Skip to content
View in the app
Armbian Community Forums
Orange Pi Zero 3 ili9486 TFT LCD
Featured Replies
Solved by WDR_s
@robertoj
Thank you very much for your reply! I sincerely apologize for any misunderstanding. When I mentioned the 16-bit option, I was referring to the selection made when setting up the Armbian image. This option is located in the same menu as the mipi_panel_dbi support option.
I mentioned this in my comment because I was a bit confused by the "but the greeter is not" part of your response. I probably just needed to enable the mipi_panel_dbi support parameter and continue building without adding any additional parameters. I use a screen with a red board on the ili9488 driver, the Chinese version for sure.
I'd also like to clarify with someone who's already done this, whether I'm following all the steps correctly. If that's possible, please let me know within this forum thread.
- I'm building a minimal image.
- First, I use the DTS file from the thread you provided as a response.
- After I see the image on the screen, if the colors are incorrect, I use the file provided by Pancake.
Please forgive me again. In the thread you provided as a solution, I don't understand the sequence of actions and where I should start. Once again, I apologize for my meticulousness.
Yes, that is the correct sequence of actions:
1. Build armbian minimal with panel-mipi-dbi kernel module
2. Use DTS so that the kernel links the GPIO, SPI to the panel-mipi-dbi kernel module
3. Use the bin file (originally provided by Kungfu pancake) <-mandatory, not optional
4. If you see console text successfully in the LCD during boot, you have successfully installed your LCD
5. Tell us here, for the next step in GUI installation
The "greeter" is the graphical login screen. Labwc is the wayland-based compositor and window manager (I think).
Edited by robertoj
Hi I was able to build an image with the panel-mipi-dbi module enabled. My previous image had the module disabled, so it took me a couple of days to figure it out. As I found out, for my version of the board, which uses the 618 chip, I needed to adjust a line in the bootconfig to build my board. It specified the 616 chip.
But that's probably not the reason for the success. After I built the image, applied the binary, and dts, the screen was still white after rebooting.
user@orangepizero3:~/v0_ips_touch_display$ cd
user@orangepizero3:~$ sudo modinfo panel-mipi-dbi
filename:       /lib/modules/6.16.8-edge-sunxi64/kernel/drivers/gpu/drm/tiny/panel-mipi-dbi.ko
license:        GPL
author:         Noralf Trønnes
description:    MIPI DBI compatible display panel driver
alias:          of:N*T*Cpanel-mipi-dbi-spiC*
alias:          spi:panel-mipi-dbi-spi
depends:        drm_mipi_dbi,backlight
intree:         Y
vermagic:       6.16.8-edge-sunxi64 SMP preempt mod_unload aarch64
user@orangepizero3:~$ dmesg | grep spi
[    2.466658] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    2.467167] sun6i-spi 5011000.spi: cannot register SPI host
[    2.474140] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    2.474558] sun6i-spi 5011000.spi: cannot register SPI host
[    3.584770] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator
[    3.603713] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator
[    3.603960] panel-mipi-dbi-spi spi1.0: Direct firmware load for panel-mipi-dbi-spi.bin failed with error -2
[    3.603975] panel-mipi-dbi-spi spi1.0: No config file found for compatible 'panel-mipi-dbi-spi' (error=-2)
[    3.603983] panel-mipi-dbi-spi spi1.0: probe with driver panel-mipi-dbi-spi failed with error -2
[   12.001666] OF: /soc/spi@5011000/ads7846@1: Read of boolean property 'ti,swap-xy' with a value.
[   12.001860] ads7846 spi1.1: supply vcc not found, using dummy regulator
[   12.004761] ads7846 spi1.1: touchscreen, irq 77
[   12.007680] input: ADS7846 Touchscreen as /devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input10
[   12.018707] spi-nor spi0.0: supply vcc not found, using dummy regulator
[   12.018953] spi-nor spi0.0: supply vdd not found, using dummy regulator
Can you clarify that you made a custom H618 board :) ?? (not exactly Orange Pi Zero 3?).
If I remember correctly, you had previous success with an ili9341 and the same linux board?
You need to compare the DTS that worked for you (with ilitek, ili9341, right?) and the new DTS you are trying to modify (with panel-mpi-dbi, for ili9488).
