Skip to content
View in the app
Armbian Community Forums
Orange Pi Zero 3 ili9486 TFT LCD
Featured Replies
Solved by WDR_s
20 hours ago, Sári Zoltán said:
Paste your custom overlay configuration for SPI, DC, and reset GPIOs
Share your DTS. It is the most challenging part of this. We can customize, based on SBC model.
In my first post, I shared it in a file called "spi-display-overlay.txt".
Yes, I know it’s strange that it’s in a .txt file — but it’s there nonetheless.
But you know what? Here it is :) :
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";  /* Orange Pi Lite SoC */
    fragment@0 {
        target = <&spi0>;  /* SPI0 bus */
        __overlay__ {
            status = "okay";
    fragment@1 {
        target = <&spi0>;
        __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            ili9486: ili9486@0 {
                compatible = "ilitek,ili9486";
                reg = <0>;  /* CS0 */
                spi-max-frequency = <24000000>;  /* Speed of SPI */
                rotate = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
                bgr = <0>;
                reset-gpios = <&pio 2 8 1>; /* PC08 */
                dc-gpios = <&pio 2 7 0>;     /* PC07 */
                init = <0x10000b0 0x00
                        0x1000011
                        0x20000ff
                        0x100003a 0x55
                        0x1000036 0x28
                        0x10000c2 0x44
                        0x10000c5 0x00 0x00 0x00 0x00
                        0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00
                        0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00
                        0x1000036 0x28
                        0x1000011
                        0x1000029>;
Edited by Sári Zoltán
Thank you for sharing it :)
Can you include these specifications, for quick reference for future readers?
Board, Debian version, Kernel, Graphics (console, X11, wayland)
Hi @robertoj and @WDR_s
I am having a similar screen ILI9486 from waveshare that i am trying to make it work with Milk-v duo S board.
https://www.waveshare.com/wiki/3.5inch_RPi_LCD_(B)
I was able to drive ST7789v and see content on screen with below code dts file
&spi3 {
        status = "okay";
        /delete-node/ spidev@0;
        st7789v: st7789v@0 {
                compatible = "sitronix,st7789v";
                reg = <0>;
                spi-max-frequency = <48000000>;
                spi-cpol;
                spi-cpha;
                rotate = <0>;
                fps = <60>;
                rgb;
                buswidth = <8>;
                dc = <&porta 18 GPIO_ACTIVE_HIGH>;
                reset = <&porta 28 GPIO_ACTIVE_HIGH>;
                debug = <0x0>;
                status = "okay";
But trying to make ILi9486 work is next to impossible for me.
I tried the dts file modification that worked for @WDR_s before he implemented touch. But this also does not work for me. And just for information dc-gpios and reset-gpios does not work for me and i have to name it dc and reset or else device  /dev/fb0 is not created.
&spi3 {
    status = "okay";
    #size-cells = <0>;
        /* IMPORTANT: fb_tft binds MUCH more reliably to this */
        compatible = "ilitek,ili9341";
        reg = <0>;
        status = "okay";
        /* SPI MODE 0 (correct for Waveshare ILI9486) */
        /* Use SAME pins that worked for ST7789V */
        rotate   = <0>;
        bgr      = <0>;
        fps      = <30>;
        regwidth = <16>;
        buswidth = <8>;
        txbuflen = <65536>;
        debug    = <3>;
        /* Long, safe init sequence */
                0x1000011
                0x20000ff
                0x10000C0 0x0D 0x0D
                0x10000C1 0x43
                0x10000C5 0x00 0x48 0x80
                0x10000C7 0x00
                0x1000036 0x28
                0x100003A 0x55
                0x10000B1 0xB0 0x11
                0x10000F0 0x01
                0x10000F6 0x00 0x01 0x32
                0x1000026 0x01
                0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00
                0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F
                0x10000B6 0x02 0x02 0x3B
                0x1000011
                0x20000ff
                0x1000029>;
This is very critical for me and i would really appreciate if you could make things work for me. Is the kernel 5.10 a issue here? as my SPI pins work for other display but not just for this display.
@robertoj
Can I use your DTS to connect to my Orange Pi Zero 3 and 3.95" ILI9488 display? What issues might I encounter? Can I use the pins described in the DTS file?
