this instruction could that be the problem
How to install
sudo apt-get install build-essential git dkms linux-headers-$(uname -r)
git clone https://github.com/kelebek333/rtl8188fu
sudo dkms install ./rtl8188fu
sudo cp ./rtl8188fu/firmware/rtl8188fufw.bin /lib/firmware/rtlwifi/
Configuration
Disable Power Management
Run following commands for disable power management and plugging/replugging issues.
sudo mkdir -p /etc/modprobe.d/
sudo touch /etc/modprobe.d/rtl8188fu.conf
echo "options rtl8188fu rtw_power_mgnt=0 rtw_enusbss=0 rtw_ips_mode=0" | sudo tee /etc/modprobe.d/rtl8188fu.conf
Disable MAC Address Spoofing
Run following commands for disabling MAC Address Spoofing (Note: This is not needed on Ubuntu based distributions. MAC Address Spoofing is already disable on Ubuntu base).
sudo mkdir -p /etc/NetworkManager/conf.d/
sudo touch /etc/NetworkManager/conf.d/disable-random-mac.conf
echo -e "[device]\nwifi.scan-rand-mac-address=no" | sudo tee /etc/NetworkManager/conf.d/disable-random-mac.conf
Blacklist (alias) for kernel 5.15 and 5.16 (No needed for kernel 5.17 and up)
If you are using kernel 5.15 and 5.16, you must create a configuration file with following command for preventing to conflict rtl8188fu module with built-in r8188eu module.
echo 'alias usb:v0BDApF179d*dc*dsc*dp*icFFiscFFipFFin* rtl8188fu' | sudo tee /etc/modprobe.d/r8188eu-blacklist.conf
Blacklist (alias) for kernel 6.2 and up
If you are using kernel 6.2 and up, you must create a configuration file with following command for preventing to conflict rtl8188fu module with built-in rtl8xxxu module.
echo 'alias usb:v0BDApF179d*dc*dsc*dp*icFFiscFFipFFin* rtl8188fu' | sudo tee /etc/modprobe.d/rtl8xxxu-blacklist.conf
Then you must update initramfs
For initramfs
sudo update-initramfs -u
For dracut
sudo dracut -q --force
Enable rtl8188fu module
how do I install these drivers for my wifi chip
  • Author
this is the output of the 3 lines that you said i need to install this is the last deb line.
johan@rk322x-box:~/debs$ sudo dpkg -i linux-image-edge-rockchip_24.11.0-trunk_ar        mhf__6.11.4-S1736-D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb
(Reading database ... 175770 files and directories currently installed.)
Preparing to unpack linux-image-edge-rockchip_24.11.0-trunk_armhf__6.11.4-S1736-        D29ea-P86b9-C85f2H5c21-HK01ba-V014b-Ba3b7-R448a.deb ...
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'prerm' starting        .
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'prerm' finishin        g.
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' starti        ng.
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'preinst' finish        ing.
Unpacking linux-image-edge-rockchip (24.11.0-trunk) over (24.11.0-trunk) ...
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postrm' startin        g.
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postrm' finishi        ng.
Setting up linux-image-edge-rockchip (24.11.0-trunk) ...
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' start        ing.
 * dkms: running auto installation service for kernel 6.11.4-edge-rockchip
 * dkms: autoinstall for kernel 6.11.4-edge-rockchip                     [ OK ]
update-initramfs: Generating /boot/initrd.img-6.11.4-edge-rockchip
W: Possible missing firmware /lib/firmware/mrvl/sdiouart8997_combo_v4.bin for bu        ilt-in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdsd8997_combo_v4.bin for built-        in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8987_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdiouartiw416_combo_v0.bin for b        uilt-in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdsd8977_combo_v2.bin for built-        in driver mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8887_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8897_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8801_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8797_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8787_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8786_uapsta.bin for built-in d        river mwifiex_sdio
W: Possible missing firmware /lib/firmware/rt73.bin for built-in driver rt73usb
W: Possible missing firmware /lib/firmware/bfubase.frm for built-in driver bfusb
W: Possible missing firmware /lib/firmware/intel/ibt-12-16.ddc for built-in driv        er btintel
W: Possible missing firmware /lib/firmware/intel/ibt-12-16.sfi for built-in driv        er btintel
W: Possible missing firmware /lib/firmware/intel/ibt-11-5.ddc for built-in drive        r btintel
W: Possible missing firmware /lib/firmware/intel/ibt-11-5.sfi for built-in drive        r btintel
W: Possible missing firmware /lib/firmware/mrvl/sdsd8997_combo_v4.bin for built-        in driver btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8987_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sdsd8977_combo_v2.bin for built-        in driver btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8897_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8887_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8797_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8787_uapsta.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8688.bin for built-in driver b        tmrvl_sdio