Make sure you haven't changed the GPIO in the DTS, and the connections in the LCD and your Linux board.
If the ili9341 was working for you with the H616 armbian configuration, changing to H618 might need changes in the LCD DTS from that change.... to make those SPI pins to be addressed correctly.
That previous H616 armbian configuration... what Linux board was it meant for?
Change back to the configuration that made your board work with the ili9341.
Good afternoon. Thank you for your reply. Unfortunately, I haven't had a positive experience. My apologies for misleading you, but my motherboard originally had a 618 processor. I tried creating an image for the 616 many times until I noticed that my processor was a 618. After several attempts, I was able to create an image for the 618.
After receiving an image for the 618 with the panel-mipi-dbi module, I tried connecting a screen with an ili9488 chip. I can say I've taken the first step toward implementing this project. Now I need to get the screen working with the resulting image.
Sorry, I've never done anything like this before. I tried setting it up according to instructions in various GitHub threads, but it always failed. You're the only person who helps me with advice, and thanks to you, I've only been able to build an image with the required kernel module. I haven't achieved anything else, except for the white screen.
I was able to get it out. I'm pretty good at Linux, but not at screens. Maybe I'm missing something?
All this time, I thought you were using a custom H618 board hardware. Now it is clear to me, that you  have an Orange Pi Zero 3,
In armbian build, make sure you don't add any configuration files. Just do "./compile.sh" and when you get the menu for board selection, press the button "Unsupported/CSC" (or something like that).
The text menu will turn red. Press OK and you will see a list of more Linux boards. Press "P" to quickly scroll down, then "UP" to find Orange Pi Zero 3.
Then choose the option for Linux edge, and choose that you want to configure linux.
Thank you very much for your reply. That's exactly what I did. I have a custom Armbian image. When compiling, I selected my board for the 618 processor, as I couldn't find it in the standard section. I also found the panel-mipi-dbi parameter in the module selection menu. However, after compiling, writing the image to the flash card, and checking the module, the system didn't find it.
I was able to build the image and include the module after correcting the boardconfig. It may have mistakenly listed the 616 processor, but I changed it to 618, and the image built successfully. After writing it to a flash drive and checking it in the system, I was finally able to find the required module. It was also displayed in the /boot/config(uname) configuration file.
If you use your own boardconfig file, or edit another boardconfig file, you may be missing some configs or device tree overlay, and make problems in configuring SPI and GPIO pins.
I always use boardconfig that's included in armbian-build, specifically for Orange Pi Zero 3, by following the text menu, and not editing any file.
Edited by robertoj
I'll try building the image again today with a new git clone, without changing anything except the userpatchers configuration. If I don't add the module this way, it won't be enabled in the text menu. I'll report back on my progress later.
I'll try building the image again today with a new git clone, without changing anything except the userpatchers configuration. If I don't add the module this way, it won't be enabled in the text menu. I'll report back on my progress later.I created an image without changing the boardconfig. I used the default configuration for userpatches, which is used for compilation. I added one line, CONFIG_DRM_PANEL_MIPI_DBI=m, and the image built successfully. Afterwards, I booted and checked the kernel module with the command modinfo panel-mipi-dbi; the module is enabled. I also checked the configuration in /boot/config(umane); the module is enabled there too.
I added DTS with the command sudo armbian-add-overlay , and also added the binary from the Pancake repo. After rebooting, the result didn't change at all; the screen was white. The output of dmesg | grep spi shows the same as in the previous post.
I'm not sure about the pinout. Could you send me your pinout? What awg wires are you using? I use a combination of 28awg for VCC, DC, and GND, and 32awg for the rest.
Edited by Orima
@robertoj
Hello.
I was able to get some DuPont wires and test them directly without soldering. The result was zero. I tried using ChatGPT to get it working.He suggests that my display isn't initializing. In some cases, it's either that the reset isn't working, or that the frequency is too high for a Chinese display. I tried using fbtft, but the result was zero. I followed your configuration and pinout. Are there any steps I might have missed?
Is your LCD at least turning white on powerup? Did you connect the "LED" pin in the LCD, to 3.3V?
Send a drawing of how you are connecting the LCD to the orange pi zero 3.
@Робертс
My screen is constantly white. Here's my wiring diagram.