I've read your comments on this forum thread.
It's described almost everywhere: you just need to change the driver name in the file and overwrite the pins with the ones used in the wiring. Are there any potential issues with using this method?
I buy this display
https://aliexpress.ru/item/1005004152942022.html?spm=a2g2w.orderdetail.0.0.12a44aa6BVhy8J&sku_id=12000028212240707&_ga=2.111843779.691992273.1764584312-1605484087.1719427130
Edited by Orima
@Michael Robinson I want to make a cyberdeck with this display and this single board computer
The ports are supposed to be used for connecting peripherals. That's why I want to know if my project is viable, or if I should look for something else.
No, it wont work.
I have made another thread just for the orange pi zero 3 and ili9488
https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#comment-208446
Change the GPIOs to match your wiring and connections.
I don't own any waveshare LCD.
I am not sure what to suggest, except that I believe it will only work with a "ili9486_DRM" (can't remember the exact name) driver ko.
It is made explicitly for waveshare SPI LCDSs, and you must activate within the armbian build script process.
6 minutes ago, Bhupiister singh said:
What about your experience with ST7796? I have one with red pcb. Even this one is not working for me. Tried different dtb and .c files.
Did this work for you ever?
I only have RED ili9341, ili9486 and ili9488
I don't have time to look right now, but search the Raspberry Pi forum and there's a nice thread with just the RED LCDs, st77** and iliteks working with panel-mipi-dbi driver
Then, when you find a solution over there, post the link here.
Your objective is MilkV Duo S with Waveshare ili9488 LCD, right?
Edited by robertoj
I tried two methods with ili9341 and ili9488 with 9341, when checking SPI, it returned the log below. The second method showed that spi-dev0.0 is my FullHD HDMI display. After turning it on, SPI-dev detected the connection, but the screen was still white.
True, I didn’t change the rotate line for 9488
I soldered the pins according to the DST file
OrangePi Zero 3 -> ILI9341 LCD connections
SPI CLOCK = PH6
SPI DO (LCD MISO) = PH8 (OPIZ MISO)
SPI DI (LCD MOSI) = PH7 (OPIZ MOSI)
LCD DATA/CONTROL = PC8
LCD RESET = PC10
CHIP SELECT = PH9 < NOT USED ANYMORE ;)
VCC = 3.3V PIN
GND = GND PIN
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5";
	fragment@0 {
	    target = <&pio>;
	    __overlay__{
	        display_pins: display_pins {
                    pins = "PC8", "PC10"; /* DC, reset pins*/
                    function = "gpio_out", "gpio_out";
	fragment@1 {
        target = <&spi1>;
        __overlay__ {
            /* needed to avoid dtc warning */
            #size-cells = <0>;
            status="okay";
            pinctrl-names = "default";
            pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */
            /*cs-gpios = <&pio 0 13 0>;  /* PA13 chip select NOT USED! */
            num-chipselects = <0>;
            display: display@0 {
                /*compatible = "ilitek,ili9488";*/
                reg = <0>;
                pinctrl-1 = <&display_pins>;
                spi-max-frequency = <40000000>;
                rotate = <270>; /* rotate for ili9341, rotation for yx240qv29 */
                bgr=<0>;
                fps = <15>;
                buswidth = <8>;
                height = <320>;
                width = <240>;
                reset-gpios = <&pio 2 10 0>; /* PC10 reset pin*/
                dc-gpios = <&pio 2 8 0>; /* PC8 Data control pin */
                debug = <3>;
                        0x1000011
			0x20000ff
			0x100003a 0x55
			0x1000036 0x28
			0x10000c2 0x44
			0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00
			0x1000036 0x28
			0x1000011
			0x1000029>;
    __overrides__ {
        rotate =  <&display>,"rotate:0";
        fps =     <&display>,"fps:0";
        debug =   <&display>,"debug:0";
user@orangepizero3:~$ dmesg|grep spi
[    1.899568] sun6i-spi 5011000.spi: chipselect 0 already in use
[    1.899578] spi_master spi1: spi_device register error /soc/spi@5011000/spidev@0
[    1.899601] spi_master spi1: Failed to create SPI device for /soc/spi@5011000/spidev@0