W: Possible missing firmware /lib/firmware/mrvl/sd8688_helper.bin for built-in d        river btmrvl_sdio
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_fw_v2.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852cu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852btu_config.bin for buil        t-in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852btu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852au_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8852au_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8851bu_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8851bu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821cs_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821cs_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821a_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8821a_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761bu_config.bin for built        -in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761bu_fw.bin for built-in        driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761b_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761b_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761a_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8761a_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723d_config.bin for built-        in driver btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723d_fw.bin for built-in d        river btrtl
W: Possible missing firmware /lib/firmware/rtl_bt/rtl8723a_fw.bin for built-in d        river btrtl
update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.11.4-edge-rockchip
Image Name:   uInitrd
Created:      Tue Oct 22 21:03:27 2024
Image Type:   ARM Linux RAMDisk Image (gzip compressed)
Data Size:    14944180 Bytes = 14593.93 KiB = 14.25 MiB
Load Address: 00000000
Entry Point:  00000000
update-initramfs: Armbian: Symlinking /boot/uInitrd-6.11.4-edge-rockchip to /boot/uInitrd
'/boot/uInitrd' -> 'uInitrd-6.11.4-edge-rockchip'
update-initramfs: Armbian: done.
Armbian: update last-installed kernel symlink to 'zImage'...
'/boot/zImage' -> 'vmlinuz-6.11.4-edge-rockchip'
Armbian: Debian compat: linux-update-symlinks install 6.11.4-edge-rockchip boot/vmlinuz-6.11.4-edge-rockchip
Armbian 'linux-image-edge-rockchip' for '6.11.4-edge-rockchip': 'postinst' finishing.
  • Author
@going
Im trying a method on the armbian forum as follows.
I made the line bold that I should change to my version where can I find out.
4. For the USB dongle with RTL8188FTV :
git clone https://github.com/kelebek333/rtl8188fu.git
cd rtl8188fu
we need to change some EXTRA_CFLAGS too and I think it is self explanatory, just add the missing lines, remove #:
nano Makefile
EXTRA_CFLAGS += -Wno-error=incompatible-pointer-types
EXTRA_CFLAGS += -Wno-incompatible-pointer-types
EXTRA_CFLAGS += -Wno-vla
EXTRA_CFLAGS += -Wno-error=date-time
(exit with ctrl+x)
And now second difference form post above - we use different image so we have lib/modules/5.3.0-aml-g12 but we can use uname -r
make ARCH=arm64 KSRC=../Amlogic_s905-kernel CONFIG_POWER_SAVING=n
sudo install -p -m 644 rtl8188fu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
/sbin/depmod -a
sudo modprobe rtl8188fu
  • Author
@going
we have done it finally.
wlx00e0372f872e: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.141  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::5acf:cb45:6c14:ce63  prefixlen 64  scopeid 0x20<link>
        ether 00:e0:37:2f:87:2e  txqueuelen 1000  (Ethernet)
        RX packets 100  bytes 14923 (14.9 KB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 112  bytes 11935 (11.9 KB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
Dont know what it was but when i used nmuti I saw my wifi and network.
thank you soooo much im very happy now.
now if I can only restore android back to this box i still dont know how to convert the gz file to a img i managed to decompress it folder is showing 7.8gig so that I can install arbian on a mxq box because it has more usb ports
again thannnnnnkkk youuuuuuu for all the patience
  • Author
@going
okay small problem but not that big
everytime after shut down or reboot it disconnects the wifi and i need to connect again with nmuti how can I set it so it always connects and I dont have to do it manually because now I have to plug in the lan the connect wifi and can then remove the lan
  • Author
@going
okay deeper in the disconnecting
to get wifi again if i reboot or shut down I need to plug in the lan cable remove usb the wifi is back up I tried by only removing the usb and plug it back in with out lan cable but then still no wifi its as if i need to add the lan cable then remove dongle then reinsert to get wifi back.
I however don't need to go in to nmuti to connect again.
13 часов назад, JOHAN VAN DER MERWE сказал:
There are several ways to force a WIFI-USB device to be detected in the OS.
You can write and add a node to the DTS. That is, to use an overlay.
You can write a rule and add it to the initialization scripts.
Or a combination of these methods.
Please reach out to people who have already succeeded in this.
There are publications on this topic here on the forum.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