Display-Orangepi zero 3
VCC-5v
GND-GND
CS-PH9(spi1)
RST-PC14
D/C-PC7
SDI-PH7(mosi)
SCK-PH4
BL-3.3v
SDO-PH8(miso)
Also, there might be a typo. The specified dc-gpio in your dts is described as PHC7. I don't quite understand, is it PC7 or PH7?
Edited by Orima
@Робертс
I've been following this pinout from the very beginning, but I'm having trouble setting it up. I think I should wait for instructions from you, which you might create. I would be incredibly happy and grateful if you could provide a step-by-step description of the steps for setting up the Chinese ili9488 display and the OrangePi Zero 3 board.Maybe then I will understand where I am making a mistake.Thank you very much for your patience.
Hello Orima, Thank you for asking. I am doing well. I've been mainly distracted by an online drawing class.
I will try to make a complete written guide in the weekend. It will be a new project in my github, and I will make a new thread here.
Hi!
I have an OrangePi3 (not Zero!) running Armbian (H6), with a TFT ILI9486 display connected via the 26-pin header. The screen works fine, but the XPT2046 touch controller does not initialize.
Here’s the situation:
CS0 on PH5, DC on PD16, RESET on PD21.
XPT2046 (CS1) on PL8, IRQ on PD24.
I tried adding XPT2046 to the overlay with all parameters configured (ti,x/y-min/max, pressure, swap-xy, etc.).
The overlay compiles successfully, but when loading the module it says:
ads7846 spi0.1: probe with driver ads7846 failed with error -22
I also tried loading the ads7846 module with parameters via modprobe — all parameters are ignored because the driver only supports configuration via Device Tree.
Here is my current overlay:
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h6";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 3 0>;
            display: display@0 {
                compatible = "ilitek,ili9341";
                reg = <0>;
                pinctrl-names = "default";
                spi-max-frequency = <20000000>;
                txbuflen = <65536>;
                rotate = <90>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
                height = <480>;
                width = <320>;
                dc-gpios    = <&pio 3 16 0>;
                reset-gpios = <&pio 3 21 1>;
                debug = <3>;
                init = <0x10000b0 0x00 // Interface Mode Control
                        0x1000011  // Sleep Out
                        0x20000ff  // Delay (255ms)
                        0x10000C0 0x0D 0x0D  // Power Control 1
                        0x10000C1 0x43  // Power Control 2
                        0x10000C5 0x00 0x48 0x80  // VCOM Control 1
                        0x10000C7 0x00  // VCOM Control 2
                        0x1000036 0x28  // Memory Access Control (Rotação)
                        0x100003A 0x55  // Pixel Format Set (16bit)
                        0x10000B1 0xB0 0x11  // Frame Rate Control
                        0x10000F0 0x01 // Enable Extended Comand Set
                        0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control
                        0x1000026 0x01 // Gamma Set
                        0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00  // Positive Gamma Correction
                        0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F  // Negative Gamma Correction
                        0x10000B6 0x02 0x02 0x3B  // Display Function Control
                        0x1000029>; // Display ON
           /* --- ADS7846 (XPT2046) --- */
            ads7846: ads7846@1 {
                compatible = "ti,ads7846";
                reg = <1>;
                spi-max-frequency = <1000000>;
                interrupt-parent = <&pio>;
                interrupts = <3 24 2>;
                pendown-gpio = <&pio 3 24 1>;
                cs-gpios = <&pio 11 8 0>;
/* OPTIONS */
                ti,x-min = /bits/ 16 <0>;
                ti,y-min = /bits/ 16 <0>;
                ti,x-max = /bits/ 16 <0xFFF>;
                ti,y-max = /bits/ 16 <0xFFF>;
                ti,pressure-min = /bits/ 16 <0>;
                ti,pressure-max = /bits/ 16 <0xFFF>;
                ti,x-plate-ohms = /bits/ 16 <400>;
                ti,swap-xy = <1>;
Could anyone advise how to properly connect XPT2046 so that PD24 is used as IRQ? Is there a working example overlay for TFT ILI9486 + XPT2046 on OrangePi3 / H6? Or has anyone managed to use the touch controller via a module without overlay? Or is that simply impossible on this kernel?
I would really appreciate any working examples or advice!
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