[    6.735454] SPI driver fb_ili9341 has no spi_device_id for ilitek,ili9341
[    6.735562] fb_ili9341 spi1.0: fbtft_property_value: width = 240
[    6.735571] fb_ili9341 spi1.0: fbtft_property_value: height = 320
[    6.735577] fb_ili9341 spi1.0: fbtft_property_value: buswidth = 8
[    6.735583] fb_ili9341 spi1.0: fbtft_property_value: debug = 3
[    6.735589] fb_ili9341 spi1.0: fbtft_property_value: rotate = 270
[    6.735595] fb_ili9341 spi1.0: fbtft_property_value: fps = 15
[    6.735669] fb_ili9341 spi1.0: fbtft_gamma_parse_str() str=
[    6.735674] fb_ili9341 spi1.0: 1F 1A 18 0A 0F 06 45 87 32 0A 07 02 07 05 00
[    6.735764] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'reset' GPIO
[    6.735785] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'dc' GPIO
[    6.735805] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'rd' GPIO
[    6.735820] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'wr' GPIO
[    6.735834] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'cs' GPIO
[    6.735849] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'latch' GPIO
[    6.735864] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.735879] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.735894] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.735909] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.735924] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.735938] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.735953] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.735968] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.735982] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.735997] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736013] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736049] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736064] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736078] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736101] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736116] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736131] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736146] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736161] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736176] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736212] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736227] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736242] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736256] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736271] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736286] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736301] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736315] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736330] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736345] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736360] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736375] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736389] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736404] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736419] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736434] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736449] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736463] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736478] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736493] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736507] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736522] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736537] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736552] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736567] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736581] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'db' GPIO
[    6.736596] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'led' GPIO
[    6.736610] fb_ili9341 spi1.0: fbtft_request_one_gpio: 'aux' GPIO
[    6.736616] fb_ili9341 spi1.0: fbtft_verify_gpios()
[    6.736627] fb_ili9341 spi1.0: fbtft_reset()
[    6.864274] fb_ili9341 spi1.0: init: write_register:
[    6.864300] fb_ili9341 spi1.0: buf[0] = B0
