December 17, 20241 yr Not an issue nor a bug nor a trouble abour my Orange pi or Armbian. I wanted to build my "own" armbian for educational purpose. I mean to raise my knowledge. I followed this page. https://docs.armbian.com/Developer-Guide_Build-Switches/ however since it's done. I'm looking for about how to make the *.img file or if I can use *.deb located in my ~/build/output/debs I just miss these informations to finish and trying my failure compilation. I say failure compilation because "first time" is always a fail By the way, if I posted in the wrong place. Delete my post and please accept my apologies.
December 17, 20241 yr Hi and welcome. tl;dr version: ./compile.sh and following interactive menu will output an image based on selection. Image will be in output/images created debs are just side products ./compile.sh kernel BOARD=orangepi5plus BRANCH=vendor will create a set of kernel deb files only and will be in output/debs