[    6.864306] fb_ili9341 spi1.0: buf[1] = 00
[    6.864541] fb_ili9341 spi1.0: init: write_register:
[    6.864546] fb_ili9341 spi1.0: buf[0] = 11
[    6.864568] fb_ili9341 spi1.0: init: msleep(255)
[    7.144245] fb_ili9341 spi1.0: init: write_register:
[    7.144271] fb_ili9341 spi1.0: buf[0] = 3A
[    7.144281] fb_ili9341 spi1.0: buf[1] = 55
[    7.144365] fb_ili9341 spi1.0: init: write_register:
[    7.144370] fb_ili9341 spi1.0: buf[0] = 36
[    7.144375] fb_ili9341 spi1.0: buf[1] = 28
[    7.144410] fb_ili9341 spi1.0: init: write_register:
[    7.144414] fb_ili9341 spi1.0: buf[0] = C2
[    7.144419] fb_ili9341 spi1.0: buf[1] = 44
[    7.144447] fb_ili9341 spi1.0: init: write_register:
[    7.144452] fb_ili9341 spi1.0: buf[0] = C5
[    7.144456] fb_ili9341 spi1.0: buf[1] = 00
[    7.144461] fb_ili9341 spi1.0: buf[2] = 00
[    7.144466] fb_ili9341 spi1.0: buf[3] = 00
[    7.144470] fb_ili9341 spi1.0: buf[4] = 00
[    7.144519] fb_ili9341 spi1.0: init: write_register:
[    7.144524] fb_ili9341 spi1.0: buf[0] = E0
[    7.144529] fb_ili9341 spi1.0: buf[1] = 0F
[    7.144533] fb_ili9341 spi1.0: buf[2] = 1F
[    7.144537] fb_ili9341 spi1.0: buf[3] = 1C
[    7.144542] fb_ili9341 spi1.0: buf[4] = 0C
[    7.144547] fb_ili9341 spi1.0: buf[5] = 0F
[    7.144551] fb_ili9341 spi1.0: buf[6] = 08
[    7.144555] fb_ili9341 spi1.0: buf[7] = 48
[    7.144560] fb_ili9341 spi1.0: buf[8] = 98
[    7.144564] fb_ili9341 spi1.0: buf[9] = 37
[    7.144569] fb_ili9341 spi1.0: buf[10] = 0A
[    7.144574] fb_ili9341 spi1.0: buf[11] = 13
[    7.144579] fb_ili9341 spi1.0: buf[12] = 04
[    7.144583] fb_ili9341 spi1.0: buf[13] = 11
[    7.144588] fb_ili9341 spi1.0: buf[14] = 0D
[    7.144592] fb_ili9341 spi1.0: buf[15] = 00
[    7.144627] fb_ili9341 spi1.0: init: write_register:
[    7.144632] fb_ili9341 spi1.0: buf[0] = E1
[    7.144636] fb_ili9341 spi1.0: buf[1] = 0F
[    7.144641] fb_ili9341 spi1.0: buf[2] = 32
[    7.144646] fb_ili9341 spi1.0: buf[3] = 2E
[    7.144650] fb_ili9341 spi1.0: buf[4] = 0B
[    7.144655] fb_ili9341 spi1.0: buf[5] = 0D
[    7.144659] fb_ili9341 spi1.0: buf[6] = 05
[    7.144663] fb_ili9341 spi1.0: buf[7] = 47
[    7.144668] fb_ili9341 spi1.0: buf[8] = 75
[    7.144672] fb_ili9341 spi1.0: buf[9] = 37
[    7.144677] fb_ili9341 spi1.0: buf[10] = 06
[    7.144681] fb_ili9341 spi1.0: buf[11] = 10
[    7.144686] fb_ili9341 spi1.0: buf[12] = 03
[    7.144690] fb_ili9341 spi1.0: buf[13] = 24
[    7.144695] fb_ili9341 spi1.0: buf[14] = 20
[    7.144699] fb_ili9341 spi1.0: buf[15] = 00
[    7.144732] fb_ili9341 spi1.0: init: write_register:
[    7.144736] fb_ili9341 spi1.0: buf[0] = E2
[    7.144741] fb_ili9341 spi1.0: buf[1] = 0F
[    7.144746] fb_ili9341 spi1.0: buf[2] = 32
[    7.144750] fb_ili9341 spi1.0: buf[3] = 2E
[    7.144755] fb_ili9341 spi1.0: buf[4] = 0B
[    7.144759] fb_ili9341 spi1.0: buf[5] = 0D
[    7.144763] fb_ili9341 spi1.0: buf[6] = 05
[    7.144768] fb_ili9341 spi1.0: buf[7] = 47
[    7.144772] fb_ili9341 spi1.0: buf[8] = 75
[    7.144777] fb_ili9341 spi1.0: buf[9] = 37
[    7.144781] fb_ili9341 spi1.0: buf[10] = 06
[    7.144786] fb_ili9341 spi1.0: buf[11] = 10
[    7.144790] fb_ili9341 spi1.0: buf[12] = 03
[    7.144795] fb_ili9341 spi1.0: buf[13] = 24
[    7.144799] fb_ili9341 spi1.0: buf[14] = 20
[    7.144804] fb_ili9341 spi1.0: buf[15] = 00
[    7.144836] fb_ili9341 spi1.0: init: write_register:
[    7.144841] fb_ili9341 spi1.0: buf[0] = 36
[    7.144846] fb_ili9341 spi1.0: buf[1] = 28
[    7.144873] fb_ili9341 spi1.0: init: write_register:
[    7.144878] fb_ili9341 spi1.0: buf[0] = 11
[    7.144895] fb_ili9341 spi1.0: init: write_register:
[    7.144899] fb_ili9341 spi1.0: buf[0] = 29
[    7.180777] fb_ili9341 spi1.0: Display update: 4186 kB/s, fps=0
[    7.181166] graphics fb1: fb_ili9341 frame buffer, 320x240, 150 KiB video
@РобертсSorry, I didn't have time to read your reply. I tried Pancake's instructions, but I got stuck at the Armbian image build stage. Would his method work on the Armbian image that comes with the Orange Pi Zero3 board? I think I've figured out which pins I need to solder so I don't have to change the GPIOs in the file, as I'm not very good at deciphering pins for configuration.
Thank you very much for the information and your efforts. I'll try to give it a try tomorrow and give you an answer.
Deactivate spi-dev in the armbian-config.
That DTS is only used if you want to run a userspace program to talk to the LCD.
In this case, we want the linux kernel to talk to the LCD, so we only need to use the LCD driver (ideally not a FBTFT. DRM is preferred)
@robertoj My objective is MilkV Duo S with Waveshare ili9486 LCD, and it will be much better if I can use ST7796, as this is a 4-inch display.
I need to make at least a 4-inch display work for my project. It can be any readily available display.
There's a 4 inch RED ili9488 in aliexpress. VERY RECOMMENDED.
It may be shown as ili9486, correctly or incorrectly, but it doesn't matter. I have seen both ili9486 and ili9486 work with the same panel-mipi-dbi driver, settings and init firmware.
At least in orange pi zero 3, some pins worked fine for GPIO and others didn't.
Also make sure to use the default chip selects in your MilkV Duo 5, and not try to change that.
Also share what Armbian and Linux version you are using.
Edited by robertoj
Making it work with panel-mipi-dbi is completely new to me. I hope ill be able to make sense out of it.
At this time, panel-mipi-dbi is the most universal way of using these SPI LCDs. Even the Raspberry community gets this recommendation (except for Waveshare LCDs).
Bhupiister, does the MilkV Duo S really have 512MB RAM? How do you deal with that?
I have used an orange pi zero LTS with 512MB of RAM with LXDE desktop in the past, but only with lightweight GUI applications.
Does it really have a useful TPU?
Edited by robertoj
My intention is not to put the whole desktop on the display. Just a user application. I am trying to build a thermostat and might use LVGL for it. I tried a similar project on 256MB and still had plenty of RAM left.
I was able to make 4 inch and 2 inch lcd work
I reported the solution on github too where i was trying to solve it with someone Github link to solution
For 2inch LCD module, i simply followed this link 2 inc LCD
This patch in the above link was important duo-kernel-fb_st7789v.patch
I was also able to make ST7796s 4inch LCD work, I kept the above patch but the init sequence for this display was different, below is the full code
fb_st7796s.c
/linux_5.10/drivers/staging/fbtft/fb_st7796s.c
Spoiler
// SPDX-License-Identifier: GPL-2.0+
 * FB driver for the Sitronix ST7796S LCD Controller
 * Based on fb_st7789v.c and Arduino ST7796S init sequence
 * Modified by Bhupendra Nagra bhupiister@gmail.com
#include <linux/bitops.h>
#include <linux/delay.h>
#include <linux/init.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <video/mipi_display.h>
#include "fbtft.h"
#define DRVNAME "fb_st7796s"
#define MADCTL_MY BIT(7)
#define MADCTL_MX BIT(6)
#define MADCTL_MV BIT(5)
#define MADCTL_BGR BIT(3)
#define MADCTL_ML BIT(4)
 *   ST7796S Initialisation (Adafruit default sequence)
static int init_display(struct fbtft_par *par)
    par->fbtftops.reset(par);
    mdelay(150);
    /* Manufacturer command unlock (same as Arduino) */
    write_reg(par, 0xF0, 0xC3);
    write_reg(par, 0xF0, 0x96);
    /* VCOM Control */
    write_reg(par, 0xC5, 0x1C);
    /* MADCTL (Memory Access Control) */
    write_reg(par, 0x36, 0x00);   /* MX=0, MY=0, MV=0, BGR=1 */
    /* Pixel Format = 16-bit (RGB565) */
    write_reg(par, 0x3A, 0x55);
    /* Interface Mode */
    write_reg(par, 0xB0, 0x80);
    /* Inversion Control */
    write_reg(par, 0xB4, 0x01);
    /* Display Function Control */
    write_reg(par, 0xB6, 0x80, 0x02, 0x3B);
    /* Entry Mode */
    write_reg(par, 0xB7, 0xC6);
    /* Manufacturer command lock (after init) */
    write_reg(par, 0xF0, 0x69);
    write_reg(par, 0xF0, 0x3C);
    /* Exit Sleep */
    write_reg(par, 0x11);
    mdelay(150);
    /* Display ON */
    write_reg(par, 0x29);
    mdelay(150);
    return 0;
 *  Set MADCTL rotation (same orientation rules as Arduino)
static int set_var(struct fbtft_par *par)
    u8 mad = 0;
    switch (par->info->var.rotate) {
    case 0:
        mad = MADCTL_MX | MADCTL_BGR;
        break;
    case 90:
        mad = MADCTL_MV | MADCTL_BGR;
        break;
    case 180:
        mad = MADCTL_MY | MADCTL_ML | MADCTL_BGR;
        break;
    case 270:
        mad = MADCTL_MX | MADCTL_MY | MADCTL_MV | MADCTL_ML | MADCTL_BGR;
        break;
    default:
        return -EINVAL;
    write_reg(par, MIPI_DCS_SET_ADDRESS_MODE, mad);
    return 0;
 *  Display structure
static struct fbtft_display display = {
    .regwidth = 8,
    .width = 320,
    .height = 480,
    .gamma_num = 0,     /* ST7796S does not require gamma tables */
    .gamma_len = 0,
    .fbtftops = {
        .init_display = init_display,
        .set_var = set_var,
FBTFT_REGISTER_DRIVER(DRVNAME, "sitronix,st7796s", &display);
MODULE_ALIAS("spi:" DRVNAME);
MODULE_ALIAS("platform:" DRVNAME);
MODULE_DESCRIPTION("FB driver for the ST7796S LCD Controller");
MODULE_AUTHOR("Custom Port");
MODULE_LICENSE("GPL");
Make entry in the Makefile
obj-$(CONFIG_FB_TFT_ST7796S)     += fb_st7796s.o
Entry in the kconfig
config FB_TFT_ST7796S
    tristate "FB driver for the ST7789V LCD Controller"
    depends on FB_TFT
    help
      This enables generic framebuffer support for the Sitronix ST7796S
      display controller. The controller is intended for small color
      displays with a resolution of up to 320x240 pixels.
      Say Y if you have such a display that utilizes this controller.
Keep modifications made by above patch for this file
/linux_5.10/drivers/staging/fbtft/fbtft-core.c
DTS that works for me
Spoiler
&spi3 {
    status = "okay";
    st7796s:st7796s@0 {
        compatible = "sitronix,st7796s";
        reg = <0>;
        width = <320>;
        height = <480>;
        rotate = <0>;
        buswidth = <8>;
        regwidth = <8>;
        bgr = <1>;
        status = "okay";
I am having issue of the color inversion where RGB is BRG
4 inch preview
305fb013-4359-409e-933c-df55415dd3d1
2 inch preview
251d34ec-e249-4fea-92f4-d3c543eb3e81
Edited by Bhupiister singh
I am glad that you made it work.
However, it looks like you are using another Debian Distro for RiscV, not Armbian (not a bad thing)
I am continuing the conversation over there
I am not using that distro at the moment as its not fulfilling my purpose at the moment so still evaluating. Milk v has a small core for running arduino application and then Linux and arduino can talk, this lets real time task run on small core, which is what i want. That distro is using small core for Image signal processing, which i do not want.
@Робертс
Hi friend, I tried your instructions, but I'm probably doing something wrong. My situation is similar to yours. Could you please tell me step by step what you did to get the screen working? I tried following this article, but it looks like you're using a custom Linux installation.
I watched Pancake's instructions; he's building his own Armbian. I'd really appreciate it if you could give me a step-by-step explanation of how you set up these devices.
I'm using the base Armbian from orangepi version 6.1.31
I also tried this DTS, but had no success with it.
Edited by Orima
Yes, it is a custom Armbian image (no coding needed)
  • Download the Armbian build system from github
  • Select panel-mipi-dbi to be a kernel module (M)
  • Choose Trixie, minimal (the greeter+desktops available in Armbian need to be pure wayland, but the greeter is not)
  • Try the DTS and firmware file again
I will try to explain better tonight
Are you sure you meant Linux 6.1.31? My opiz3 is running 6.13.x or newer
Edited by robertoj
As a reminder: earlier this year, WDR_s had success with the waveshare 9486 LCD, with the ili9341 driver, but that was the fbtft old style driver.
https://forum.armbian.com/topic/46824-orange-pi-zero-3-ili9486-tft-lcd/#findComment-213110
I can't remember whether someone used the adafruit ili9341 driver (DRM) for the Waveshare ili9486/9488 LCD... anyone remembers?
And a success case in the reddit community (warning Raspberry):
https://www.reddit.com/r/raspberry_pi/comments/1lk18a7/comment/mzql8v4/
Edited by robertoj
@robertoj
Hi I'm completely stuck. I'm trying to build an Armbian Trixie image, but I'm having trouble installing packages. I've tried changing the repository links to the ones closest to my location, but to no avail.
I am completely unable to continue my research for assembling Armbian.
This is how I collected Armbian
./compile.sh BOARD=orangepizero3 BRANCH=edge kernel-config CONFIG_DRM_PANEL_MIPI_DBI=m CONFIG_TOUCHSCREEN_EDT_FT5X06=m CONFIG_BACKLIGHT_GPIO=m CONFIG_BACKLIGHT_PWM=m ./compile.sh BOARD=orangepizero3 BRANCH=edge BUILD_DESKTOP=yes BUILD_MINIMAL=yes KERNEL_CONFIGURE=no RELEASE=trixie
Also, with the configurator window open, I selected to enable panel_mipi_dbi
Perhaps you still have an image of the assembled Armbian?
I first built it on Ubuntu 22.04. Later, I built it on Debian Trixie.
I change repo to:
http://ftp.debian.org/debian
And debian security
http://ftp.debian.org trixie-security
For armbian
https://armbian.systemonachip.net/apt
Its not work
Edited by Orima
Orima,
Ubuntu 22.04 is recommended, but I have no problem installing armbian build in Linux Mint 22.0.
I think Debian Trixie in your laptop is too new to have the right requirements and versions for armbian build.
You can build Debian Trixie for your orange pi, with no problems.
Don't try to fill all the parameters in a single command line. Just download the armbian zip, "git clone" it in a new directory. Then run "./compile.sh".
You will be presented with all the text user interfaces to make your board selections, linux and debian versions, etc.
Edited by robertoj
@robertoj
OK. I managed to build Armbian, selecting mipi-panel-dbi support and booting to 16-bit. After setting it up and running the dts you provided, my screen still doesn't work. I'm probably doing something wrong, because although the screen glows white, it still shows barely noticeable backlight flickering.
I also tried to do it according to Pancake's instructions, but I also didn't have any success.
This log with Pancake's
cat log.txt
[ 1.623324] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.173154] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.242555] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
[ 7.591150] systemd[1]: Starting systemd-backlight@backlight:backlight_gpio.service - Load/Save Screen Backlight Brightness of backlight:backlight_gpio...
[ 7.652908] systemd[1]: Finished systemd-backlight@backlight:backlight_gpio.service - Load/Save Screen Backlight Brightness of backlight:backlight_gpio.
user@orangepizero3:~$ hostnamectl
 Static hostname: orangepizero3
       Icon name: computer
      Machine ID: a5f7b63422b54dc5a365def0a7294555
         Boot ID: 4445f89ef8cb4b999e3fa684f292ca2a
Operating System: Armbian-unofficial 26.02.0-trunk bookworm
          Kernel: Linux 6.16.8-edge-sunxi64
    Architecture: arm64
And this log with DTS from you
cat log.txt
[ 1.623908] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.172898] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[ 2.242212] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
But I'm very happy that I managed to build my first Linux, albeit in such a simple way.
My pinout
Displ           OpiZ3
Vcc -            out 3.3v
Gnd -           gnd
Cs -              ph9
Reset -        pc14
Dc/rc -        pc7
Sdi(mosi) - ph7
Sck -           ph4
Led -          5v
Sdo(miso) - ph8
Edited by Orima
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
